Dorman Battery Experiences
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Surly, Feb 11, 2014.
  1. Surly
    Surly Junior Member
    Omaha, NE
    I have all the symptoms of needing to replace the hybrid battery, P0A80, P3022, warning lights, cooling fan, fully charged battery all the time. Northern Auto Parts are selling Dorman remanufactured batteries for $1500.
    Was looking for folks experience with the Dorman batteries and Northern Auto Parts. Was attracted to Dorman for their 3 year warranty. I plan on doing the install myself.
    P.S. - I attempted searching but keep getting prius chat error message when searching "Dorman" in this sub forum.
    Yakoma likes this.
  2. usnavystgc
    3,159
    989
    Tucson, AZ
    Well Dorman is a nationwide auto parts distributor. They have been around and are a reputable company. They purchased the company formerly known as "ReInvolt" then started selling the batteries thru Auto Parts stores. I don't see them going out of business anytime soon so their warranty should be a good selling point for you.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Try searching for ReInvolt. That is where you will find a majority of the remanufactured battery threads.
  4. dpeverhart
    dpeverhart Member
    126
    23
    I
    If you use Northern Auto Parts make sure you search for and use a coupon code. You should be able to get 10% off your order. I did when I bought a hybrid battery from them.
    usnavystgc likes this.
  5. Surly
    Surly Junior Member
    Omaha, NE
    dpeverhart
    Thanks so much for that suggestion, I was able to find a use a 10% off code.
    How long have you had your Dorman battery installed now, any problems? One of my concerns from ordering it from Northern Auto Parts is that it would arrive without a fresh charge if it was picked off the shelf; this should be a non issue if it hasn't been sitter there for years. Hoping they drop ship it from Dorman, then I should likely receive a freshly charged one.
  6. dpeverhart
    dpeverhart Member
    126
    23
    I
    I should be receiving mine later this week so I can't offer any other input. The warranty is great (3 years) and the price was right!
  7. Surly
    Surly Junior Member
    Omaha, NE
    Appears my battery drop shipped from Dorman, received it one week after placing the order with Norther Auto Parts.
    Unfortunately I may have received a bad battery. After installing and a succesful test ride, about 5 miles city & highway, I finished putting the interior together the next day and had the warning lights come on and throwing a P0A80 fault code. Cleared the code and ran a quick errand with the car and it came back on. Battery display shows that it starts off with 1 to 2 bars then quickly goes to full charge. I'm going to go through Dorman's warranty checklist, double checking auxillary battery voltage, disconnect plug, etc... I'm hoping another fault code pops up if everything checks out okay, otherwise Dorman's literature states my problem is not covered under warranty. I'll be contacting Dorman for help if that's the case. I'll post a follow up.
  8. uart
    uart Senior Member
    4,215
    1,200
    Australia
    That's a bit worrying. Another member here recently had a bad reinvolt battery too. From memory his problem sounded similar to yours, SOC would drop to pink very readily at start up and then reach high SOC fairly rapidly too. His wasn't bad enough to throw a code for quite a while, but fortunately it eventually did and he got it replaced under warranty.
    I'll try to search for the thread and post a link.
    Edit: Here's a link to a reinvolt/doorman user who had similar problems. Watch my commute.. is this normal? | Page 3 | PriusChat
  9. usnavystgc
    3,159
    989
    Tucson, AZ
    Yes this is very disturbing. Can you post the literature that says this won't be covered under warranty? I can't understand why if only a p0A80 pops up, the warranty doesn't cover it. Plus I want to know if they aren't backing up their product.
    Uart,
    I thought about the exact same post when I read this.
  10. Surly
    Surly Junior Member
    Omaha, NE
    I have copied the "TOYOTA GEN2 PRIUS WARRANTY RETURN CHECKLIST" from Dorman's Hybrid Battery website, which is the same checklist I received with my battery. My aux. battery tested at 12.0 volts, I have it on a trickle charger now to bring it up to full capacity. Disconnect was properly installed and codes have been cleared. Going to start driving the car again and call Dorman support sometime this week to get their input. I'll post a follow up later this week.
