Don't put the jump box or cables in the storage under the hatch
Discussion in 'Gen 2 Prius Main Forum' started by ToyotaGal, Jun 12, 2021.
  1. Mendel Leisk
    42,347
    Yeah my response wasn’t helpful either, off on a tangent. :oops:
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,014
    NJ-USA
    If the new battery can be charged and tests ok, then use a digital multimeter to measure voltage at the battery or the underhood jump-start point. If it's around 14.0V with the car in ready mode, then the charging system (the DC-DC converter) is working as it should. That would leave some sort of unintentional high draw that is draining the battery - aka "key off draw".
    It can be very tricky to diagnose this kind of fault, as you need a meter or "amp clamp" that can accurately measure very low current flow from the battery, the vehicle wiring diagram (and can read said diagram), and are able to test and locate what circuit the draw is on.
    xliderider likes this.
  3. ToyotaGal
    ToyotaGal Member
    212
    Millis, ma
    Going to Mechanic on Thursday LTMFIO. I really don't think its because something is not shut properly as when you lock car with fob if a door is open it beeps. I haven't been driving at night so lights have not been on.
    52,855
    electrical gremlins can be tough to track down. make sure the mech tests the battery with a load tester, then tests all the points of connection, including the jump point under the hood.
    if everything is good, he needs to put a meter on it and measue the draw compared to toyota's spec. if it's high, the search begins.
    a simple method is to measure the static voltage in the evening and morning. if it is dropping, the tough work begins.
    make sure all the lites are off after closing the doors in the dark, and lock the door to be sure nothing is ajar.
  5. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    How much time do you spend driving a day? A Prius 12v is charged more as a factor of time. It charges at a relativity fixed rate. I turned off my SKS when I started working at home. Will turn it back on when I start going to work everyday.
  6. qmanqman
    qmanqman Active Member
    444
    153
    CO
    Never seen this one. Can you please explain? I think I know what MF stands for.
  7. ToyotaGal
    ToyotaGal Member
    212
    Millis, ma
    Let The mechanic figure it out. It stems from an accounting joke of let the accountant figure it out.
  8. ToyotaGal
    ToyotaGal Member
    212
    Millis, ma
    A lot. But not all at once. last week I put 400 miles on her in 3 days.
  9. ToyotaGal
    ToyotaGal Member
    212
    Millis, ma
    So everything checked out with the mechanic. He said the negative wire was not all the way down but did not think that would cause it. He suspected it was within the security system. We decided to test it by locking the car making sure I activated the system and see if it goes dead.again. He also said my original fog was acting lazy and to change the battery.
  10. bisco
    52,855
    is that aftermarket security? they seem to wreak havoc at times
  11. qmanqman
    444
    153
    CO
    A ground wire (negative wire) not being tight can wreak all kinds of problems. That's always item #1 to check when having electrical issues.
    ToyotaGal likes this.
  12. mr_guy_mann
    4,118
    2,014
    NJ-USA
    Did your mechanic test (measure) the amount of current used by the car when it is turned off? (aka "key off draw). I usually have to trip the tailgate latch shut with the gate up so I can get to the 12V battery. Let the car sit for 15-20 min so all the computers" go to sleep" and measure the current. Typical is about 20 milliamps.
  13. bisco
    52,855
    sounds like you've got it licked
  14. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    "He also said my original fog was acting lazy and to change the battery."
    Fob?
  15. bisco
    52,855
    exactly, i was almost ready to ask what the lazy fog was :D
  16. ToyotaGal
    ToyotaGal Member
    212
    Millis, ma
    fob fog what the difference between a b and a g??? lol
    Mendel Leisk and bisco like this.
  17. ToyotaGal
    ToyotaGal Member
    212
    Millis, ma
    is thinga ma jinkey better ??
  18. ToyotaGal
    ToyotaGal Member
    212
    Millis, ma
    I think so
  19. ToyotaGal
    ToyotaGal Member
    212
    Millis, ma
    No clue I did know it had one? He told me if someone tries to steal the car hen activated, it would shut down after a few miles and no start again..
  20. bisco
    52,855
    that might be the oem, i'm not sure how it works.
