dr prius lithuim modules problems
Discussion in 'Gen 2 Prius Main Forum' started by mikweb73, Jun 14, 2023.
  1. mikweb73
    mikweb73 Junior Member
    35
    oregon
    in response to priuscamper's post:
    i do not have a lot of specific knowledge of the prius drive train as i never had to replace and rebuild parts of it like i have had to with that damn 1st gen honda civic hybrid, but i cannot see how slipping would cause the electric motor to output more torque and damage the dampener as you say .other hybrids don't have traction control and don't self destruct when you spin the wheels. however it does seem plausible to cut power to prevent getting rpms too high and damaging components and tires that way but even then i think it is self limiting unless your wheels are off the ground and have absolutely no friction resistance and a simpler rpm limiter would solve that. what am i missing?
  2. ChapmanF
    19,022
    Well, that's a pretty fair description of the system in gen 1 (though this thread, otherwise, doesn't seem to be about gen 1).
    If you have an RPM limit in mind, and supplying electrical power to a very torque-y motor sends it above your RPM limit, what is your response to limit the RPM?
    If you look at the nomograph, notice that a quick spike of MG2 to an unrealistically high "car speed" (which can happen if the wheels break traction), especially if the engine is stopped (which it often is, when first moving off from a stop) corresponds (draw a line through zero ICE RPM) to a big negative MG1 RPM. (And gen 1's MG1 had a lower safe rev limit than gen 2's, just ±6500. The gen 2 MG1 is safe to ±10000.)
    The rotating masses are small enough (with the engine stopped) and MG2 is torque-y enough that a loss of traction could whip the gen 1 MG1 to an unsafe RPM faster than you the human could react with your foot on the pedal, so the car had to do it.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,103
    6,967
    Texas Hill Country
    Going to a "Toyota University" for a couple of years would help but you normally have to work for the dealership.
    Disabling traction control can damage the transaxle, which is otherwise hard to do.
    I usually tell "civilians" (locals without hybrid basics) the Toyota transaxle was the real engineering breakthrough as it had no clutches or torque converters and it's realtime control, monitoring and reliability was amazing twenty years ago.
    The inverters (vfds) and three phase motors had been around forever but never packaged quite so small for so very little money - while still capable of running in such severe vehicle conditions.
    It takes several generations of any breakthrough to optimize it. Certainly the awd versions like my Rav4 hybrid are considerably more optimized for things like rain, ice and snow. Even then ice is a killer for anything on rubber.
    After three years of severe ice storms in Central Texas, my Prius v gen3 now has Michelin Cross Climate 2 tires which are noisier but have not impacted my mpg by any noticeable amount.
    For better understanding of how a Toyota hybrid drivetrain works, spend a few weeks at Weber State University in Utah. Or better yet, if you have the discipline, spend quality time on their automotive website. You really have to watch the early videos and work up to your generation as they don't repeat the building blocks to any extent.
    https://m.youtube.com/playlist?list=PLIn3FrDiB1lyzmzZNBM24V_FsyuDx8ow_
    I would start on the "The 20 Year Evolution of the Prius Transaxle" and then continue through the videos.
    #63 rjparker, Dec 2, 2024
  4. ChapmanF
    19,022
    We often mention the online Technical Information Service here, when we're talking about the repair manuals and wiring diagrams:
    Toyota Service Information and Where To Find It | PriusChat
    We don't always mention that there's a whole "technical library" including the University of Toyota course materials there, too. That is mentioned on the above-linked wiki page, but it doesn't hurt to plug it again. :)
  5. mikweb73
    35
    oregon
    thank you chapmanf and rjparker for the useful information i will be studying up soon one way or another as even though my gen2 prius is in good shape except a deer head butted the side as i was going to work at 4am while driving on a rural road. it has about 250000 miles on it and eats some oil and it is only a matter of time until something critical wears out or breaks.
    on a side note it got down below freezing the last few days and into the low twenties today a and my back up car , the 1st gen honda civic hybrid was throwing battery trouble codes at me , the battery pack was replaced by the dealership where the previous owner had it serviced the several years he owned it ,and the paperwork checks out , new cells of oem hydrides, about 60000 miles in 4 to 5 years. fairly mew , only 1/4 of their life span , and they do not like the cold either. it runs fine , just reduced power or on engine only until the battery pack warms up , but it has never tried to do charge / discharge cycles that brake and accelerate the car like the prius, of course that may happen later on as the pack ages or if the cells don't warm up fast enough. also the honda only has about a 15 or 17 hp electric assist motor the prius i believe has 50 or 60 hp. so if the honda was doing it i would be much less noticeable.