    1. Check 12v battery under load. Vehicle requires 11.2v during starting to properly power all computers.
    2. Check to make sure Orange safety disconnect handle is in the locked position. The locked position requires 3 steps. A. Insert into holder. B. Flip handle up to vertical position. C. Push straight down until handle clicks into locked position
    3. Check trouble codes and clear to make sure they are not stored from previous battery.
    4. Trouble codes P3011-P3024 are battery failure codes and warrant return.
    5. Trouble code P3006 without the above codes requires the Delta SOC PID from the data stream. If the Delta SOC is below 21%, the issue is not battery related, but could be caused by a failed 12v battery.
    6. Trouble code P3009 has to be set during key on/not ready to be battery related. Check by connecting scan tool, Press start button without foot on brake to where instrument panel lights up, but there is no ready light. Clear codes and wait 30 seconds. If code does not reset in this mode, the P3009 is not related to the HV battery.
    gdanner likes this.
  11. hybriddriveguy
    98
    63
    Sanford NC
    As the founder of Re-Involt Technologies and now Hybrid Product manager with Dorman Products, I will be happy to address any concerns with either product. My email is: [email protected].
    Re-Involt, although a relatively small company, had a policy of taking care of our customers. Dorman has made numerous improvements in our product since taking over and doubled the warranty we offered.
    I can say that Dorman's policy is and always has been to take care of the customer. Regarding how long our batteries sit on the shelf at a distributor location, we have an automatic 6 month return date in place and most are shipped out when ordered.
    One of the exciting things about my position with Dorman is the ability to make improvements on failed OE designed parts and offer a strong warranty to back it up. The batteries hold true to this.
    As will be true with any product, there will be defects along the way. These are sometimes caused by manufacturing defects, shipping damage, installer error or as we see quite often, there was a failed initial diagnostic and our battery was returned with no problems at all. In every case, the customer has gotten either a replacement or a full refund.
    We have included both instructional videos and trouble shooting tips on our website to help anyone installing one of our batteries to be both safe and to do the job correctly. Dorman Hybrid Drive Batteries
    Again, if anyone ever has any issues with Dorman batteries or any other hybrid specific part that we produce, they can email me at [email protected].
  12. usnavystgc
    3,159
    989
    Tucson, AZ
    David,
    In the situation detailed above by Surly, is it covered under waranty? Is it true that if a p0A80 is the only fault code, this does not merit waranty coverage? I'm just trying to figure it out. Is there anything else that could pop up a p0A80 besides the battery?
    Btw, I appreciate all you have done both with ReInvolt and now.
  13. hybriddriveguy
    98
    63
    Sanford NC
    The P0A80 is pretty generic in that we have seen it set by a low 12v as well as several other issues. We have had numerous customers get this code after the ICE failed to start due to a dirty throttle body and drained the HV battery almost dead. Our goal is to make it easier on the customer, no matter what and sometimes, replacing a battery without digging a little deeper only wastes everyone's time.
    In the end, if we could not help the customer resolve the issue and they still felt it was the battery, we would replace it at no charge and just assume there could actually be something with the battery that we were missing.
    Once that unit got back to our NC facility, it would go through rigorous testing both in and out of a car to make sure we are constantly improving the product. If we do not find any defects, the battery gets torn down and sent back through production to make sure nothing is missed.
    To date, Dorman has not denied a warranty claim on any hybrid battery.
  14. we9to4
    we9to4 New Member
    Phx, AZ
    Just this year I lost my Traction Battery. I had a junk yard one for $900 or went back to the Dealer Online for $1900+ install, Each would only give 1 year written warranty. Not the 10 year Dealer in past. Though Service Writer said if it went over a year they might still replace, Bring it back an ask. One thing, I chose Dealer because it was all new cells.
    What about shelf life Battery Storage, I bought a wreck that stopped charging in April, and it will take another month or two before I get it running?
  15. bisco
    49,371
    a month or two is nothing. i leave mine for a month or two every winter for ten years, no problem.
  16. we9to4
    we9to4 New Member
    Phx, AZ
    A Reply from: hybriddriveguy - [email protected].
    Dorman places a conservative 6 month shelf life on our batteries currently. Toyota has a 12 month shelf life.
    I believe with all the data we have acquired, you should be safe going 12 months as long as the battery was charged prior to storage.
