dr prius lithuim modules problems
Discussion in 'Gen 2 Prius Main Forum' started by mikweb73, Jun 14, 2023.
  1. rjparker
    rjparker Tu Humilde Sirviente
    11,104
    6,967
    Texas Hill Country
    Don't have a Prius FB group and don't belong to one. Love to see the links with details here or wherever. It is a safety and reliability concern for a massive power source in the passenger compartment. Love the idea just wish there was transparency before known issues have a solution.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Several times. But that is over a LONG period of time.
    Maybe 8 to 10 %.
  3. pasadena_commut
    pasadena_commut Senior Member
    3,065
    951
    Southern California
    For 12V car batteries I'm at roughly 10% too. One bad out of around 10, over 45 years. The one that dropped dead almost immediately was a Bosch from Pep Boys.
  4. pasadena_commut
    3,065
    951
    Southern California
    That is probably the safest choice. However, it does assume that the quality of current packs is equivalent to that of the originals, and that may or may not turn out to be true. Nobody is going to know until years from now. Past track records are not always reliable indicators of current quality. For instance our original GE Microwave oven lasted 25 years, the replacement GE units we bought both died in under 2 years. The pack in our 2007 Prius is the original, it isn't in the best of shape, but 15 years is an amazingly long time for a battery to keep working.
    We don't have nearly as many years of history with the project Lithium pack. A lot of care has clearly gone into the electrical design, and I'm impressed that they redesigned the circuit after observing only a 1% failure rate for a particular problem. A lot of companies would have calculated that most of the failures would be well past warranty and let it slide. Still, assuming that these packs will last as long as the original NiMH ones isn't at all a certainty, despite their best intentions. I worry about the pouch technology batteries drying out faster than the prismatic blades in the original. (One of the main things that kills batteries is loss of water. All else being equal, the thicker the wall, the slower the loss of water through it.) I have my doubts about the longevity of the soldered tabs on the pouches. I don't recall exactly but there was some part of the original circuit boards which I thought might have problems. The vibration in cars is really hard on solder joints and these may crack over time. That's why the Honda IMA battery sticks had cells welded end to end rather than soldered, and why sometimes there is potting material on circuit boards in cars. Tesla stayed away from pouch based packs, but not because of the soldering issue, they were using a different chemistry which is more prone to going up in flames, and they argued that other form factors were safer.
    On the other hand...
    The Project Lithium pack is clearly superior in some ways. It is lighter and it stores more power. Both of those are going to increase MPG if all else is equal. Will it save enough in gas to offset an earlier failure? Possibly so if the car is driven far enough before that failure occurs.
    Also, as Toyota phases out NiMH packs they may reach a point where they stop making replacements. That is basically what happened with Honda and its IMA packs. At that point there are only the aftermarket suppliers to keep the cars going. For that reason, it would be a form of insurance for this ecosystem (as it were) for some of us to buy aftermarket packs to keep the aftermarket suppliers in business, in case that dread day ever arrives. Of the aftermarket packs discussed in this forum, I think Project Lithium is probably the best, both from a technological and business perspective.
    So which am I buying? Luckily I don't have to make that decision just yet!
  5. AzusaPrius
    AzusaPrius Senior Member
    2,257
    943
    When it is time, check out my profile for the link of this amazing HV battery.
    I will give anyone in the high desert an install of your purchase for only $150
    PriusCamper likes this.
  6. PriusCamper
    PriusCamper Senior Member
    13,465
    5,431
    Pacific Northwest, USA
    Last time I installed a Nexcell pack I charged near $150 because he seemed like a honest person who deserved a break and $48 an hour is more than fair for someone working from home and not paying for a shop.
    But because I let him watch and spent lots of extra time explaining the dude wrote me a check for $400 and gave me a stern lecture about how the only problem with my "highly skilled" work was that I should value myself more... Lol... And Jack as well says the going rate for a shop to do an install is $450 and that I need to charge more.
  7. AzusaPrius
    2,257
    943
    Yea some people like to work slow to get a higher labor rate.
    I can do it in half the time and this deal is only for locals in the high desert.
    I would rather help people get their packs installed safely at a great price than charge them an arm and leg for whats going to take me way less than 3 hours.
