Dorman HV Battery with a new lease on life.....
Discussion in 'Gen 2 Prius Main Forum' started by TMR-JWAP, Jun 8, 2019.
  1. bisco
    51,935
    we have a lot of deer, but i don't encourage them because of lyme disease
    edthefox5 likes this.
  2. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    Since I’m ignorant when it comes to the capacity and percentage, I’m going to ask a question.
    What percentage of capacity is considered “acceptable”, and what percentage do you aim for when doing a recondition, if that number is different?
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    I don't believe there's a set value out there. Since each module has 6 individual cells, it's more important that the 6 cells are fairly well balanced, and then that all 28 modules are well balanced with each other. A module with 5 strong cells and one weak cell can still provide ~5400 mAh, but's it's voltage would drop to ~ 6.4 very quickly when the weak cell drops out. If you're able to monitor a modules voltage curve while discharging, you'd be able to immediately identify any with a weak cell.
    For me, I think any module that shows 5800 mAh or better during discharge testing should be a good module. That's just a bit under 90% of rated capacity. Anything under that bears more evaluation to ensure a cell isn't dropping out.
    A Prius will function normally even if the modules all tested at 2000mAh, as long as all 6 internal cells in each module are functioning equally.
    Using modules from 2015-current year eliminates most of the worry about having a bad module sneak into a customers battery. A few quick charge/discharge cycles to test and document capacities is all that's needed.
  4. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    So if I’m doing a recondition, and the numbers stabilize and I’m happy with them, then install it and go?
  5. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    I would say for a well balanced battery I would want all the modules to fall within a certain band for capacity.
    Let's say you tested/cycled all the modules and removed two weak ones. The remaining modules average 5600 mAh. I think for a DIYer, with the goal of having the car back on the road at reasonable cost, with reasonable reliability, I would have a band of 5200-6000 that I would prefer to see all 28 modules fall into. The further you can stay away from the bottom of the band, the better off you'll be. I think that would keep the delta V at a reasonable value during heavy discharges. If the band is too wide, you run the chance of the strong modules holding a high voltage while the weaker modules drop to a lower voltage, increasing the chances of tripping the RTOD.
    The tighter the band, the more balanced the battery will be. A better balanced battery will have a smaller deviation between the highest and lowest module voltage during discharges and charges.
    If you look at the results from the battery in this thread, the average was 6891 mAh. Highest was 7117 and lowest was 6655. That's a band of only 462 between highest and lowest. Essentially the average plus or minus ~3.4%.
    #25 TMR-JWAP, Jun 8, 2019
    happyinscotland and SFO like this.
  6. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
  7. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    You're right about doing it right, and the passion thing.
    Employees taking ownership, and a bit of passion/interest, just makes the difference.
    James1964 likes this.
  8. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Can such a curve above be provided by a Toyota techstream?
  9. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    What exactly is this soldering the lugs thing and how does one do it?
  10. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    Look at the heavy gauge orange cables. Where they attach to the module, there is a lug crimped onto the copper cable. On an OEM cable, there tends to be a bit of corrosion buildup on the copper wire. Apparently Dorman lays on a layer of solder to seal this up, and then puts a layer of heat shrink over the area. It's no different than an electronics guy tinning a wire on a lug.
    To do this well requires a good technique, decent equipment and a good heat sink to protect the cable insulation. A typcal DIYer would end up putting a tremendous amount of heat into the lug and cable, most likely melting the insulation 2,3 or 4 inches up the cable. This is probably why they also install heat shrink on the area to cover any melted stuff.
    I'll look around to see if I have any photos of the lugs. If not, I'll get some photos next time I pull the cover off that battery.
    Skibob likes this.
  11. strawbrad
    953
    1,007
    Can you share the parameters of your conditioning cycles? I'm sure you have posted them somewhere but I could not find them in this thread.
  12. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    I have a bench setup with factory Gen 2 ductwork and HV cooling fan. All the modules are mounted in the oem clamps and baseplate and attached to the duct. The fan is driven by a Prolong harness.
    I do an initial discharge/charge at 1.5 amps (discharge to 5.8volts) and 2.0 amps charge to either 8200mAh max or default delta V detection. I do this to document the "as removed from car" condition of each module. This is followed by charge/discharge cycles as needed to establish actual capacity of the module. I do 2 cycles per day typically.
  13. strawbrad
    953
    1,007
    Are all the discharge cycles stopped at 5.8 volts?