    also another side note and comparison to the honda about braking drivetrain components , before i knew anything about the honda hybrids particular problems the cvt started slipping at high torque and rpms and had signature "judder" on take off and i actually tried a "burnishing the clutch" procedure that dealerships performed at the official recommendation of honda. which was their attempt to ( push off total failure till after the 80 000 mile warranty expired ) avoid replacing a cvt and drive train components that were designed for the honda insight not the heavier civic and so were over torqued in normal operation and wore out and broke components way faster than normal . the procedure consisted of jacking up the front wheels off the ground and goosing it up to about 35mph then slamming the brake ,and doing this a few times , and apparently this worked for a few thousand miles or so until it would start slipping again and then they would do the procedure again , then after the warranty expired honda told them to buy a new transmission. metal powder and flakes were a common occurrence in the cvt fluid. honda and the dealers had been misrepresenting the problem as a clutch slipping problem and all sorts of other problems , but iT became obvious when i tore my original cvt apart to rebuild it , that the steel belt spline segments were wearing down and slipping on the steel angled pulley halves and that the "burnishing the clutch " procedure was to cause a jolting severe friction to cause the belt segments to bite into the angled pulley halves in the low end range (where take off torque causes most of the slipping) and rough it up to increase friction for later normal operation. the 2nd gen cvt beefed up all the weak parts and added 20% more lower pulley range to solve the problems. i usually drive the honda in really bad conditions because it is more reliable in some ways and does not have the traction control problems and has less side wind drag and lower center of gravity and handles better ,and if it wrecks i have more steel around me and i don't have to deal with it's problems anymore . i got my use out of it , i only paid about $3000 for it and $ 700 for 2 parts cars. after that i think i probably would get another prius gen2 to replace it. better gas mileage and power and hauling room , higher ground clearance, etc ..
  6. mikweb73
    35
    oregon
    i just got home at 3 pm and it is still below freezing and amazon dropped of my new not so cheappo elm obd2 dongle thats works with the doctor prius app and played with it some and it started off with the prius battery pack restricted to about 14 hp charge and discharge maximum restrictions by the prius computer and all three battery temp sensors at 31 degrees f. because the prius had been sitting outside overnight . i cranked the heat up full fan and temp ,recycle air vented mid vents, to help warm the pack up as fast as possible, since the prius was not running under load but only idling enough to charge the pack at a max of 12 amps it did not get very hot . i started off into its charge and discharge cycles max 12 amp and avg 8amp charge and max 10amp and avg 6amp discharge. i let it do this for about ten minutes recording on the prius app and periodically taking screen shots. as the pack temperature rose the computer raised the max resrictions on charge and discharge to about 17hp at the end at about 40 degrees f. Screenshot_20241203_153208_Dr Prius.jpg Screenshot_20241203_153342_Dr Prius.jpg Screenshot_20241203_153008_Dr Prius.jpg Screenshot_20241203_153018_Dr Prius.jpg Screenshot_20241203_153205_Dr Prius.jpg Screenshot_20241203_152829_Dr Prius.jpg Screenshot_20241203_152553_Dr Prius.jpg Screenshot_20241203_152706_Dr Prius.jpg Screenshot_20241203_152428_Dr Prius.jpg Screenshot_20241203_152424_Dr Prius.jpg Screenshot_20241203_152343_Dr Prius.jpg Screenshot_20241203_151648_Dr Prius.jpg Screenshot_20241203_151703_Dr Prius.jpg Screenshot_20241203_152155_Dr Prius.jpg Screenshot_20241203_151515_Dr Prius.jpg Screenshot_20241203_151414_Dr Prius.jpg Screenshot_20241203_151625_Dr Prius.jpg
  7. mikweb73
    35
    oregon
    tried to upload screenshots of the excell output of the dr prius app but it got fouled up , will have to figure it out later
  8. mikweb73
    35
    oregon
    Screenshot_20241204_145541_Anyscan.jpg Screenshot_20241204_145404_Dr Prius.jpg Screenshot_20241204_144639_Dr Prius.jpg Screenshot_20241204_145340_Dr Prius.jpg Screenshot_20241204_145159_Dr Prius.jpg Screenshot_20241204_144224_Dr Prius.jpg Screenshot_20241204_144242_Dr Prius.jpg Screenshot_20241204_144338_Dr Prius.jpg Screenshot_20241204_142910_Anyscan.jpg Screenshot_20241204_143346_Anyscan.jpg Screenshot_20241204_135456_Dr Prius.jpg
    prius ran fine in mid to high twenties temps but at reduced power on the way to work , a little under an hour drive got trouble codes towards the end . on the way back home battery temps got into the 90's when cabin temp was 70 , and charged to 100% and past according to the computer, and ended up pending a replace battery pack code.
