Don't Buy a 3rd Gen Prius! - Blown headgasket at 233k
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Absalom, Feb 13, 2019.
  1. Absalom
    Absalom Junior Member
    42
    42
    Denver
    I don't consider your reply to be sidetracking at all. I want answers on why a HG would fail on a seemingly healthy car that wasn't overheating or consuming coolant.
  2. Mendel Leisk
    41,440
    How are you monitoring temperature? Just an aside: it'd be REALLY nice if Toyota could include a coolant temp gauge on these cars.
  3. frodoz737
    frodoz737 Top Wrench
    4,699
    2,497
    33
    The OP bought a very used and already broke 2010 Prius with 233K miles on it. :whistle:
  4. Absalom
    42
    42
    Denver
    Why didn't you tell me in advance?? :whistle:
  5. Borninblue
    Borninblue Active Member
    233
    158
    Cleveland, Ohio
    Did you clean intake manifold too?
    Bay Stater and Mendel Leisk like this.
  6. Mendel Leisk
    41,440
    The "Torque To Yield" bolts you're referring are the cylinder head bolts? Attached is a TSB for piston/ring replacement, and they put those bolts in an "as needed" category; not sure what that means. There's a revised part number for them too. IIRC you're looking at around $100 to replace them. Maybe cheap insurance??
  7. Mendel Leisk
    41,440
    Torque-to-yield fastener - Wikipedia
    Wiki suggests to replace though (see "disadvantages" in the above. What would define the bolts as being TTY? Just that it's common for cylinder head bolts? The distinctive torquing method?
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Well...
    You bought a high mileage, used Prius. In those cases, you don't know how it was driven or maintained.
    Hardly fair IMO to disparage the build quality of Prius and Toyota, when you are dealing with a vehicle you bought used and have less than month experience with.
    Yaga1973 likes this.
  9. egn83b
    egn83b Junior Member
    59
    Rarford nc
    If the hg is an issue on these motors it might be well worth a new set of tty bolts and seal up the engine with silicon glass sealer at 230k miles. Nissan altima's back in the mid 2000's grenaded 4 cylinder engine like crazy because the aluminum was too soft and not repairable. The biggest cooperates in most hg failures is when the thermostats stick closed for too long. There is a video on youtube of a prius with a bad coolant pump which still ran but didnt turn so it might be good to throw those away at 200k too.
    mjoo and Raytheeagle like this.
  10. Mendel Leisk
    41,440
  11. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
  12. padroo
    padroo Senior Member
    2,763
    2,252
    It seems that aluminum engines with aluminum heads are more prone to head gasket problems than the old cast iron versions. They certainly don't handle overheating as well. All in the name of saving weight.
    mjoo likes this.
  13. Absalom
    42
    42
    Denver
    From those that have actually done it, when using an OEM HG, do I need to use a gasket sealant at all?
  14. Mendel Leisk
    41,440
    Repair Manual says just a couple of dabs of "seal packing", at leak-prone points I assume:
    Absalom likes this.
  15. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Just buy a $15 subscription to alldatadiy. It will have all of the info you need for 12 months. Use coupon code AZREWARDS.
    Absalom likes this.
  16. padroo
    2,763
    2,252
    Absalom likes this.
  17. ekpolk
    ekpolk What could possibly...
    548
    176
    Pensacola & Vero Beach FL
    2018 Prius
    Two Eco
    At the end of the "day," -- in the very long run -- the whole car is, in essence, consumable. Yes yes, I know the practical meaning of the term. My point is that, as some others have suggested, at this mileage, almost anything can happen.
    I just went through this with my Gen-2, worth about $2k by the book, but needing over $7k in work (severe brake system damage). Sure, a head gasket is a major job. But it's also a relatively simple one at least in concept (I wouldn't want to try one myself...). You just have to make the decision -- fix or scrap. . . I hope you find a good solution and wish you well. :cool:
    Absalom likes this.
  18. padroo
    2,763
    2,252
    Old cars and non DIY people don't mix well together.
  19. Absalom
    42
    42
    Denver
    The head is off, gasket was blown right at the #2 cylinder. Going back together tomorrow. Cake job so far. If I were a "DIY people", it'd be even easier.
  20. ekpolk
    548
    176
    2018 Prius
    Two Eco
    Pictures!
