Don't put the jump box or cables in the storage under the hatch
Discussion in 'Gen 2 Prius Main Forum' started by ToyotaGal, Jun 12, 2021.
  1. ToyotaGal
    ToyotaGal Member
    212
    Millis, ma
    apparently when you hit the lock button 2x it activates the security system. If someone steals the car, it will only drive so far and then shut down.
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,013
    NJ-USA
    Nope.
    There's two systems on most cars. First is the "immobilizer", which prevents the car from starting or running if you do not have the correct key. Second is the "antitheft" system, which sounds an alarm if the car is opened without disarming the system using the key/fob. Neither system can "shut the car down" once it's driving.
    The antitheft arms anytime the car is locked. AFAIK double pressing the lock button on the fob just gives you a horn chirp as confirmation that "yes, I did really lock the car".
    Hope it works out for you on this.