  9. rjparker
    11,103
    6,967
    Texas Hill Country
    You are learning what many have learned, the lifespan on these aftermarket modules with poor bms control is very low.
    I don't recall anyone running oem modules ever overcharging.
    It seems you were blaming the manufacturer but were letting the startup company that sold them to you off the hook. Of course they have moved on to another chemistry. I would be seeking help from them quickly.
    At least we know you can understand the arguments.
    Honda was notorious for bad trannys on many models during this timeframe
    Brian1954 likes this.
  10. black_jmyntrn
    black_jmyntrn Senior Member
    1,729
    410
    2013 Prius Plug-in
    this is not true... let me ask you this.. if the Gen 3 came with both NiMh and Lithium, do you think the electronics were different between the vehicles that had either or? Do you think the electronics from the Gen 2 and 3 are that drastically different to support the different battery types?
    you know... this way of think something is a scam because it might bear some of the earmarks then openly calling a company a scam.... all because , its what you believe without any proof just a huntch... has got to be one of the most.... well lets just say this is something I don't do personally and after talking with many people on a similar topic I've learned that most people have been scammed and since I haven't, I don't have a fear nor are my spidy senses configured to start tingling because of earmarks... but that's just me and being on the opposite end of people whose spidy senses are configured to react to scam earmarks and not being anything close to scam related I can tell you that jumping the gun towards someone or something and immediately classifying them as a scam improperly is idiotic!
    everyone wants to point the blame at what they are unfamiliar with
    id be curious to know which one? I have pretty extensive time into the OBD2 port of a Prius and using many different dongles and cables to use with techstream... so much so I had a PCB I designed made so I could not only log data to the SD card on the board but also be able to control an added rear electric motor for an AWD conversion... that said. If you didn't get a MX+... lets just say I don't trust any dongle unless its the MX+ or the board I've made to provide the most accurate data from the port.
    Here are some articles I wrote with OBD2 in them. that first one about what to use with techstream is good. Soon I hope my board will be able to connect to techstream wirelessly...
    https://black.jmyntrn.com/?s=obd2
    but this is the one I recommend, also recommend watching the video about one of the key differences between the obd2 dongle I recommend and a low cost version
    https://black.jmyntrn.com/2021/01/02/new-obd2-bluetooth-adapter-is-better-than-carista/
    Yeah but... you can have all that and still need experience working on and through issues with many different vehicles. I know one guy who is the Prius Yoda of the Gen 2 and kid you not, without him and his assistance I wouldn't be where I am at today with my Gen 2 knowledge... because I know one thing for certain, the entire dealership service garage and employees couldn't figure out the gas issue with my 2017 Prime... it got to a point where they were recommending trading it in for a newer one because they couldn't give the car back without it throwing a CEL right after leaving their dealership... heh, they told insurance someone put sugar in the gas tank and I laughed when I told the insurance rep, clearly they don't know what they are talking about and said that after seeing the fuel crystalize... which means its old... not that sugar was put in the tank! You see... just because Toyota Service doesn't mean they know everything... just like just because Toyota, doesn't mean their batteries are they best and their logic cant be disputed...
  11. black_jmyntrn
    1,729
    410
    2013 Prius Plug-in
    as much as I might not like PriusCamper and his energy... he makes a point I think lots of people just don't think about... the harness.. the wires... if they were all corroded even just a little... and you noticed after having HV battery problems... then you replaced the cells and didn't replace the harness with a new one... any additional battery issues you have are not on the battery cells your replaced with. Its because you didn't get a new harness! heck, I even went the route of adding solder to the terminal of the wire to help the resistance and connection with no long term success of throwing no more hv battery codes. It wasn't until I got all new hardware and a harness did all my hv battery headaches go away!
    I wrote a few blog articles on the company I recommend purchasing a harness from
    https://black.jmyntrn.com/?s=harness
  12. rjparker
    11,103
    6,967
    Texas Hill Country
    Of course they are different including the ecm and bms.
  13. black_jmyntrn
    1,729
    410
    2013 Prius Plug-in
    how positive about that are you?
  14. ChapmanF
    19,022
    If rj isn't positive, I'll bite. In an earlier thread where this silliness came up, I posted photos (frame grabs from the Weber U videos tearing the different batteries down, with their different wire harness and BMSes). You're welcome.
