Door arm rest and center console questions 2014
Discussion in 'Gen 3 Prius Main Forum' started by HoustonEvolution, Mar 18, 2018.
  1. HoustonEvolution
    59
    44
    San Antonio, TX
    2023 Prius
    Thanks everyone for the advice on the license plate question. I read up on the missing extra fob & it looks like the best ( i.e. easiest) method for replacing a keyfob might be to hit up the dealership. I'm gonna call tomorrow and ask.
    Now my remaining questions (I think) are about the driver's side door armrest and the center console lid replacement. (2014 Prius Two, cloth, grey interior). I did a bit of searching and found discussions about replacing whole doors but not the interior piece only.
    The driver's side door armrest looks broken once you put pressure on it. To just look at it in the normal state looks fine but once you press on it, it easily gives way. Has anyone else encountered this and if so, any ideas on how to fix it (or replace it)?
    The center console lid is pretty badly worn & if the rest of the car was in similar condition then I likely wouldn't even bother with it. I believe I can order a replacement lid. That's easy enough but I forsee that exact thing repeating in a year or two. What about ordering a leather one? (I have the cloth interior). Does anyone know if the leather one could be a direct replacement? From the parts diagrams, it looks like you can just remove the lid and put a new one on.
  2. HoustonEvolution
    59
    44
    San Antonio, TX
    2023 Prius
    Hi everyone. Just a polite bump to see if anyone knows the answers or has any tips on where to look.
    thanks!
  3. m3pare
    m3pare Senior Member
    679
    1,818
    SoCal (626)
    For the panel, you can remove it off the door and reattach the center portion to the frame with glue or screws. The armrest is replaceable, and either the black Persona or grey trim level Five armrests will work from a 2012-2015.
  4. gak27
    gak27 Prius, Take Two
    117
    Akron, OH
    I've seen a couple of videos on YouTube discussing how to repair the armrest "collapse" issue - not all glues work; I know one video has links to the two-part epoxy he used to fix his...
    m3pare likes this.
  5. HoustonEvolution
    59
    44
    San Antonio, TX
    2023 Prius
    thanks to all the responses and it might sound strange but its good to hear that this has been seen before. I hope to investigate this soon. (dang work schedule isn't allowing the time lately!)
