Downsized from 19" to 17" and somehow... ride quality is worse?
Discussion in 'Gen 5 Prius Main Forum' started by strawmochi, Aug 25, 2025.
  1. Zeromus
    Zeromus Active Member
    553
    307
    Ottawa Canada
    2024 Prius Prime
    SE
    Up until about 90kmh in EV mode on a freshly laid road - quiet. Older roads - loud. Even in a prime SE, which doesn't have front laminated glass. I definitely think its the wheel arches. I believe its the same in other priuses too historically, and most hatchbacks as well. When you don't have a full on closed off trunk, road noise in the back will be higher than if you have a closed off trunk.
    For priuses in general, I've seen numerous examples of people sound proofing/deadening the wheel arches making a massive difference for road noise in the past. So the gen 5 is likely no exception. I wouldn't mind figuring out a good way to sound deaden the arches in the future, but in a way that doesn't hold moisture thanks to the whole salted roads thing. I've seen so many videos about using specially made foam/sound insulation rather than sound deadening stick on mats for the arches, but if they ever hold salty water from the winter, that's a recipe for disaster. I kinda just live with it. Better than the NVH of my much older 2003 lol You notice it so much even coming from the modern prius on the highway lol
    Perfectpacman likes this.
  2. TGTGUUD
    TGTGUUD Member
    92
    70
    San Francisco
    2024 Prius
    Wider and heavier tire & wheel combo almost always cause worse ride quality. No surprise here.
    And Prius is a bare bone economy car with no sound deadening to keep the weight down and true to its eco root. Any increase of tire noise will surely stand out more.
    #42 TGTGUUD, Dec 8, 2025 at 8:28 PM