  8. mikweb73
    mikweb73 Junior Member
    35
    oregon
  9. mikweb73
    35
    oregon
    just downloaded dr prius app and am getting to know it. will probably upgrade so i can do its test. it's data coincides with other scanner apps i normally use . block 1 and 2 are low volts , so the lithium cells 1 and 2 may be bad or of a different manufacture batch and started of with less of a charge or there is something in the pack connections that is reducing the voltages (corrosion , etc.) or they are defective etc. . i used new bus bars , everything was corrosion free when i put it back together. a couple years ago , back when i was swapping out bad hydride cells every few months , i installed a maxx volts whole pack trickle over charger and through hole 120v plug so i could just plug it in with an extension cord from the outside like an e.v. and it would automatically run the battery fan and fully charge every cell in the battery pack , equalizing them if they were not too far of spec from each other , even from a dead pack that the prius would not start the engine with. so i could try using that , however i will have to do more research to figure out if it might damage the lithium cells with too much voltage or heat, even though the lithium cells are supposed to be able to handle more current and produce less heat than the metal hydrides they replace, the metal hydrides were twice as many cells ,so any voltage increase was half per cell that the lithium's will experience , on top of lithium's lower nominal voltages.
    i have not contacted dr. prius lithium project yet , as i wanted to get a better understanding of the problem first to make sure it was not some sort of goof on my part or simple easy fix , before i wasted the companies involved's and ,my time contacting them and going back and forth as i assumed they would just write it of as bumbling armature installation . i also have taken 6 months off work to build my girlfriend a 30 ft high out building that had solar installed during the winter, i poured concrete welded brackets and logged and filled up a log truck then milled all the structural lumber myself and roofed it and am now landscaping and doing work in her Forrest and getting old pieces of equipment to work that i bought nonfunctional at auction , i am pretty occupied and short on free time and don't drive the usual 2 hrs a day to and back from work i used to in the prius. thus i have been slow to get on this battery problem, and the last time i ran the prius a couple of days ago after it completely shut off the battery pack and went into limp home mode , i cleared the dtc's and it started working more or less normally for a couple of hours .
    as i am finishing up my other projects i will spend more time on the prius , i have lots of upgrades in the works , 2nd big 12v battery installed , big pure sine wave inverter installed , but have yet to hook it all up the way i want with all remote solenoid switches from the drivers area ,for battery selection and out lets etc. and dedicated hybrid and 12v battery monitors , volts , amps , watts temp etc. and all new led lights and corner cameras and on ir camera. and disc brakes for the rear parking brakes . at one point i was seriously thinking about adding a rear drive electric boost /4x4 motor and extra traction packs , but that is too much work and would take up too much time and space and weight , and better suited for my honda civic gen 1 hybrid.
    TheLastMojojomo likes this.
  10. rjparker
    11,104
    6,967
    Texas Hill Country
    I think you have just killed your chances with the company (which you have not contacted directly) after explaining all the non standard charging and mods.
  11. pasadena_commut
    3,065
    951
    Southern California
    Don't. The manufacturer's site says not to use any sort of grid charger on the pack with their LFP blades installed.
    The only good use for an HCH1 is as a trade in. I had one, it was a money pit. The CVT kept breaking, there was no OEM IMA pack replacement with good cells (only used ones), and the aftermarket IMA pack with Chinese cells crapped out in very short order. It handled like a Civic, which was nice, but it was just as anemic accelerating as a Prius, and it was far less practical. I was amazed when CarMax bought it for $1K, since as far as I was concerned, it had negative value.
  12. Lesk_The_Glut
    Lesk_The_Glut Junior Member
    58
    25
    Bakersfield, CA
    Any updates, Mikweb73? I'm curious to know how their customer service is treating you before I buy their pack.
    Prius Rising likes this.
  13. Tombukt2
    Tombukt2 Senior Member
    13,861
    2,519
    Durham NC
    Yeah it should be interesting to see how they're going to support this looks like this guy's added a ton of electronics to his generation too My god all these battery monitors from the seat folks got lots of time on their hands I guess holy crap. I'm not really seeing how the battery manufacture seller is going to get involved in this especially when I would think most of the things that have been stalled and this guy's generation two are all 12 volt related for the most part It looks like The sine wave inverters not fully connected so it says. And seen no further post that's always interesting.
  14. PriusCamper
    13,465
    5,431
    HI Lesk, I have friends that live in your town and it'd be fun to visit them if you need help with the install... I've also been helping Project Lithium with FAQ writing and adapting packs to run in Honda hybrids, which has given me a front row seat to their customer service work. Feel free to private message me if you have specific questions? They definitely push their economic limits of being generous when people do something stupid that damages the battery pack.
  15. pasadena_commut
    3,065
    951
    Southern California
    LFP modules would have to be an improvement over those strange dual cylinder NiMH sticks Honda started using with the Civic Hybrid in 2006.
    We had a first generation Civic Hybrid. You hardly ever see those on the road these days because in addition to the packs not lasting very long they had an unreliable CVT. (Even if one changed the fluid frequently, which was extra maintenance I never needed to do on any other car.) Other than that the car was just a slow Civic, but otherwise reliable. In the same sense as "other than that Mrs. Lincoln, how did you like the play". Ours rarely did better than 40 mpg though, regardless of driving conditions.
