Door touch sensor woes
Discussion in 'Gen 3 Prius Main Forum' started by Miyamoto, Dec 16, 2017.
  1. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Thanks to those who posted the two finger squeeze technique. I knew about that, but forgot over the years of being lazy and just touching the top. Works much more reliably when wearing heavy gloves (and we're doing that at temps. of -20C and below, below 0F for those metrically challenged ;) ).
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    About 4° below 0 F to be precise. At -40 they are the same.
    I didn't know about the top-bottom technique till I saw it in the manual when looking up info on this issue.
  3. Tideland Prius
    16,680
    Palming the face of the handle near the sensors also works as a last resort.
    jerrymildred likes this.
  4. Prodigyplace
    12,712
    11,848
    Central Virginia
    Interesting. On Gen 4 they moved the lock sensor to the vertical surface of the handle. That would make it easier to "palm".
    Tideland Prius likes this.
  5. Mendel Leisk
    42,343
    But if you push on the face of the handle, also triggers locking I guess? I know, usually good, but I prefer to leave the car unlocked in our secure garage, thinking less wear-and-tear on all 5 lock mechanisms.
  6. David Beale
    5,963
    1,990
    Edmonton Alberta
    I leave Pearl S unlocked in the garage because if some moron breaks in they won't have to smash a $500 window to steal $10 worth of "stuff".
    My garage seems to be "secure", as there have been at least one attempt at breakin every two years. All without success.
    jerrymildred and Mendel Leisk like this.
  7. Tideland Prius
    16,680
    Not sure. Haven't tried.
    Lock mechanisms should be ok. Mine is set to global unlock so all door locks have been locking and unlocking every time I unlock the car and on shift in/out of Park. Only for a short period have I had it set to the default Driver-only so it's been this way for the better part of 7 years (assuming the default was used for a total of 1.5 years)
  8. Prodigyplace
    12,712
    11,848
    Central Virginia
    There is a small spot much like Gen 3 but on the face instead of the top.
