door lock light
Discussion in 'Gen 3 Prius Technical Discussion' started by Old Smokey, May 13, 2012.
  1. Old Smokey
    Old Smokey Junior Member
    23
    thornhill on
    the door lock light will flash constantly when are locked,it don't matter how i lock the doors eg. key fob,front doors or rear door. i have verified that all doors are locked and the car beeps once when i lock the doors. how can i turn the door lock light off,permantly if need be.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    201
    If your talking about the flashing light on the dash, it's normal. It indicates that the engine immobilizer is active, and is essentially a warning to a potential thief.
  3. Old Smokey
    23
    thornhill on
    thank you for the responce,you are absoulutly correct.you have set my mind at ease.
Loading...
