Doors don't like to hold position when open
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by btse6, Oct 16, 2012.
  1. btse6
    btse6 Junior Member
    Pacific Northwest
    The little device that helps hold doors open (so they don’t swing freely) aren’t very effective on my ’09 model. Actually, it's only a problem on the front doors. The rear doors hold position quite well. The front doors have always been a problem and I wonder if is this typical. Is there a fix (other than replacement)?
    Thanks,
    Tom
  2. pjc
    pjc Member
    139
    46
    Bloomington, MN
    I have the same experience with my '09. If I'm on any sort of an incline in the wrong direction, the doors swing shut on me.
    In my last car (a Volvo wagon), I had the little mechanism break that does this, and it was fixable -- pretty expensive, though.
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I thought it was just mine. Personally I'd rather the wear slack that wear tight like some.
  4. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Same problem on my 2008.
  5. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    I thought it was just me. I guess it is the car after all.
  6. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    That's the way the car is designed. You can swap the hinges with other makes that have larger "detents" in them. Remember this makes the door less smooth when it opens and if you want it open to a setting other than the detent, it is hard.
  7. btse6
    btse6 Junior Member
    Pacific Northwest
    Hmmm. Maybe I'll try swapping the ones from the front and rear doors (if they look like the same dimensions, etc.)
  8. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    I did this this weekend. I noticed today exciting the car it no longer closed automatically
    The hold open tensioner is the same on all four doors.
    iPhone ?
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    never lubricated. Wear out.
    Paul Schenck likes this.
  10. Paul Schenck
    524
    307
    Fresno, California
    You’re right Ed, I never did though it seems they’re made of a graphite composite. Self lubricating?
    iPhone ?
  11. edthefox5
    10,096
    4,837
    Clearwater, Florida
    I just use CSP spray grease on everything that moves on my cars and house. have fantastic results. No smell either.
  12. George W
    George W Senior Member
    939
    520
    San Antonio
    Is it difficult to change those? Are they new, or new 'old stock'? Thanksl
  13. edthefox5
    10,096
    4,837
    Clearwater, Florida
    I think very easy outside bolts on the jamb if I'm not incorrect. Paul?
  14. Paul Schenck
    524
    307
    Fresno, California
    Once you remove the door panel you can get to them by cutting the vapor barrier and reaching it from there. Or you could do as I did and time it to when you wanted to replace the speaker and use that opening
    iPhone ? View attachment 181779
    #14 Paul Schenck, Nov 14, 2019
  15. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Or just peel the barrier open partially from its glue. Glue stays tacky so you can just press is back afterwords. Barrier is there for a reason so don't just cut it. Or if you did cut it at least fix it.
    Paul Schenck and George W like this.
