door sensor auto lock delay
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Bigboi, Nov 2, 2016.
  1. Bigboi
    Bigboi Member
    136
    26
    Las Vegas
    2015 Prius c
    every time i park my car somewhere, i exit my 2015 Prius C 3 and try to lock the car by pressing on the two lines on the handle and it takes between 6-25 seconds before it locks. this sensor was working fine for the past 11 months but now there is a delay in locking, usually locks after the courtesy dome lights turn off. any ideas on how i can fix this?
  2. Mendel Leisk
    42,239
    On our regular Prius there's some mention (in the Owner's Manual) to pinch the handle, ie: have fingers above and below the handle. There's sensors above and below, maybe yours is similar? Take a look if there's two lines also on the underside. Might help.
  3. Bigboi
    Bigboi Member
    136
    26
    Las Vegas
    2015 Prius c
    Hey thanks for the suggestion Mendel, my car does not have any sensors above or below. I tried switching fobs with no success, still a delay where no delay existed before... Shall I warranty it?
  4. Mendel Leisk
    42,239
    Maybe my language is confusing? You have the "two lines" on top of the handle; is there a similar pair of lines on underside of handle?
  5. Bigboi
    Bigboi Member
    136
    26
    Las Vegas
    2015 Prius c
    Oh yeah the two lines are actually lateral on the door handle. No lines exist superior or inferior of the handle :(
  6. Bigboi
    Bigboi Member
    136
    26
    Las Vegas
    2015 Prius c
    I called the dealer and have an appointing to check out the problem on Tuesday will let you know what happen!
  7. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    If your car has the auto lock feature (30 seconds after exiting), I suspect that the sensor on the handle are not functioning and it is the auto lock that is locking the door.
    Bigboi likes this.
  8. Bigboi
    Bigboi Member
    136
    26
    Las Vegas
    2015 Prius c
    Oh I did notice that option so I turn it off and car still wouldn't locking when touching the sensor until after 20-30 seconds of standing there and pressing the sensor I look at my key fob and it lights up red each time I touch it this delay is crazy
  9. Bigboi
    Bigboi Member
    136
    26
    Las Vegas
    2015 Prius c
    By the way I notice I can usually lock by touching the sensor until after the middle info screen turns off on the dashboard (next to the mph screen) after turning off the car...
  10. Bigboi
    Bigboi Member
    136
    26
    Las Vegas
    2015 Prius c
    The dealership saif nothing was wrong but I told them when I bought it new it could lock immediately after leaving the vehicle via door sensor or key fob and now I have to wait until the info screen turns off. They said other Prius C's did that.
    Please tell me if your Prius C also needs to wait until it powers off completely before you can lock it via door sensor or key fob? I wish it was like the good old days of immediate locking after exiting my baby :(
  11. DonDNH
    1,711
    655
    Nashua, NH
    Four Touring
    Perhaps a call to Toyota to report the issue and see if there is a known remedy that your dealer is unaware of.
    Bigboi likes this.
  12. Bigboi
    Bigboi Member
    136
    26
    Las Vegas
    2015 Prius c
    I will definitely call them and see what is going on. It's crazy to think that it's okay to have to wait next to my Prius C for 20 seconds before I can lock it. Oh man
  13. Bigboi
    Bigboi Member
    136
    26
    Las Vegas
    2015 Prius c
    I called Toyota and they said no recall on having to wait 20 seconds to lock the door via key fob and via door sensor. They said if the dealer says it's normal then it's normal for me to not be able to lock the door immediately with my key fob and sensor when for a whole year I was able to lock the doors immediately. I don't know what's going on.
    Can you tell me if you are able to lock your door immediately after turning off your car via key fob or door sensor?
  14. PaperbagPanda
    PaperbagPanda New Member
    Houston
    2015 Prius c
    Did you ever find a solution for this? This is happening to me.
  15. TheTimob
    TheTimob Member
    120
    79
    Divide, CO
    This is a strange problem and I'm sure it's very annoying. My suggestion would be to throughly clean both front door handles, on the top and bottom of the handle. Contamination like tree sap or dirt could be causing phantom inputs to the touch sensors for lock/unlock.
    Make sure that the lock and unlock button on the hatch both work. One could be stuck.
  16. PaperbagPanda
    Houston
    2015 Prius c
    They all work fine. Its very random. Sometime it locks right away, sometimes I gotta wait a long while.
  17. bisco
    52,754
    ask the dealer to show you how a new one works, i bet it's instantaneous.
  18. PaperbagPanda
    Houston
    2015 Prius c
    Finally got the dealer to figure out that the sensor is experiencing intermittent issues.
    TheTimob and bisco like this.
  19. bisco
    52,754
    great news, all the best!(y)
  20. PaperbagPanda
    Houston
    2015 Prius c
    They changed out the sensor I believe but the issue is still occurring... Not sure if they did it in the first place. Will need to bring it back.
