Dome light will not turn off...
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bielinsk, Feb 13, 2013.
  1. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    Car is acting like a door is open, but I don't have any symbol for an open door.
    So the dome lights will not shut off unless I turn the overhead switch off. But this keeps the puddle lights bright, and with that, my exterior turn signal puddle lights stay on.
    This happened in the past, but went away.
    I have had door sills and the turn signal lights installed and am nervous going into the dealership they are going to blame me for this.
    Any ideas?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    First thought is a malfunctioning door switch. Second thought is the aftermarket add-ons in terms of faulty wiring.
  3. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    Checked the door switches. Each one will turn off the illuminated door sill, so the ground there is being broken (and stopping power) as it should. Is there some switch in the door other than just the rubber covered push thing?
    The turn signal mirrors do tap into the puddle lights and dome light for power only, they don't have any type of activation to them that I am aware of.
  4. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Did you try opening/closing the rear hatch as well? Some people have had trouble where even though it was closed it didn't register with the car being closed. Long shop perhaps but worth a try nonetheless, assuming you haven't already tried it.
  5. mrbigh
    3,686
    699
    Long Island, NY
    Agree with Paradox, the rear hatch door switch..............
  6. bisco
    52,761
    could this have anything to do with the scratchy speaker?
  7. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    That is another thing I am worried about. Speaker has been quiet for a couple days.
    I went out and checked each door. Slammed the hatch twice. Now the dome light is off and working correctly.
    I am missing something here.
  8. mrbigh
    3,686
    699
    Long Island, NY
    Yes, you'r missing a solid connection...................:LOL:
  9. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    Actually, if that was the case, then the lights would not come on at all.
  10. retired4999
    2,652
    627
    Eau Claire, Wi.
    I think it is possible to shut the rear hatch, just on one catch, door looks and seems shut but it is not, needs to be shut harder to actually be shut properly. maybe? :)
  11. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    I looked and I can't seem to locate any type of switch for the hatch. Must be in the latch mechanism itself.
  12. retired4999
    2,652
    627
    Eau Claire, Wi.
    Hummmmmmmm? I really don't know, sorry! :unsure:
  13. raimix
    raimix Member
    204
    33
    Long Island NY
    i would suggest service visit.
  14. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    Went back to my installer and he took everything apart. Turns out, the passenger side light assembly of the JDM turn signal mirrors has a short in it. So with that light connected, it causes a ground. Disconnect that light, and everything works as it should.
    Now I get to try to get a hold of the ebayer and try to convince them to send me a replacement.
  15. retired4999
    2,652
    627
    Eau Claire, Wi.
    Good to hear you found the problem! Not so good, now a different problem to deal with, but light at end of tunnel.
  16. bisco
    52,761
    aha! all the best!:)
  17. lensovet
    2,615
    496
    Burlington, NJ
    ha ha light! get it?
    retired4999 likes this.
  18. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    The ebay seller said No Problem and will ship me out a new light assembly. Good to hear people stand by their products.
    lensovet, Tracksyde and retired4999 like this.