  14. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    Yes. At that point, the module is essentially depleted and voltage is dropping fast.
  15. strawbrad
    953
    1,007
    I suggest that on your next pack you try adding a deep discharge. After the second discharge at 1.5 amps to 5.8 volts start another slow discharge at 400 mA to 3 volts. This is what Hybrid Automotive has been recommending for years.
    With the deep discharge you won't need nineteen cycles to achieve good results.
    Raytheeagle likes this.
  16. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    Without a doubt, 19 cycles is extreme. That is, by far, the most cycles I've ever done on a set of modules to find the point where more cycles make no significant difference. I'm normally in the "8" range, about 4 days, which is probably even more than really needed.
    What makes it tough to change my current sequence is the chargers I use are not fully "programmable" to change discharge or charge rates at specific voltages. I would have to set them to discharge down to 5.8v and then stop. Then when I get home from work, record the discharge data and then set them to discharge at 0.4 amps to a new voltage. Once they're done, record data again, then I would have to change them to charge mode. Once they were charged, start all over again. I would basically have to do every step manually and hope the timing matches up to my work/home schedule. The sequence I use right now was settled on after a bunch of test sequences trying to get the timing to match my work schedule. I wake up at 5 am, do my morning routine, record the cycle data and just press the start buttons to begin the next cycle right before I leave to go to work. I usually get home from work between 5 and 530pm and do the same thing. It ends up being almost a perfect 12 hr cycle for me. Each cycle usually ends within 1 to 1.5 hours of when I arrive to record data and start the next cycle. Allows plenty of time for the pack to fully cool before another cycle starts.
    The only thing I hate more than doing yard work is having to make adjustments on all 28 charger channels. :sick::sick: I've found that frequently making changes on 28 channels leads to errors being made on setpoints.
    The other option would be to set them up to perform the entire discharge at 0.4 amps, but that would again probably be a schedule thing as each discharge would be extremely time consuming. This was the big problem I had when using chargers rated for only 5 watts.
    One thing I have thought about trying is to perform a full 3 cycle sequence using the Prolong system I have, then using my 28 chargers to do additional cycles to get actual capacity measurements for each individual module. I would still end up doing multiple cycles with my chargers to determine if the modules were still improving. The only problem with this is that I won't have individual control of the modules for the first three days, like if I wanted to disable cycling an obvious bad module. And the three days of Prolong cycling would have been 6 cycles of my normal sequence, which would typically be near completion. I think I still want to try it though.
    On another note, has anyone figured out why Hybrid Automotive changed their voltage setpoints?
    A year or two ago, I received a brand new in the box Prolong Gen 2 Deluxe Package as partial trade for a battery job. The setpoints for the three cycles are 134v, 84v and 17 volts. Now the equipment they sell uses 192v, 120v and 24 volts. What gives on that? I wonder if maybe those earlier voltages are less healthy for the battery than the new ones? Wonder if they offer free upgrade/program changes to previous owners? The sad part is that I've been using this $$ system merely as a fan controller for my test bench. I need to put it to better use.
    strawbrad likes this.
  17. strawbrad
    953
    1,007
    I feel your pain about changing the settings on 28 chargers. It's not fun and you really want to be sure about the need to do it. What chargers are you using? Can you save different settings to memory?
  18. James1964
    James1964 Member
    177
    83
    Vashon Island, WA
    This whole thread is encouraging for those of us who got a "good deal" on their first Prius w/ a Dorman HV battery installed. We killed the first one and now have a direct from factory, warranty fulfilled (free replacement). It tested at 100% on the Dr Prius acceleration test (I know, I know) and car is running well, getting 45-48mpg. I'm considering finding a shop with the Prolong system and have this battery loved a bit. Can't hurt it appears. Great thread!
  19. Chris Temple
    Chris Temple Junior Member
    San Jose
    Appreciate you guys documenting this for others to follow. I am reconditioning a 2005 Gen 2 battery that was throwing all kinds of battery codes and triangles at me. I bought the car with 211k miles for my son, no experience with a Prius and then fell quickly into the world of battery problems and a desire to fix without spending a bunch on a car my teenager will likely destroy while learning to drive.
    Using 2 quad hobby chargers. Here are my results so far:
  20. Chris Temple
    San Jose
    What would your criteria be for deciding if a module should be replaced or left in the pack? 4500 mAH ? Should load testing be a factor also ? I am at the end stage of cycling and need to figure out how to decide when to replace, how to pair them and how to balance them before reassembly. Thoughts ?
