Downstream O2 Sensor Replace
Discussion in 'Gen 3 Prius Main Forum' started by itengineer, Dec 2, 2022.
  1. itengineer
    itengineer Member
    86
    25
    Minneapolis
    Does anyone have instructions on how to replace the downstream O2 sensor?
    This is the one after the cat.
    TIA
  2. itengineer
    itengineer Member
    86
    25
    Minneapolis
    FYI - I bought a 2 day subscription to TSI
    I was able to download the diagnostic/install PDFs
  3. PriusCamper
    PriusCamper Senior Member
    13,453
    5,430
    Pacific Northwest, USA
    It's easy... There's youtube videos on it too... The plug is under the carpet close to to dash on left side of front passenger seat. I think I usually use a big 7/8" box wrench and count the number of turns so I can pre twist the new cable/wires so once it's screwed in the wires are no longer twisted but straight.
    itengineer likes this.
  4. itengineer
    itengineer Member
    86
    25
    Minneapolis
    Thanks. I did find this specifically for the 2011
    However I ended up paying a mobile mechanic $100 to install the new sensor
  5. Kam2
    Kam2 Junior Member
    39
    new york
    Anyone knows the part number for OEM ?
  6. Mr. F
    Mr. F Active Member
    390
    264
    Washington
    Denso also sells it as the 234-4400, which you can likely obtain for much less.
    Kam2 likes this.
