Door actuator
Discussion in 'Prius c Technical Discussion' started by Javierz0509, Aug 18, 2017.
  1. Javierz0509
    Javierz0509 Member
    111
    52
    Miami
    My passenger door actuator does not work but if i tap it it will work, can it be fix instead of replace?
    #1 Javierz0509, Aug 18, 2017
    49,694
    can you expand on the terms 'put' and 'tsp'?
  3. Javierz0509
    Javierz0509 Member
    111
    52
    Miami
    Sorry..fixed my words.
  4. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Do a search here for "lock actuator".
    You should find a thread where someone detailed the procedure to remove and fix one.
    IIRC, it wasn't a trivial matter.
    But dealer cost to fix is rather high.....to the point of being outrageous, I think.
    When my second one failed.......out of warranty......I traded the car in.
  5. bisco
    49,694
    does it work with the door switch, the drivers door switch, or the key fob?
  6. Javierz0509
    Javierz0509 Member
    111
    52
    Miami
    This is what was happening it like as if the motor in the actuator gets stuck (dirty maybe) I took off the complete actuator assembly and open it to take out the little motor and I cleaned the brush and put back everything and it worked, someone from youtube suggested that if the motor gets stuck again replace it with a 20mm flatshaft motor $7 on eBay. For now the clean up has worked.
  7. bisco
    49,694
    well done!(y)
  8. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    I recently did this swap. Locking and unlocking the door manually would work for about 2-3 days and then the issue would return. I found the part (do a search on the forum, I added the part number) for ~$35 after shipping. Took me an hour.
