Don't know what to believe about ICE coolant change
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bmparent, May 14, 2019.
  1. bmparent
    bmparent Member
    159
    65
    barre ma
    Further adventures in coolant-land...After driving around for a half-hour this morning, the day after having the fluids changed. I opened the hood after the car had been cool for 1/2 hour to check everything out. The inverter reservoir was really, really low as in like almost to the bottom. So I filled it to the fill line. It went down again! Filled it up again and it stayed. Now I'm worried that I'm going to get air bubbles in the system. BUT the good thing is that when I look into the reservoir, there is way more turbulance/movement that there was before I had the coolant changed. From what I hear that's a good thing.
    What do you think did the dealership screw up the levels? Was it ok to just dump some more in?
  2. Mendel Leisk
    41,473
    It can't hurt to top up, likely more air pockets worked out.
  3. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Your not going to get air bubbles in unless there was no fluid at all in the reservoir. That was the reservoir doing it’s job of replacing trapped air in the system. Sounds like the dealer didn’t get all the air out when they did the change.
    M in KC and bmparent like this.
  4. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    I think both coolant changes are easy DIY projects. I’m trying to start MeetUps here in the Oregon area to try owners to do this stuff together. I have the experience, tools, and a 3-car garage... maybe you can start something like that where you live.
    johnjohnchu and bmparent like this.
