Door Lock Beep
Discussion in 'Prius c Technical Discussion' started by Further, May 30, 2013.
  1. Further
    Further Junior Member
    2020 Prius
    Is there a way to make my C2 beep when I use my key fob to lock and unlock the doors? this is he first car I've owned in decades that doesn't do this by default.
    Thanks,
    Daniel
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    C2 or C3? You mention 2 here, but you have 3 on your profile... so confused.
  3. R Scneider
    R Scneider Member
    86
    37
    Hitting the key fob lock Icon to lock and it beeps. Since my C3 unlocks by touching the handle I don't hit the key fob unlock button if ever.
    Dylan Murphy likes this.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  5. Ashley7
    Ashley7 Active Member
    545
    222
    Oregon
    2019 Prius
    If you have a Two (no Smart Key) it will not beep and there is no setting (dealer or otherwise) to make it do so. If you have a Three (with the Smart Key) it will/can.
  6. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    Check in your owner's manual.
  7. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    You can add the beep with an aftermarket unit. I have not seen one for the C but I am sure it can be done. I did one for my Vibe gt. Wife hated it because I was always messing with it when she was around, just to aggrivate her. Have not decided if I will fix this one to beep the horn or not. Seems I get myself into enough hot water already.;)
    Dan
  8. Luiggi
    Luiggi New Member
    Suffolk
    Any idea on this? I do have a prius c three with SKS and I'm having a problem right now with the flashing and beeping. It does not work when I lock it, it ONLY flashes and beepes when I unlock it either with the remote or using the handle. Car still locks and unlocks...its just tje beep akd flash that doesnt only when attempting to lock it. I really appreciate any feedback or solution. Thanks!!!
  9. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Pretty sure there's a setting to turn that on and off. Should be in your owners manual.
  10. Luiggi
    Luiggi New Member
    Suffolk
    I looked at the manual online bc i don't have a paper copy one, but i did find something in the "vehicle setting" its the feedback tone for lock and unlock, it IS all the way to the max so idk what else it could be. It's just weird because still works as it should when unlocks by hand or remote...
  11. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    That is weird indeed. If I get a free minute today, I'll do a forum search, I know there was a topic similar to this a few years ago. It's definitely a topic that comes up often. Maybe not your exact issue, but definitely the topic.
