door lock not working
Discussion in 'Gen 2 Prius Technical Discussion' started by dj80d6, Feb 15, 2017.
  1. dj80d6
    dj80d6 New Member
    sacramento
    when i looked for fuses it only had one and that was #11 and it was fine.
    52,803
    it's baffling. i don't recall anyone having a one way problem before. i hesitate to say it's a bad circuit board, but maybe there are separate receivers or transmitters.
  3. dj80d6
    dj80d6 New Member
    sacramento
    well i bought it used and he said it hasn't worked for a while. also i only have one fob. and all the research i have done is the same they don't have one way problems like this.
    52,803
    how good are your diy capabilities?
  5. dj80d6
    dj80d6 New Member
    sacramento
    not to bad if i have the time and tools
  6. bisco
    52,803
    it's probably overkill, but mini vci and a service manual would probably do it. but maybe you should pull the door panels first and have a look around.
  7. Abdulrehman2002
    Abdulrehman2002 New Member
    Japan
    I have prius of 2011, i changed my navigation system, after that it has not locking or unlocking even from inside of the vehical! Not from the key too! Fuses are all good: can anyone help me?
  8. dolj
    dolj Senior Member
    8,634
    4,388
    Wellington, New Zealand
    Your car is a Gen 3 and you have posted in a Gen 2 forum.
    Maybe ask your question in one of the Gen 3 forums.
