Door window weatherstrip
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by spacecoastbill, Oct 14, 2017.
  1. spacecoastbill
    spacecoastbill Junior Member
    25
    16
    Goodyear,AZ
    Has anyone replaced the weatherstrip on the windows of the doors? Mine seems to have come apart and I want to replace it.....
  2. JC91006
    16,935
    8,646
    Yes they melt away. It's called a belt molding. Best to replace all 4 doors at once
  3. spacecoastbill
    25
    16
    Goodyear,AZ
    Where is a good place to get it?
    Is there a how to posted anywhere?
  4. JC91006
    16,935
    8,646
    You can get them online, like parts department of camelback Toyota in Phoenix.
    There's instructions in the package. Clips on in seconds
    kilimar likes this.
  5. spacecoastbill
    25
    16
    Goodyear,AZ
    OK, for the benefit of anyone replacing theirs, the part numbers are:
    front left 75720-47021
    front right 75710-47021
    rear left 75740-47021
    rear right 75730-47021
    #5 spacecoastbill, Oct 15, 2017
  6. scottmk
    scottmk Junior Member
    I replaced my driver's side belt weatherstripping on my 2011 GIII. I found instructions on YouTube for a GII but found better instructions (with pix) for the GIII on eBay at the bottom of the part item page:
    I can't post a link to the eBay page, but if you search for the part number -- 75720-47021 (LH driver's side), you'll find the instructions by mainmanmanne which specifies no tools (unlike the YouTube video). It took me under 10 minutes, using just my hands. There's a cover in the door front interior over the outside mirror mount; gently pop that cover off and then you can pop the belt weatherstripping off to start the removal. Gently work it our from front to back, where the clip is. I then took my time and very gently worked the clip out. Installation was a reverse process, beginning with the clip and then gradually seating it from rear to front. Last step is replacing the mirror mount cover.
  7. mikesparky
    mikesparky New Member
    Chapel Hill, NC
    Thank you for listing this!!! I've spent more time than I expected trying to find part numbers! (For those searching: outside window molding, window weatherstrip, parts numbers)
    kc410 likes this.
  8. CR94
    CR94 Senior Member
    2,822
    1,238
    Northwestern S.C.
    The ones on the left side of my Prius deteriorated into a gummy mess like elderly rubber bands. I bought replacements from the local dealer, which matched internet prices (for the first and only time).
  9. JC91006
    16,935
    8,646
    You should just change the right side too, they will soon be the same as the left side. I had to replace all 4, drivers side was the first to go
  10. CR94
    CR94 Senior Member
    2,822
    1,238
    Northwestern S.C.
    I suspect the left ones died first beause they got a lot more direct sunshine. The dealer parts guy said the part number reveals a design update, which I hope means the new ones are made of better material.
