Door handle sticking open
Discussion in 'Gen 4 Prius Main Forum' started by liamr, Jan 22, 2018.
Tags:
  1. liamr
    liamr Junior Member
    Ireland
    Hi...
    On my 2016 Prius both the passenger and drivers side external door handles do not return to their flush position once they are released. To get them flush again is necessary to push on the end until they fully retract. As far as I can see the handles have become slightly warped and so piece of the handle catches on another part of the mechanism.
    Has anyone else experience this?
    Liam
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Not that I'm aware of. Get back to your dealer PDQ.
    pilotgrrl and bisco like this.
    52,782
    agreed, i don't recall reading this before either. sounds like something is sticking.
    RCO likes this.
  4. 303inthe510
    303inthe510 Member
    65
    70
    Oakland, CA
    I once had a 2006 BMW 330xi that had this occur on 2 or 3 door handles. It was under warranty and BMW replaced all 4 door handles.
    I have never had any issues with either my former '12 or current '17 Prius' door handles.
    Keep us posted on what Toyota says/does --
    RCO likes this.
  5. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Ice ? The solid water kind ?
  6. MichaelM44
    MichaelM44 New Member
    England
    Excel
    Hello Liam,
    I am having exactly the same problem with both front door handles on my Gen 4 Prius Excel. The problem has slowly got worse over recent months.
    I thought a bit of grease or WD40 would cure the problem but as the car is only 18 months old, I decided to let my Toyota dealer do this.
    However, after examining the handles, the Service Dept. said the problem is more complex and they need to take the handles apart. This may involve stripping parts of the doors. I have yet to book the car in for the work to be done and I stupidly did not think of asking them if they had tried greasing the handle mechanism.
    Have you solved the problem with your door handles?
  7. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Welcome to Prius Chart, Michael. @liamr has not been heard from since his original post, so you might want to have a conversation with your service manager about the fault.
  8. MichaelM44
    England
    Excel
    Thanks. I will report back when I have an answer to the problem.
    RCO likes this.
  9. JimmyPri
    JimmyPri Active Member
    201
    245
    Hilo, Hawaii
    Yes, I had this same door handle problem. It seems to happen when we have several days of rain. I spray with a lubricant by holding the handle open and spray back into the mechanism. That works for several months until the right conditions happen again. Next time I should report it to Toyota while still under warranty. Sorry for delay in answering I have had medical issues.
  10. padroo
    padroo Senior Member
    2,763
    2,253
    Sounds like a common problem and should be reported the the NHTSA.
  11. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Are you sure this would come under the category of Safety Issue?
  12. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    I have not had any door handle issues with my 2016 Prius, and we had a few icy days and even more rainy days this winter.
    RCO likes this.
  13. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Yeah, while others suggest this is not a one-off fault, it needs to be reported back up through the Toyota supply chain.
  14. Prodigyplace
    12,710
    11,848
    Central Virginia
    No issues with my 2017.
    1 US user & 2 international users does not an epidemic make.
    RCO and krmcg like this.
  15. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    That's right, but they might just be interested that it's happened a couple of times. Even if that's just on Prius Chat!
  16. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Mine did it yesterday when we had the hot weather, both front door handles. It seems that the handle is expanding and getting slightly longer and catching on the lock barrel. Pushing the handle forward let it close fully. It's not done it since but I'll keep an eye on it and if it does it again I'll get it to the dealer (or I might just trim some plastic off the front of the lock barrel hole with a hobby knife).
    RCO likes this.
  17. Prodigyplace
    12,710
    11,848
    Central Virginia
    Curious. How warm?
  18. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Not hot by your standards, 26 deg C and just before the hot days we had a week or more of persistent rain too so high humidity.
    #18 kithmo, Apr 20, 2018
    RCO likes this.
  19. Prodigyplace
    12,710
    11,848
    Central Virginia
    It has been very wet around here and I think temperatures were higher earlier this week. I have had higher temperatures and no issue with my Prius.
  20. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Hmmm - I guess mine will only do it on the driver's door - no lock barrel on the passenger side. We've had cooler weather - with maximums about 26C o_O. That's getting to what I like. Any hotter and the a/c goes on, because it's usually accompanied with high humidity.
    RCO likes this.
