Door replacement
Discussion in 'Gen 3 Prius Main Forum' started by marquis1366, Mar 25, 2021.
  1. marquis1366
    marquis1366 New Member
    houston tx
    Does anyone know how to replace the front passenger door. Not the panel but the actual door.
    52,757
    that looks like a big job, you might want to consult the service manual. i have to think more is bent than the door.
  3. PriusCamper
    PriusCamper Senior Member
    13,386
    5,409
    Pacific Northwest, USA
    Door bolts on at the hinges... There's also some wires you need to unplug. Very simple to remove...
  4. marquis1366
    houston tx
    Great I just order a whole new door and if it’s only hinges and wires seems pretty straight forward. But will have to change the door panel
    PriusCamper likes this.
  5. BZzap!
    BZzap! Senior Member
    1,607
    878
    As long as the “A” and “B” are not sprung, the door is pretty straight forward to change. The wiring at the door flex requires a little disassembly of some of the kick panels for access to the electrical connectors.
  6. Mendel Leisk
    42,243
    Your info says 2nd gen, but this is in fact 3rd gen? Do you have collision insurance?
    There could well be more to it; a simple door swap might not be all you need. A competent body shop will check the hinges, frame and so on. Also they can repaint using seamless blending technique.
    Yeah I’d second that, suspect a less tightly cropped pic would reveal “collateral damage”, the front fender end (what little shows) appears to be a little impacted, and the door frame, hinges??
