Donut Spare for 2017 Prius Prime?
Discussion in 'Prime Main Forum (2017-2022)' started by NEHiker, Jun 26, 2018.
  1. NEHiker
    NEHiker Junior Member
    16
    Massachusetts
    Hi everyone. I know there have been lots of threads with regard to spares, so forgive me if I'm rehashing old stuff! This past weekend, I picked up my new 2017 Prius Prime. I've been thinking it would be practical to have a spare tire on hand for long trips. I went to my local Toyota dealer this morning to inquire whether a donut spare from a 2017 (or other model year) "regular" Prius would fit my car. The parts department guy was insistent that *no* donut would fit the car and it would harm the vehicle to put a donut on it. Instead, I would have to get a full size wheel/tire, to the tune of ~$300 for the rim alone. This all sounds kind of bogus to me, based on other information I've read here. Have any other 2017 Prime owners out there uncovered different information at their dealer? My plan was to check out some local junkyards for a salvaged donut spare, once I figured out the right model and year to search for... Thanks in advance, as always!
  2. Mendel Leisk
    42,293
    Yeah there are lots of threads on this, but anyway:
    I think you're really being shortchanged by that dealership. The Prime is basically a fourth gen Prius, in MANY aspects, and the fourth gen temporary spare will work fine. It's deplorable that they didn't at least have the gumption to try putting one on, drive around the lot, check it out.
    Probably third gen temp spare would be fine too, I think they're the same as well? Second gen, probably the rim will be fine, the tire slightly undersized though.
    Note, if you were to start looking for used, keep in mind tires age, might be best to stick to recent vintage.
    NEHiker likes this.
  3. SaraBBrown94
    SaraBBrown94 Active Member
    234
    263
    Pittsburgh PA
    They might have been considering the weight of the car being several hundred pounds more than the regular Prius and most cars on average. I'd imagine that would make the "no more than 50mph for 50 miles" reduced further.
    Have you ever considered a patch kit(with the plug and stuff)? I looked into it and the process is actually pretty easy looking. Much cheaper and lighter than extra tires and then you don't lose ABS and get error messages.
    If you do buy a junkyard tire, maybe getting a full sized one and just leaving it at home if you had someone that could bring it to you in an emergency would remove the concern about using a spare.
    Not really answering your question but I'm in the same boat as you trying to consider what to do about the lack of spare.
    NEHiker likes this.
  4. Mendel Leisk
    42,293
    Good to have both, spare tire and plug-repair kit. Then you can remove the flat, put on the temp spare, and plug-repair when you're home. Using the plug-repair kit is much easier standing over the tire, using your weight. And much more comfortable, less risky, than side-of-road, in the elements.
    I got a BlackJack kit soon after getting our 2010: one tire had a tiny finishing nail, about an inch from tread edge, and dealership deemed it too close to edge for a "kosher" inside/outside style patch/plug repair. I did an outside-only plug repair, that was maybe around 25K kms, and the tire's still on the car now, around 75K. I've used the kit also on one of our snow tires, and at least a couple of other times on other family cars.
    Putting on a 4th gen temp spare should not do anything to the Anti-lock Brake System or trigger error messages. If you're thinking due to different tire OD, that is not the case: temp spares have the same OD.
    #4 Mendel Leisk, Jun 26, 2018
    NEHiker likes this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    The only problem I can foresee with either sized spare for the Prime is securing it when not in use so that it doesn't take your head off in an accident.
    pjm877, NEHiker and Mendel Leisk like this.
  6. Mendel Leisk
    42,293
    I keep thinking about coming back from Costco, with four loose rims and tires, stacked akimbo in the hatch. :ROFLMAO::eek:
    Are there some D-rings at deck level, or are the lower ones "submerged" in the Prime hatch. Also, there might be a tire retaining belt supplied? There was one on our 3rd gen, excerpt from Owner's Manual:
    #6 Mendel Leisk, Jun 26, 2018
    jerrymildred likes this.
  7. jerrymildred
    11,517
    14,167
    Tampa, FL
    PiP has 4 D-rings. I was not able to find any in the Prime Advanced I looked at. And I looked diligently for them.
  8. Mendel Leisk
    42,293
    I'd suspect the weld-nuts for them are there, but buried by the raised deck? If really lucky, the D-rings are down there too, but I doubt it.
  9. Rightrudder
    Rightrudder Member
    49
    59
    Nazareth, PA
    Got a donut spare for my prime from the first auto salvage yard I went to. $30 and it had never been used. It sits behind my driver's seat very well. Also got a small vinyl cover for it. The guy at the salvage yard did a bit of research and said that the 2016 Prius's donut is also cross-listed with the Corolla's and Matrix's. Just make sure it has 5 holes, not 4
  10. NEHiker
    16
    Massachusetts
    Nice! I will see if I can find something similar near me... Seems well worth $30...
  11. Mendel Leisk
    42,293
    I'm using Corolla full size 15" steel rims with snow tires.
    NEHiker likes this.
  12. Mendel Leisk
    42,293
    Check the date on the tire. Temp spares do tend to live a sheltered life, but a 10+ year old tire that's been been maybe out in the elements more, is past it's due date.
    NEHiker likes this.
  13. NEHiker
    16
    Massachusetts
    Great advice - thank you very much! I am going to see if I can get an unused 2017 Prius temp spare (or something compatible like a Corolla spare). Might be like looking for a unicorn, but we'll see :)
  14. PHIL620
    PHIL620 New Member
    Long Island NY
    Have you tried it on your car yet? what is the size of the tire? thanks, Im getting crazy trying to find a spare donut. A lot of suggestions but no one seems to e saying they actually put it on their car.
  15. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    --Is the compact spare the same outside diameter as the original tires?
    --If not, will the unique Prime drivetrain be OK with the compact spare on the front?
    --Good point above about comparing the Prime weight to the weight of the Gen 4 or Corolla or whatever the compact spare is designed to be used on.
  16. Washingtonian
    Washingtonian Senior Member
    726
    621
    I bought a temporary spare from a Lexus CT200H online. Size is T125/70D17. Made by Bridgestone in Japan and says to inflate to 60 PSI. I installed it on the back of my Prime and drove around a couple of blocks to see how it would drive and it was fine. I would recommend that if you have a flat in front, replace that tire with one of your rears and only use the temporary on the rear. I keep the spare in the garage so I can have someone bring it to me if I have a flat on the road somewhere. If I ever take a really long trip I will probably take it along, upright behind the driver's seat.
  17. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    I have a full size spare on steel rim kept in my garage. My driving is 99% of time within 30 miles of my home, and I can just call my home to have it brought to me in case of flat on the road. For remaining 1% of time I drive out of town, I should take the spare in my car, but those longer trips are the ones that requires more cargo space, so I have been driving without a spare. I don't think a full size spare will fit behind the seat, but I haven't tried that.
  18. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    Well the genius in the parts department at the Toyota dealer today told me that you can't put a steel wheel on a Prius because the regenerative braking system works by determining the weight of the wheel, and if you use a steel will you will ruin the system. I then went into the service department and asked the service manager who brought a mechanic in and said that a wheel made of steel can be used and has nothing to do with the regenerative braking system whatsoever. We then went back into the parts department to talk to the genius. After the dust settled the service manager apologized at which point I said he should have put his brain in gear before he put his mouth in gear.
  19. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    Probably not. Prius’ with 15” and 17” wheels use the same compact spare size.
  20. Mendel Leisk
    42,293
    1. The 15", 17" and the temp spare are all very close in outside diameter.
    2. Will be fine. Just keep speed under 50 mph, and get the original tire repaired and reinstalled asap.
    Some conflation going on?
