Door unlocking options
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by IwasBirchyFirst, Sep 17, 2025.
  1. IwasBirchyFirst
    IwasBirchyFirst Junior Member
    27
    Dallas, TX
    I have two 2010 models. On one, with key fob in my pocket, I can unlock the front passenger door and hatch, but on the other car, I can only do that with the driver's door and then have to manually unlock the whole car. Yes, I could fish the fob out of my pocket, but I have a lot of other things in that pocket.
    My question is: is the different behaviors based on hardware or programming? If the later, I'll dig out TechStream and change the programming.
  2. Mendel Leisk
    42,379
    What level are the 2 cars? Toyota’s always limited multi-door unlock with a touch to the upper levels, with the base level restricted to drivers door only.
    too, with the upper levels, there’s an owner-programable setting, to alternate between drivers door only and all doors. IIRC you can press-and-hold lock and unlock fob buttons, till dash beeps and displays an icon, showing a car with all doors ajar, or single door. Each time it alternates.
    it’s explained in owners manual, somewhere.
    if you google:
    3rd gen prius touch to unlock priuschat
    the AI overview explains too, but I’d check against the manual.
    there’s various priuschat threads on it, one example.
    #2 Mendel Leisk, Sep 17, 2025
  3. CR94
    CR94 Senior Member
    2,840
    1,246
    Northwestern S.C.
    ?? Using the method described in the manual, I set my low-level 2011 to unlock all doors with a double-press of the fob button or touching the exterior driver's door handle..
