Double vision
Discussion in 'Prime Main Forum (2017-2022)' started by Smithrmark, Oct 7, 2020.
  1. Smithrmark
    Smithrmark Junior Member
    Woodstock
    Good morning Mark.
    I received information back from the technical division at Toyota Canada.
    The double image you are seeing at night time is a result of the Heads Up Display feature your vehicle comes with, reflecting the info onto the windshield. For vehicles that have this feature, the windshield is required to have an additional layer of glass inside it to broadcast the images properly.
    They have confirmed that, when looking out at this section at certain angles, the refraction from the glass can cause the double images you are seeing.
    Unfortunately, they have stated this cannot be corrected on vehicles like yours that are designed with the Heads Up feature, and technically our windshield replacement was not going to correct or change anything.
    At this point, they have stated there is nothing more our dealer can do with this concern, as it is a design feature of the vehicle, which we have confirmed on similar vehicles.
    I apologize we cannot do anything further.
    iPhone ?
    road2cycle and bluespruce like this.
  2. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Love it... in software lingo, there are never any bugs, only "features". :ROFLMAO:
  3. bb4srv
    bb4srv Active Member
    140
    107
    2018 Prius Prime
    Technology
    I have HUD but never really noticed ghosting. Now I should check mine prime with HUD. Will let you know.
    In the meantime, change the seating angle so it changes the refraction angle see if it helps.
  4. pghyndman
    498
    466
    CT shoreline
    I don't recall this issue with either of our two HUD equipped PPs. Checked it out last night, and did not notice any issues..
  5. Smithrmark
    Woodstock
    Not sure what to say been reading up on it. And I can’t find a conclusion to it except when I use the polarized sunglasses it goes away. I going to plan so test drives in other Prius primes and other Toyota products with HUDs to see if they have the same issue.
    iPhone ?
  6. vvillovv
    vvillovv Senior Member
    4,322
    1,510
    NY
    Thanks for posting an update and further plans. Mine doesn't have HUD so I can't test anyway.
    I was going to write after reading your posts, that other cars with HUD's might not show the same issues to you when you drive them due to the curve of the windshield and/or your seating position in relation to the windshield in other cars. Than I thought one way that might be helpful, unless you've done this already, changing your seating position in as many directions as possible to see if the reflection(s) go away or at least move to less annoying places.
  7. bluespruce
    bluespruce Member
    79
    72
    New England
    2020 Prius Prime
    I have not noticed double vision but it is interesting information. I love the heads up display on the Prime. It works well for me.
  8. Wolfie52
    Wolfie52 Senior "Jr" Member
    143
    124
    No. Carolina
    I must say, that my 2017 Prime Advanced with HUD never had a problem like this.Recently. I did replace the windshield due to a a number of dings and finally a crack. (Weak Toyota Prius windshields-- as I had to replace my 2013 PiP after 3 years just like this prime).
    I have noticed that I get a bit of "ghosting" (ex-can see 2 headlights, dimly) in my windshield now, as they (Safe-lite) obviously replaced it with a "regular" windshield. The HUD is fuzzy, but if the windshield holds up better, I really don't mind. I do not drive at night much, but have wondered if the ghost effect will be worse then. Seems my issue is the opposite of the OP.
    I had the same company do the windshield on my 2013 and it has NO ISSUES, no dings, etc. It did not come with a HUD however.
  9. road2cycle
    road2cycle Active Member
    168
    109
    Sonoma County, CA
    When I checked out the Limited version I could barely see the HUD even with it set to maximum brightness. I thought the sales guy was messing with me until I switched to my regular prescription glasses.
  10. bluespruce
    bluespruce Member
    79
    72
    New England
    2020 Prius Prime
    So far so good with mine. I love car heads up displays and the Prime's works fine. I wish Tesla would get them.
  11. Db17
    Db17 Member
    188
    92
    Visalia, CA
    The HUD is polarized light, so polarized sunglasses will kill it. That’s why pilots don’t wear them. I switched to RayBans and everything is now fine.
  12. Smithrmark
    Woodstock
    Unfortunately I can’t use that at night and it shouldn’t be a requirement.
    iPhone ?
  13. Smithrmark
    Woodstock
    Also noticing with my windshield is a little dirty and clears it right up
    iPhone ?
  14. Db17
    Db17 Member
    188
    92
    Visalia, CA
    Sunglasses are not a requirement at all. But if/when you wear them, polarized ones will kill the HUD in the same way they kill reflections. The HUD is a reflection.
  15. bb4srv
    140
    107
    2018 Prius Prime
    Technology
    I have a HUD PP. No ghosting.
  16. Smithrmark
    Woodstock
    I going to the dealer to see another pp with hud and I will update
    iPhone ?
