Dr. Prius app with Caritsa OBD device
Discussion in 'Gen 3 Prius Technical Discussion' started by spiralhelix, May 20, 2019.
  1. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    My bafx Bluetooth scanner not showing hybrid battery charging and discharging. Do your one work on hybrid assistant app?
  2. VFerdman
    VFerdman Senior Member
    1,200
    1,218
    Western Massachusetts
    My old BAFX reader seemed to work with hybrid assist. But that was a while ago. I haven't had an Android phone for a few years now and hybrid assist does not exist in iOS, unfortunately.
    Ohid likes this.
  3. PickleMint
    PickleMint Junior Member
    The Netherlands
    I am using a 'Viecar' Bluetooth 4.0 dongle from AliExpress. Works fine on iOS with Dr. Prius and Car Scanner ELM.
    It also works fine with Carista. I suspect (as the device looks almost identical) that it is the same dongle as can be bought directly from Carista.
    The Vgate device also looks promising. There is an (Android) app (ELM327 Identifier), it looks like the Vgate supports the most protocols.
  4. ADONAI TSEHAYE
    ADONAI TSEHAYE New Member
    Oakland
    I was using exactly like you did and I run all the test through the Dr prius app and I 've found that my battery is 55% which is in fair condition which am still didn't understand it if I need replacement of battery or I can go with fair battery for long time ? Anybody can explain for me ? Thank you
  5. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    What is your delta SOC and blade voltage difference?
