Don't spend a fortune installing electrical
Discussion in 'Prime Plug-in Charging' started by Marine Ray, Dec 16, 2019.
  1. Marine Ray
    Marine Ray Senior Member
    1,139
    947
    Sparks, NV
    #1 Marine Ray, Dec 16, 2019
    Rob43 likes this.
  2. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    I found it "kinda" interesting, but this article was mostly written for BIG battery EV cars, not necessarily our Prius Prime with its smaller battery.
    Charging at a faster rate like Level 2 is of course up to the needs of that individual owner. I personally love being able to charge up in 2 1/2 hours using the Toyota OE EVSE unit for almost free.
    Rob43
    Matt1984 likes this.
  3. Marine Ray
    1,139
    947
    Sparks, NV
    Me, not being knowledgeable in electricity, was his electrical "amps, watts, volts, etc" accurate?
  4. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    The writer is all over the place with amp, volt, and price statements. Can you quote a direct sentence ?
    Rob43
  5. Marine Ray
    1,139
    947
    Sparks, NV
    Not really. Figured if you didn't raise the BS flag right away, the article was at least in the ball park. Thx.
  6. Elektroingenieur
    2,515
    3,284
    Three Touring
    I’m not sure I’d agree. The basic points—that a Level 1 charger may suffice for some EV users, and that a knowledgable electrician may be able to suggest lower-cost installation alternatives—are fair enough, but the article is weakened by errors, of which I mention two only.
    The author writes, “[T]he electrical code demands that your house be able to handle everything being turned on at once — dryer, oven, air conditioner and car,” which simply isn’t correct. The National Electrical Code has specific procedures for calculating service loads; in the 2017 edition published by NFPA, see Article 220, Parts III and IV, and the examples in Informative Annex D. Notably, the optional procedures for dwelling units in 220.82 and 220.83 use formulations such as “100 percent of the first 10 kVA plus 40 percent of the remainder” or “[t]he largest of the following six selections,” in effect applying demand and diversity factors, rather than just summing all of the connected loads as the author claims.
    The author writes, of a branch circuit for a receptacle used with Level 1 EVSE, that “It has to be dedicated — nothing else on that circuit breaker.” This is generally a good idea, but it’s a code requirement only for new outlets “installed for the purpose of charging electric vehicles” (NEC 2017, 625.40).
    Perhaps I’m fastidious in such matters, but I’d also hesitate to take electrical engineering advice, especially about the details of installation codes, from anyone who writes “plug” when “outlet” or “receptacle” is meant.
    noonm, MTN, jerrymildred and 4 others like this.
  7. Marine Ray
    1,139
    947
    Sparks, NV
    Thanks for your feedback. Would you be willing to communicate this with the author of the article? It is Fortune magazine.
  8. m8547
    m8547 Senior Member
    946
    626
    Colorado
    2018 Prius Prime
    The article is full of minor errors, misleading statements, and over-simplifications. I stopped reading. Forbes is a bit of a content farm these days, not so much a reputable news source anymore, so I doubt it's worth contacting the author. It would be more work than just writing your own article. But the basic point is reasonable, that if you only drive a certain amount in a day, you only need a charger that can provide that amount of charge (or a bit more) overnight. But if you have a non-Tesla EV where public charging is slow or expensive and hard to find, then I think you need to size the charger for the worst case scenario, which is probably getting back from a trip with an empty battery, then going on a longer than average drive (but not totally draining the battery) the next day. I think charging an EV with only L1 would cause some serious range anxiety, even though I think it would work for most people's commutes and average daily driving.
    Marine Ray likes this.
  9. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    In a general, big picture kind of way, Brad Templeton did an OK job addressing some of the issues. He would have been well-served to have let a practicing electrical engineer or electrician do a quick editorial proof-reading to clarify some of his points and to bring consistency to his use of terminology. (e.g., a plug is inserted into a receptacle. That thing mounted on the wall is not a "plug.")
    The article makes an attempt to get one thinking about one's vehicle use pattern and determining how-much how-fast one needs to re-charge one's vehicle to sustain, say, daily commuting. It does not address how other use patterns -- such as lots of random short trips to run errands separated by periods of being parked at home charging -- might affect one's decision. And, of course, no mention of shorter range BEVs and PHEVs which may need to be charged more frequently for shorter periods of time.
    This, and all the other comments here on Prius Chat, show that the subject is more complex and nuanced than one might expect. Kind of like standing in front of the 200+ brands, styles and flavors of yogurt at the supermarket and turning to the fellow shopper next to you and asking "Which one do I want?"
    #9 Old Bear, Dec 17, 2019
    jerrymildred likes this.
  10. Marine Ray
    1,139
    947
    Sparks, NV
    Agree, sometimes too many choices is too much.
  11. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    When I read that in the article I thought, "Really?! When did they change that?" :D
    Yeah, lots of technical errors, but the general idea that you might not need max power for your charging needs is valid. But then again, you may discover, as I have, that sometimes you just can't get charge back up fast enough.
    I've been noticing that lately. Lots of headlines from Forbes in my Flipboard feed that are just clickbait.
