Dome light - auto off?
Discussion in 'Gen 2 Prius Main Forum' started by Beven, Oct 12, 2008.
  1. Beven
    Beven New Member
    Outside Boston
    Hi All,
    Just rented a Prius this weekend, and all went well! Took a 300+ mile roadtrip, and got about 50.9mpg! Wow!!! Now just have to look at the possibility of getting one...eventually. :)
    Quick question tho (and I hope someone knows offhand) -- when dropping it off, I manually turned the overhead light on to make sure I had everything out of the car. Well, I put my keys in the drop box, and found that I left the dome light on! :(
    Does the light automatically turn off after a certain amount of time? I'm sure it wasn't on the "door" setting -- I manually left it on... :(
    Thanks!
  2. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    Yes, as long as the switch is set to "door" the light will turn off by itself.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The OP said it wasn't on the door setting. If you leave it manually on, it will turn off automatically once the 12V battery is dead. :rolleyes:
    Tom
  4. Beven
    Beven New Member
    Outside Boston
    I decided to go back to the rental agency, and sure enough, the light was still on... :(
    Thankfully, AAA to the rescue -- unlocked the door, and slid it back to "off" just to make sure it wasn't coming on again...
    Thanks!
  5. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    the ones you have to watch out for are the map lights, if you leave them on, they will be on forever until your battery dies
    when i first got the car i was always thinking i left the dome lights on, because the way the dome lights come on when you
    walk up to the car!