  16. mikweb73
    35
    oregon
    so far they treated me pretty well customer service wise. i got an upgraded version 2 lithium pack from them and installed it and it works great so far.
    i drive a minimum of 80 miles a day to work and back , half of it up and down some fairly steep and long hills , one in particular on the way home has a long moderate slope which makes sure the battery is fully charged before the last part of it a very steep downhill for a few hundred feet staring at 55mph at the top and you have to slow to 35 at the bottom as you go round a bend, this all combined puts a lot of overcharging stress on the battery pack, and there was some corrosion on some cables and contacts but that would not cause any increase in overcharging with increased resistance, however the cold winter here is when it started having problems and condensation probably helped accelerate the corrosion, also the cold would reduce the battery packs ability to cope with high charge rate/load further exacerbating the problem, i ended up getting the triangle of death at the bottom of that particular hill, and i was told all the battery pack module pouches were puffed up , and with all the other circumstances to me shows a really bad combination of factors together created extreme , repeated overcharge events that over about 10 000 miles or so fried the pack, but who know i am no expert on the matter.
    the gen 2 modules upgrades are supposed to greatly reduce the chances of overcharging the battery pack , so far it seems to be working as advertised i used the dr prius app going down the hill and the battery pack voltage was only in the yellow zone no red showed like with the old pack. however i did not get or use the app on the old battery pack until it started having problems so i do not know at what level it was at when it was new. i will continue to monitor the pack and will start doing the battery tests etc. to see how it handles things over time.
    i previously posted a long one about my problems and solutions etc with the honda civic hybrids but it looks like it failed to post and is gone , shame i explained a lot,
    anyway yes the cvt had massive problems ,the powertrain is right out of the previous years honda insight , a car that looked like a prius and had an aluminum frame and was significantly lighter . in a heavier civic it over torqued eveything in the cvt, ant cvts especially first gen ones couldn't handle much torque to begin with. in the second gen civic hybrid they fixed the problems to a degree by beefing up the cvt parts , and fixing specific design flaws and increasing low end pully ratio by 20 percent to handle launch torque etc..i believe my cvt slips because the hundres of segments on the bands that form the drive belt , wear down over time due to many factors that you can mitigate to some degree, then the beltis down to the bands and the sides of the bands have no grip and aid slipping as well as the band now being narrower and going down further in the pulleys affecting ratio and possible getting to extent of pully in/out movement. i was going to rebuild my original cvt and tore it appart but got 2 spare parts cars for about $800 and ripped out one and installed it into my car. some day i will rebuild one of them, but i did get to see the wear on parts etc. inside one. i have gotten 42 mpg in it combined hwy/hilly country driving before started slipping again. ac, extra baggage weight etc. all drag down mpg and performance.
    if i get enough free time i may take and post pictures, but its low on the priority list right now , wish you well , gotta go .
    Isaac Zachary and bisco like this.
  17. Plaman
    Plaman Member
    46
    34
    Denver, CO
    I didn't read any of those text walls with no formatting. I have zero affiliation with Project Lithium / Nexcell but I will absolutely attest to the quality and customer service of my Project lithium experience in my 2nd Gen Prius. I paid full price, had a technical issue that-quite frankly-was my fault, and had two replacement blades shipped to me for free along with additional equipment to manage the install.
    If anyone has any questions about Project Lithium I would be happy to answer them on a phone call or other means of communication. This batteries, and this company are going to change the market. It's early adopters like us that are driving that change. I'm not going to hand out some referral code or BS like that but if you are anywhere within a couple hours of Denver, Colorado I will help you every step of the way because I believe so much in what Jack at Project Lithium is doing. I'm here if anyone has any other questions.
    Prius Rising and ColoradoCrow like this.
  18. mikweb73
    35
    oregon
    just did a battery health test after about 10000 miles and i think i lost 2% or so of battery life however that may fall within the margin of error combined 1st test and this one . still have over 110% of battery life so even if i was losing 2% per 10000 miles i may have at least 150 000 miles left , if i expect an accelerating deterioration rate over time do to various factors due to chemistry , corrosion , operating under less than ideal conditions , temps etc., etc., etc..... . but who knows this version of the pack may last me 250 000 or more miles before it is unusable or mpg and performance degrades enough to want to replace it. i will try to keep track of mileage and performance and health more precisely and do regular testing every 10000 miles in the future, to track changes .
  19. pasadena_commut
    3,065
    951
    Southern California
    A test I ran on our old NiMH pack showed that it had increased in capacity by about that much over a period of several months with no processing of the pack to cause it to improve. The consensus was that that was noise too. Unless the operating temperatures for two tests are exactly the same the thermal effects are likely at least a couple of percent.
  20. mikweb73
    35
    oregon
    the first test was in much warmer weather , probably about 30 degrees or more warmer than the test now , first one was after start up and the one now was after an hour plus drive , i did not note the battery temps. so who knows how much effect that had on the test , but i can assume there had to be some significant effect . in the future i will have to star taking screen shots of all relevant data.
