Door edge guard
Discussion in 'Gen 4 Prius Main Forum' started by Haji1987, Jul 19, 2017.
  1. Haji1987
    Haji1987 Junior Member
    24
    17
    Los Angeles
    Three Touring
    I just bought a 2017 Prius 3 Touring and noticed that the edge guard was not installed correctly. It's the film kind. I didn't notice when I received the car last night that the bottom edge was peeling away on the driver side and the passenger door behind the driver. The other doors are stuck on great.
    Anyway, just wanna make sure that these are indeed edge guard before I go to the dealer again and not something meant to be taken off. Does anyone else have a 2017 Prius with edge guards factory installed?
    RCO likes this.
    52,888
    idk, but i have a feeling they're only there until you buy the car. did your purchase include them as an option?
    RCO likes this.
  3. Haji1987
    24
    17
    Los Angeles
    Three Touring
    It did not include it, but they came on all the doors and under the handles as well. They are very thick vinyl strips that are similar to the ones my Prius C had. Maybe I should just take them off? I called the dealer and they said because they had to bring the car from another dealership, that other dealership puts aftermarket edge guards on all their doors and they didn't want to replace them because of that. But they offered to remove them and make sure there's no residue. I might just take them up on that offer.
    RCO and bisco like this.
    52,888
    if they are supposed to be permanent, it's too bad one is peeling off.
  5. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Use isopropyl alcohol to soften the adhesive and press them back on. A cloth soaked in it works well. It won't harm the paint but will remove any wax on there (on a new car there shouldn't be any wax, but ymmv). ;)
    RCO likes this.
  6. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    My 2016 only has a small (200mm) piece on the front of the rear wheel arch (I've highlighted the 2 ends).
    CoastRider likes this.
  7. CoastRider
    CoastRider Active Member
    305
    397
    Off into the sunset...
    Mine has the same as Alan. Factory applied. But I've never seen them on the front door edges, as the OP has. The door edge guards the dealer sells are usually an accessory, and black metal. (I think the Prius Chat Shop also sells them).
    #7 CoastRider, Jul 19, 2017
  8. Prodigyplace
    12,720
    11,852
    Central Virginia
    As far as I know, Toyota only has door edge guards
    and body side moldings
  9. CoastRider
    305
    397
    That looks better than the black ones.
  10. liquidtenmillion
    liquidtenmillion Active Member
    261
    194
    Easley, SC
    My 2017 DID come with door edge guards like the OP. I would go to the dealership and have them replace it, it should only take maybe 10 minutes to install a new one. It is there to protect your door in case you slam it open into something.
    My 2017 also came with paint protection film on the painted part of the mirrors, door handle cups, and the front bumper. My 2015 did as well. I was not sure if this is a Toyota thing or a South East Toyota thing. I suspect you have the same film in the same places.
  11. Priifan
    Priifan Member
    93
    143
    Cary, NC
    Too bad they don't come with permanent heavy clear plastic ones that hold up for a long while. Dings on door edges look like crap on such a gorgeous car, and it would cost the manufacturer about two bucks to add them, wouldn't it?
    RCO likes this.
  12. Lwirmo
    Lwirmo Junior Member
    Socal
    Mine came with it on all four doors and walls behind the handles. Need to keep reminding my five years old not to peel them off but so far they stay up alright. Only wish the ones on the rear doors can cover a little bit lower. When we were finalizing the paperwork, the finance manager came out and wanted extra $299 for this dealer "option". I told them to f*** off (in a nice way).
    RCO likes this.
