Door Panel Removal, Front Door Speaker Removal With Pictures
Discussion in 'Gen 3 Prius Audio and Electronics' started by bxzcd, Apr 4, 2011.
  1. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
  2. bxzcd
    bxzcd Junior Member
    22
    Earth
    The set that Crutchfield sent me didn't seem to fit very well on the 5.25", and there was a lot of airspace around the speaker, which, could be fixed with a baffle I suppose? (I've never used plastic adapters actually)
    I had to make custom adapters when I installed speakers on my last car, so when the adapter they sent me seemed kindof iffy to me, I figured I could just make a decent pair in an afternoon. I think they should be fine for a while though. If they go bad, I'll fix them.
  3. bxzcd
    bxzcd Junior Member
    22
    Earth
    Danvee...THANK YOU!
    Before:
    After:
    2 people like this.
  4. danvee
    danvee Blizzard Brigadier
    326
    53
    38
    New Jersey
    Glad I could help!:D
    For interest sake: what did you end up doing?
  5. Launch Vehicle
    Launch Vehicle Junior Member
    82
    Missouri
    WOW - the power of heat!
  6. bxzcd
    bxzcd Junior Member
    22
    Earth
    I pushed the blemish back in by hand, and then I found a hairdryer and basically just heated that little area up. It was a surprisingly easy fix.
  7. danvee
    326
    53
    38
    New Jersey
    Thanks for that! I kinda figured that it would work, but surprised that a hair dryer was enough heat. I guess that the plastic is softer than I thought.
    That's an old installers' trick. When we would bend some ABS plastic for installs you would get the same whitening, and a heat gun fixed it right up.
  8. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    I put these in - but would've preferred wood ( was late, so I went with what I had).
    These are VERY thin and flimsy. Not ideal for something that's going to move a lot (bass).
    That said, they're easy to install and use...
  9. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    That was nice work. But the reason it heats so easily is that it's thin and easy to overheat so be careful.:eek:
    BTW, the marking on the plastic is PP/PE which is polypropylene/polyethylene. It's not hard to melt and nearly impossible to get a structural glue joint to work with products available to the consumer.
  10. danvee
    326
    53
    38
    New Jersey
    I guess that there is a solvent-based adhesive that would work to "weld" this material.
    I know that I've seen dealers do a repair of a hole or cigarette burn in this type of plastic using a mini "iron" and filler along with a textured "graining" sheet.
    Sort of like one would do with a vinyl repair kit.
    Plastics are soooo much fun.....:rolleyes:
  11. zrtmatos
    zrtmatos New Member
    Connecticut
    very good write up and pics on speaker install. what kind of speakers did you end up with?
  12. mee081224
    mee081224 New Member
    193
    Tampa, Florida
    nice write up
  13. shafi10a
    shafi10a Junior Member
    brooklyn
    very well written. Can someone tell me how i can splice into the speaker wires with audio cables connecting to my bazooka subs?
  14. mee081224
    193
    Tampa, Florida
    wait, you want to connect your bazooka to the wires connecting to your door speakers?
    You def do not want to do that, you will want an amp for that sub. you will need rca cables & remote turn on cable to your head dead, and then power to the battery and ground it anywhere on the chassis. then connect speaker wire from amp to sub
  15. xamnosidda
    xamnosidda Junior Member
    61
    Celebration, FL
    I thought Bazooka subs were self powered...
  16. mee081224
    193
    Tampa, Florida
    You still need power to them, it wont be as easy as cutting into the wiring. If you put a new head unit, the ghetto way would be to get the wiring hooked up at the head unit level and not at the door.
  17. txl146
    txl146 Member
    301
    NY
    Newbie question - front speaker looks like 6x9"; why do people install 6.5" speaker in that spot? Crutchfield seems to list only 6.5" or smaller sizes for front opening; any idea why 6x9" speaker is not listed?
    Thanks!
  18. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    225
    Harrisburg, PA
    I think it's because the weird Toyota plastic 6x9's use non-standard mounting holes, even for a 6x9. And the adapter brackets from Crutchfield are for putting 6.5" in the factory opening.
  19. shawnsprius
    shawnsprius Junior Member
    84
    South East
    eeeeks I cringed when I saw MDF going in a door in a car.. dip that MDF in water for 1 second and let me know what you have....
    not a good material for a car door... :(
  20. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I'm hoping that the peel-and-seal he used will keep the water away. I might have coated it with at least some poly-resin, or made a thick fiberglass adapter panel, and used screws with nylocs to mount the speakers.
