Don't Shoot the Messenger -- Tufoil
Discussion in 'Gen 3 Prius Fuel Economy' started by JSchnee, Mar 17, 2014.
  1. Former Member 68813
    3,524
    983
    US
    Now, what was the temp in January and February (to compare)?
    According to this source: New Jersey Monthly Mean Temperatures
    March is much warmer than the previous winter months (on average), and that will do your 10% change. please report back in summer with your MPG changes.
    BTW, there is is a reason you don't want particles in your engine. It was well studied before, but people have short memory:
    Taxicab Fuel Economy and Engine and Rear Axle Durability with Low-Viscosity and Friction-Modified Lubricants
  2. kye04
    kye04 Junior Member
    38
    Europe
    Best way to have your money in your pockets? But LPG on your car. I did it and i do not regret one second...
    ZENIT PRO OBD | Autogaspol I have this and now i drive faster than you for less money...
  3. Former Member 68813
    3,524
    983
    US
    Too bad it can't be done easily and legally in USA as it would be considered tampering with emissions and punishable by law.
  4. ETC(SS)
    7,566
    Gasoline isn't $9USD a gallon here.
    Too few places to fill here on the Continent. If I want range anxiety, I'll buy a LEAF.
    You have to haul a tank around.
    You have to disable/modify a 50-MPG(US) car for....what, again??
    It is a little cleaner, but what's the cost-per-mile?
  5. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    The manual never will state the use of additives!
    DBCassidy
  6. dbcassidy
    1,581
    290
    I'm surprised the Tufoil is still around.
    DBCassidy
  7. bwilson4web
    16,537
    Over time "Bob is the Oil Guy" started good and has gotten a lot better. One article I just reread:
    source:
    Effects of Shearing - Bob is the Oil Guy - Bob is the Oil Guy
    In my cars:
    • driving for efficiency - avoids high engine power settings, which tends to preserve hydrodynamic film. Our Atkinson engine is already running less power than the Otto versions of the same engine so the risk to the lubrication film is less. Add to that driving for efficiency and the engine has a gentle life.
    • preservation of the catalytic converter - we do this by keeping the oil level slightly below "F", never over "F", so the oil seals are not stressed AND there is no need for compounds that leaving the hot exhaust port are looking for some surface to condense on and coat . . . like a catalytic converter.
    • replace oil filter and oil regularly with a quality oil - it isn't that hard although the ZVW30 has made it harder than necessary for no good reason.
    In 1992, I saw a teflon additive that 'sounded good', a one-time treatment. Before that tank was done, that engine developed oil leaking, valve-guides. For the next 15 years, every cold start emitted an oil-based, blue cloud that as the car warmed up, disappeared. We just lived with it. But I decided I would never again use an additive in a new engine . . . old engine, who cares. But even our highest mileage Prius, 160,000 miles, is still giving 52 MPG.
    A couple of years or so ago, I read Argonne Labs had done some work on boron and thought to test "Motorsilk", which is a boric acid. I could find no evidence of any change in mileage and the oil changes remain quite ordinary. "Motorsilk" may increase the detergent function but I could find no evidence that the car became more efficient. Now I see another paper from the same lab with a different result:
    http://www.transportation.anl.gov/pdfs/MM/857.PDF
    There is a placebo effect, 'it is a pill so it must do some good,' but I'm more interested in hard data. It is one of the reasons why I don't participate in the 'low rolling resistance' tire thread because it has too much anecdotal and not enough, hard metrics. If it can't be measured, it is not science or engineering.
    I just don't have the energy or interest to play ad hoc experiments with Prius lubrication. In fact, one of the reasons I'm going with a two-stroke, engine for N19Wt, there will never be another oil change. It will always use virgin oil, just another consumable like the gasoline. Fortunately, the oil injection makes a significant reduction in the amount of oil consumed.
    So if someone wants to say "I put <something> in my <oil|gas> and now it works great!" I say, "Good for you." But if they ask if I want to do it too, "No, I'm waiting for the jury to come in."
    dbcassidy likes this.
  8. dbcassidy
    1,581
    290
    Tufoil led to the demise of my old Toyota engine. Plugged oil galleys took out the valve train, main crankshaft bearings and 2 of 4 cylinders were gouged.
    Not good. Now I stick w/ the owners manual and have no problems with engine lubrication issues.
    Tufoil - buyer beware!
    DBCassidy
  9. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
    Some of you guys are obviously hard to convince when it comes to oil additives. With people like you, how are these producers to survive?
    However, I am one of you and do not believe the hype of a miracle in a can.:)
  10. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    ...OK now where's the messenger (OP) so we can shoot him? If I tried something it would be the RedLine synthetic oil that I think EdtheFox likes.
    bwilson4web likes this.
  11. dogfriend
    7,512
    1,191
    Carmichael, CA
    And it stained the paint anywhere you spilled it. :cautious:
  12. Mike500
    Mike500 Senior Member
    2,593
    767
    Made you think every car had a diesel engine in it...
