Dr Prius - Error!! battery was somehow charging during test
Discussion in 'Gen 3 Prius Technical Discussion' started by AnneN, Feb 20, 2022.
  1. AnneN
    AnneN Junior Member
    39
    Ireland
    Hi All.
    First time posting here.
    Just got a 2014 Prius, imported from Japan into Europe.
    I ran the Dr Prius Battery Life Expectancy today and got a strange result:
    Can anyone help me with what this means? Should I be worried?!?
    Thank you.
    52,695
    congrats and welcome!
    did you run it again to see if it was a glitch?
  3. AnneN
    AnneN Junior Member
    39
    Ireland
    Hi bisco. Thank you for the welcome and the reply.
    No I didn't run it again, too scared I would blow something up! It just felt so wrong flooring the accelerator and pressing the break so hard for so long.
    Just wondered if it was a result anyone else had gotten themselves or seen from someone else.
    I guess I just need to do it again.
  4. vvillovv
    vvillovv Senior Member
    4,336
    1,517
    NY
    which ODB2 bluetooth adapter are you using?
    Dr Prius report shows
    VIN# No VIN Number
  5. AnneN
    AnneN Junior Member
    39
    Ireland
    I ran it twice more. The second time I got 194%!!
    The third time I realized what I did wrong - I was keeping my foot hard on the break whilst discharging the battery!
    This is the third result - which I think is a good one?
  6. AnneN
    AnneN Junior Member
    39
    Ireland
    Hi. I'm using this one
    I wondered if it's because the car is a Japanese import to Europe that the VIN is not shown?
  7. vvillovv
    4,336
    1,517
    NY
    Good catch.
    You might want to try the Hybrid Assistant app too, to see if it also works with your OBD2 adapter. Both apps are really good at giving lots of data about the Prius systems and data that one app doesn't have can sometimes be found using the other app.
    I was wondering the same. You could send an email to Dr Prius support and ask if they know of any other issues when using the app with an import from japan.
    Hybrid battery diagnostic and repair tool for Toyota and Lexus
    AnneN likes this.
  8. bisco
    52,695
    i would say 85% is spot on for an 8 year old battery
    AnneN likes this.
  9. AnneN
    AnneN Junior Member
    39
    Ireland
    Thank you both for the support and advice. My first Prius and first hybrid so a very different experience from years of driving diesel or petrol cars. So far I'm loving it - the car and the whole experience of driving it and learning about it.
    It's such a calmer way of driving.
  10. AnneN
    AnneN Junior Member
    39
    Ireland
    Yes, I've been using this the last couple of days after watching a YT video on it. Not 100% sure what it's all about yet but I'll figure it out.
    Thanks.
  11. vvillovv
    4,336
    1,517
    NY
    If you already watched a YT you probably already know about the option to view the reporter data (there is an option in settings "Archive Trips" that lets you choose how many trips to archive).
    The default screens are not the easiest to view at a glance like DrPrius. The reporter feature in Hybrid Assistant is were the app really shines since it saves a ton of data for each trip it archives. And the more you read it the more you'll start to understand what some of the more obscure bits relate to.
    #11 vvillovv, Feb 22, 2022
    AnneN likes this.
  12. Matt98svt
    Matt98svt Junior Member
    85
    South Carolina
    2015 Prius v wagon
    I keep getting the same error code. So are you not supposed to keep your foot on the brake when doing the test even though the car is in reverse? I get down to about 200 seconds left and the engine kicks on to charge the battery and it throws the error
  13. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    That is great news! Now get going with the egr circuit cleaning. You’ve got 3 hours to complete it, time starts now!
  14. pavidco
    pavidco New Member
    Tehran
    It could be a glitch in the test, or it might indicate a potential issue with the battery. I'd recommend consulting with a mechanic or someone knowledgeable about Prius batteries to interpret the result and determine if any further action is needed.
  15. Carall
    Carall Active Member
    316
    104
    Harrisonburg, VA
    The similar happens when there is a module in the battery pack that suddenly loses its charge during the test and the battery charge drops below 40% instantly and the engine starts. Such a module can be detected by trying to discharge it with an RC charger. During discharge the charger will throw an error message saying something like the voltage of the battery is too low.
