Doors won't unlock with fob or mechanical key
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MJTenn, Aug 22, 2023.
  1. Danno5060
    Danno5060 Active Member
    386
    199
    Wyoming
    If you can get the hood unlocked somehow (getting to the cable by removing the plastic panels under the front bumper cover, maybe tilting the front bumper cover up by popping out the sides you can get to the 12V battery terminal inside the fuse box with a charger. If your charger is like mine (6 amp), the accessory battery will probably be pulling too much of a load for a while, but eventually you'll be able to use your fob.
  2. Patrick Perry
    Patrick Perry Junior Member
    Salt Lake City
    Open the rear hatch
    Charge or jump the battery on the back passenger side
    51,838
    how do you open the hatch if you can't get into the car?