    Purchasing a battery from salvage, makes it next to impossible to know the state of charge when received.
    On the 2011, if the engine fails to start several times, the battery can easily get discharged to the point of failure.
    If you plan to keep these batteries long term, store them in a climate controlled area and invest in a grid charger.
    Thanks,
    David
    Thanks a great help to me. This is AZ hot sun country...We just Fryin Eggs on the sidewalk !
  17. Surly
    Surly Junior Member
    Omaha, NE
    UPDATE:
    Okay, so I never did contact Dorman (reference post #10 in this thread) because my warning lights stopped coming on until last week (about 5000 miles and 7 months since remanufactured battery was installed). I'm now receiving the P0A80 fault code again and the battery will quickly discharge and recharge. Example: After the car has set for a week my wife started it up, ICE started as usual and continued while we observed the battery go from 6 bars to 1 bar before leaving the drive way; by the time she went down a short hill and along a flat road for 1 mile, the battery was up to 8 bars (full capacity). David Taylor had kindly sent me a personal message back in April 2014 when I first posted about my concerns (post #10) with a Dorman remanufactured battery I had installed in my 2006 Prius. The message contained a direct line to a manager at Dorman, whom I have called and left a voice mail with at this time. After reading David Taylor's post, I feel confident that Dorman will come through on the matter. I'll try and post updates as this process continues.
  18. JC91006
    16,474
    8,393
    I'm glad to hear about the great customer care you are getting from Dorman. But this is one of the main reasons that people should be cautious about rebuilt batteries. They will have a longer warranty than original Toyota products but they will not last as long. If the money you're spending is going to be close to the same amount is a New battery, the smart money would be to purchase new with the 1 year warranty from Toyota. With a great company like Dorman, you should have no issues with warranty claims. However with smaller rebuilders, you may run into issues when the warranty claim is necessary (with a rebuilt, it will be necessary).
  19. Hollywood Cole
    Hollywood Cole Junior Member
    25
    Alabama
    I can tell you guys one thing... Don't EVER buy an HV battery from Rockauto.com
    Early this year, I bought a Dorman replacement HV battery for my 2006 from there since they had the lowest price I had seen, but I had trouble codes out of it within about 3 months: bad cells. It was an inconvenience, but I understand things happen and I have a great 3 year warranty that will take care of me, right? No. Dorman said to contact Rockauto, Rockauto said it was Dorman's issue, back and forth literally over and over waiting on hold each time for a CSR. After about 3 days of this BS I finally got pissed and started recording the conversations and advising the reps that they were being recorded because I was being given the runaround. Finally then the Rockauto people decide it was their problem, however they don't have any replacements in stock, and HAVE NO IDEA WHEN THEY WILL HAVE A REPLACEMENT. They said they would not special order one for my warranty exchange and it could be months for me without a car to drive. I had to call multiple times asking for managers (which they all said they "were the manager") and telling them this was about to be a legal issue of not honoring their warranty in a timely and reasonable fashion, finally I got a helpful person (out of probably 20 people there, ONE woman was nice and helpful) who told me I would have to purchase another one and then just return the first. I had to put up an additional $1800 but it was worth getting my vehicle fixed so I could go to work.
    Here we are 6 months later, and new problems with the replacement. Now I am getting fault code P0AFA - Low Voltage, which the Toyota Service Bulletin 0166-09 indicates is likely a bad HV battery ECU.
    Called Rockauto and they are playing the EXACT same game. "you need to contact Dorman, that's not a valid code." Yes it is, it is listed in the TSB, and it has returned 3 times to my fault codes almost immediately after being cleared each time.
    Dorman may be a good company, but Rockauto is NOT. I have made many purchases there because their prices were the best, but their customer service on big ticket items is zilch, so stick to gaskets and oil filters if you order from them. I am really hoping Dorman will step in and make this right since Rockauto is so incompetent.
    Sorry for the rant, but this is taking years off of my life and I hope to save others the trouble.
  20. JC91006
    16,474
    8,393
    I have read of many failures in the Dorman batteries. I don't think they are as good as before. Actually many rebuilts have problems. Best to go new and not rebuilt
