Door Status on CAN
Discussion in 'Gen 3 Prius Technical Discussion' started by ErikJ, May 21, 2018.
Tags:
  1. ErikJ
    ErikJ New Member
    23
    Palo Alto, CA
    2015 Prius Plug-in
    Hi all,
    I am currently working on a project for my Prius and I need to be able to know the door and window status over CAN. I have found the window status on message ID 0x638, data byte 4 (2 bits per window), but I can't seem to locate the door status. I have found a bit in message 0x626 that appears to indicate the status of either the dome light or the door indicator on the dash, however I would love to know the status of each door individually. Does anyone know if that is available or will I need to do more reverse engineering?
    Thanks!
    Erik
    PS. ID 0x638 also appears to contain the lock status and hatch button state on bytes 2 and 6, if this is useful to anyone!
  2. ErikJ
    ErikJ New Member
    23
    Palo Alto, CA
    2015 Prius Plug-in
    For the curious, here's how to decode the door lock and window status:
    Code:
    def windowStatus(data, window):
        status = (data >> (2 * window)) & 0x03
        if status == 1:
            return "Fully Open"
        if status == 2:
            return "Closed"
        if status == 3:
            return "Partially Open"
        return "N/A"
    Code:
    if msg.arbitration_id == 0x638:
        if msg.data[1] & 0x80:
            print("Driver Door:       " + ("Unlocked" if msg.data[2] & 0x10 else "Locked"))
            print("Passenger Door:    " + ("Unlocked" if msg.data[2] & 0x08 else "Locked"))
            print("Rear Doors:        " + ("Unlocked" if msg.data[2] & 0x06 else "Locked"))
            print("Hatch:             " + ("Unlocked" if msg.data[2] & 0x01 else "Locked"))
            print("Hatch Button:      " + ("Pressed" if msg.data[6] & 0x40 else "Released"))
            print("Driver Window:     " + windowStatus(msg.data[4], 3))
            print("Passenger Window:  " + windowStatus(msg.data[4], 2))
            print("Right Rear Window: " + windowStatus(msg.data[4], 1))
            print("Left Rear Window:  " + windowStatus(msg.data[4], 0))
    Buzzhead likes this.
  3. RobH
    RobH Senior Member
    2,359
    954
    69
    Sunnyvale, California
    Check the wiring diagram to see if the door switches are separately connected to an ECU. I suspect that they are all on one connection. My wife's CT200h displays which door is open, while my Gen2 Prius only displays that a door is open.
  4. taxibuddy
    taxibuddy Junior Member
    76
    Atlanta
    2014 Prius v wagon
    Maybe this is overly picky but your code returns inaccurate information if one rear door is locked and the other isn't.
  5. ErikJ
    ErikJ New Member
    23
    Palo Alto, CA
    2015 Prius Plug-in
    Hi @taxibuddy - unfortunately, the two rear doors appear to be connected in a "logical-AND" configuration - if either is unlocked, the status bits show 'unlocked' for both. I am expecting the same for the 'door-open' status, as there is only 1 wire going to the ECU for both rear doors in the wiring diagram.
  6. ErikJ
    ErikJ New Member
    23
    Palo Alto, CA
    2015 Prius Plug-in
    @RobH: The wiring diagram shows that there are inputs for the following "courtesy switches":
    - Front Left
    - Front Right
    - Rear (both in parallel)
    - Hatch
    - Hood
    I think it should be possible, therefore, to read these on the CAN bus...
  7. ErikJ
    ErikJ New Member
    23
    Palo Alto, CA
    2015 Prius Plug-in
    Got it! It was sharing the same message as the parking brake, which I had already filtered out and is why I couldn't find it...
    For future reference:
    Code:
    if msg.arbitration_id == 0x620:
            print("Driver Door:       " + ("Open" if msg.data[5] & 0x20 else "Closed"))
            print("Passenger Door:    " + ("Open" if msg.data[5] & 0x10 else "Closed"))
            print("Rear Doors:        " + ("Open" if msg.data[5] & 0x0c else "Closed"))
            print("Hatch:             " + ("Open" if msg.data[5] & 0x02 else "Closed"))
            print("Parking Brake:     " + ("On" if msg.data[7] & 0x10 else "Off"))
    Still no sign of the hood status (even on that message), but I don't need that anyway.
    RobH likes this.
Loading...
