Dots on upper wind shield
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by The Craw, Oct 2, 2012.
  1. The Craw
    The Craw New Member
    27
    SoCal
    Why are there dots in the inside surface of the upper wind shield?
    I am considering sticking a FasTrak® transponder up against the inner wind shield behind the rear view mirror and wonder if there would be any problem due to the dots.
  2. rockfeller
    rockfeller Junior Member
    88
    CA
    To me it looks like sunshade like dots, which help create some sort of shadow.
  3. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    You can stick the transponder over them, I've been doing that with my ez pass for many years now, no problem.
  4. Jason dinAlt
    Jason dinAlt Member
    183
    61
    1. It is a free "Count the Dots" game. Caution: play only at stop lights.
    2. It is a device to reduce driving under the influence - if you can no longer see the dots, you should not start the car.
    3. It is part of the SETI project. All of the dots when put together form a massive antenna to seek intelligence. If you registered your car properly, you should begin getting emails telling you the direction in which to park your car.
    4. They tell you it is part of the SETI project, but it's really a secret government program researching mind control.
    Ken Blake, ftl and PLSPUSH like this.
  5. CharlesH
    2,785
    1,152
    Roseville, CA
    If you are in California, I think the only legal positions for the FasTrak is in the lower left or lower right corners of the windshield.
  6. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    My PeachPass HOT lane transponder works fine behind the "dots" sunshade
  7. The Craw
    The Craw New Member
    27
    SoCal
    Bottom left link "FasTrak Mounting Instructions":
    Metro ExpressLanes
    States that you can mount 1.5" from top of wind shield in center behind rear view mirror. Mounting in bottom corners makes for a long forward stretch to set the switch for number of car occupants.
    lensovet and CharlesH like this.
  8. CharlesH
    2,785
    1,152
    Roseville, CA
    I stand corrected. It's the bottom left or right or behind the rear-view mirror.
  9. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    Sunstrips don't adhere well to those dots - something to think about if you're considering a mini-tint across the top 6"…
  10. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    I went with the "directly behind the rear-view mirror" option.
  11. rjrose
    rjrose Junior Member
    I am late to this discussion, but I put my switchable transponder (for the LA toll lanes) in the center of the windshield just below the dots, behind the rearview mirror. The transponder is obscured from my direct view, and seems to be working just fine. I have a Pilkington replacement windshield.
