Door Belt Weatherstrip replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Prius2010owner, Sep 4, 2020.
  1. Prius2010owner
    Prius2010owner Junior Member
    LA
    Both the driver and passenger side have fallen apart and I feel like I should replace them.
    My questions are...
    How important are these door belt strips? If I decided to never replace them, what could happen?
    What do these typically cost?
    Has anyone replaced these before?
  2. Ed Beaty
    Ed Beaty Active Member
    334
    309
    Salt Lake City
    Here's a PC thread on that which may be of use...
    Raytheeagle and jerrymildred like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    Do you mean the ones at the base of the windows on the outside? The sun eventually destroys them. I've replaced several on Gen 2 Prii. They were not prohibitively expensive, but did cost more than I thought they should. $40 + seems to ring a bell for me, but Gen 3 could be different. There are plenty of online Toyota parts places you could look up such as
    Toyota Parts and Accessories - Official Online Store
    A quick search led to this, if it's what you're looking for.
    2010 Toyota Prius Hatchback HYBRID Parts like Door Window Belt Weatherstrip
  4. ASRDogman
    ASRDogman Senior Member
    6,092
    3,273
    They help keep the rain from getting inside the door, sitting there, and rusting out the bottom of the door.
    jerrymildred likes this.
  5. ChapmanF
    15,621
    I'm not sure they are always tight enough on the glass to keep rain out, but even so I'm pretty sure they help keep other junk from coming in with the rain, and clogging the drain holes at the bottom of the door, leaving the rain sitting there, and rusting out the bottom of the door.
  6. ASRDogman
    6,092
    3,273
    I did say "help".....
  7. ChapmanF
    15,621
    Either way, they help....
    ASRDogman likes this.
  8. orenji
    orenji Senior Member
    5,884
    3,486
    Does it rain in LA? ;)
  9. ASRDogman
    6,092
    3,273
    Man, it pours!
  10. jerrymildred
    11,511
    14,113
    Tampa, FL
    I spent nine months there doing consulting work. They would get all excited about a quarter inch of rain. I'd sniff and tell them, "Hmm. In Florida, we call that 'dew.'" :whistle:
    ASRDogman and orenji like this.
  11. Stangar
    Stangar Active Member
    174
    173
    Palmdale, CA
    Do it!
    I recently replaced my "Door Window Belt Weather Strip" on my 2011 Prius as a couple of them had torn rubber next to the window that was no longer effective and unsightly. Replaced all 4 and they were $46 each. Pricey, but when see the construction of these you will understand why.
    Toyota Part nos:
    Left Front: 757204-47021
    Right Front: 75710-47021
    Right Rear: 75730-47021
    Left Rear: 75740-47021
    Once you have your new ones in hand it will become very obvious as to how to replace these.
    I suggest you procure the 4 inexpensive plastic tools from Harbor Freight to help remove the original weather strip and to prevent any paint gouging. They are listed as ITEM 69668 (Pittsburgh) "Nylon Pry Bar Installer Kit". Great, inexpensive item for installation and removal of trim and a number of other efforts.
    Patience is key here. Take your time. Easy does it. Good Luck!
