Don't let this happen to you. Inverter coolant warning.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PartsNinja, Dec 2, 2014.
  1. bisco
    51,896
    interesting that you weren't part of the recall, when that the part they recalled iirc. i wonder why it's a sub assembly now?
  2. PartsNinja
    PartsNinja Junior Member
    26
    There were certain codes (mine wasn't one) that could pop up indicating a problem in the IPM. To keep us from having to replace the entire inverter, Toyota made it available in component parts through the bulletin. Basically a warranty extension to 150k if and only if you get one of those codes. The dealer has to report it along with flash data and Toyota authorizes the warranty extension.
    BTW Smart cookies at techline. It's fixed!
  3. JC91006
    16,768
    8,565
    This is just weird. A Toyota dealer puts an additive to a coolant service that can ruin the inverters without telling the customer. Then to find out there has been other people the same problem with the added additive. Then the customer has to do the leg work in getting it repaired. Paying to get problems, how messed up is that! Man I would be really pissed off.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    I'm really confused on this whole thread. Was the car initially repaired at the dealer? And the tech at the dealer used some additive or something besides SLLC? Op says the dealer saw it in the records that an additive was used. And the op works at this dealership too? Wth?
    Well, why is the Op sweating all this? The dealer tech goofed it all up. Its all on them. What am I missing here?
    Btw, isn't replacement of the Inverter IPM circuit part of the TSB Service Campaign to fix the failing output transistors?
  5. Philliplewis590
    Philliplewis590 New Member
    Oakland
    I have a squeaking noise when I accelerate. Does this have to do with the inverter? Does it need to be replaced or flushed?
