dors gen 3 inverter fluid bubble?
Discussion in 'Gen 3 Prius Technical Discussion' started by Darklandscape, Sep 12, 2022.
  1. Darklandscape
    Darklandscape Junior Member
    64
    I read that the gen 2 inverter fluid tank is supposed to bubble/simmer.
    Does the gen 3 do this too?
  2. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    honestly, I checked at least a dozen times & I never ever saw any movement of the fluid /
    techstream never showed any codes /
  3. Noahdoge
    Noahdoge Active Member
    219
    148
    Mississippi
    What you’re wanting to know starts at 14:10
    52,876
    can't see thecoolant movement, should see the coolant movement. that's a problem