  15. mikweb73
    35
    oregon
    i response to black_jmyntrn 's post
    thank you for the information , i have several different kinds the wifi ones usually only work with proprietary software ,the blue tooth ones work with torque and dr.prius , i bought a panglong which claims to work with dr.prius but it kept cutting out and having communication errors so i am returning it . i bought a veepeek as well and so far it works pretty good for a generic semi cheapie . each one and software i have all have some trade of or another , some of the software has options others do not and some are a pain to customize to display what you want etc , so i use various ones for different things or situations,
  16. mikweb73
    35
    oregon
    speaking of wiring harness issues the slip control loosing coms with steering wheel angle sensor and other s completely stopped after i wiggled all its harness connectors .
    when cold and heat cycles happen such as below freezing when i start the car in the morning then blasting the defroster for an hour on the way to work bringing everything up to 70 , then refreezing in the parking lot at work and then heating on the way home then freezing in the driveway over night , the plastic and metal contract and expand at different rates and thins move as well a condensation forms and corrodes stuff. which definitely affects electrical connections. when i was swapping out the two battery packs back and forth subbing in refurb modules i replaced the busbars in one with new nickel coated ones cleaned contacts , new nuts , and solderer flux cleaned wires and crimped connections ect the other one i wire brushed the copper bus bars and wire lugs clean and reused them, i checked connection pins and cleaned them later on and on one packs bus bars and contacts i applied an electrically conductive grease specifically designed to improve conduction and prevent corrosion in contacts . in the year and a half doing that i did not notice any additional degradation or corrosion , and performance and voltages etc did not change since i did all that . one pack was fairly pristine to begin with ( other than corrosion on the bus bars) the other had issues and that one if i had let it get much worse would have ended up causing problems.
    i know from experience , electrical contacts and wires can be an intermittent or constant source of problems from working on sailboats and yachts decades ago , wires can crack and contacts corrode and things move with vibrations etc . that is one of the reasons why i am hesitant to lay blame on the manufacturer of the li cells , many things could be going on . however there are a lot of recurring data that is consistent with the cells not performing well with the cold , and the pack not meshing well with the prius programming and then the prius causing damage to the cells as a result of these compatibility issues . it is hard to get much more conclusive than that as i only have the data the prius computer spits out and how the car performs to go by , so far, i do not know the specifics of the li cells electric or electronic controller or protections etc. nor any of the programming of the prius . i will probably get some info about the cells when i finally pull the current pack with the li cells/module out ,probably to replace one that looks like it is possibly going bad , it seems its resistance and voltage fluctuations are moving out of step from the rest of the pack , it may be very slight now and may not develop into a bad module , but it might.
    the prius was running semi normal after work except it was always trying to chare the battery to a higher level than before repeatedly going past 100% , then after i stopped for gas and shut it off and turned it back on it started behaving more normal yet. i want to not mess with the pack until this summer unless it fails before then , i want to see if it goes back to normal when the weather improves etc. and gather data until then .
  17. mikweb73
    35
    oregon
    on the way home it started in with its charge and discharge cycles , i used the dr. prius app for the first 60 % of the trip Screenshot_20241206_143103_Anyscan.jpg Screenshot_20241206_142709_Anyscan.jpg Screenshot_20241206_142420_Anyscan.jpg Screenshot_20241206_142119_Dr Prius.jpg Screenshot_20241206_141814_Dr Prius.jpg Screenshot_20241206_141616_Dr Prius.jpg Screenshot_20241206_141548_Dr Prius.jpg Screenshot_20241206_141544_Dr Prius.jpg Screenshot_20241206_141528_Dr Prius.jpg Screenshot_20241206_141513_Dr Prius.jpg Screenshot_20241206_141443_Dr Prius.jpg Screenshot_20241206_141437_Dr Prius.jpg Screenshot_20241206_141430_Dr Prius.jpg Screenshot_20241206_141301_Dr Prius.jpg Screenshot_20241206_141249_Dr Prius.jpg Screenshot_20241206_141246_Dr Prius.jpg Screenshot_20241206_141130_Dr Prius.jpg Screenshot_20241206_141104_Dr Prius.jpg Screenshot_20241206_143103_Anyscan.jpg Screenshot_20241206_142709_Anyscan.jpg Screenshot_20241206_142420_Anyscan.jpg Screenshot_20241206_142119_Dr Prius.jpg Screenshot_20241206_141814_Dr Prius.jpg Screenshot_20241206_141616_Dr Prius.jpg Screenshot_20241206_141548_Dr Prius.jpg Screenshot_20241206_141544_Dr Prius.jpg Screenshot_20241206_141528_Dr Prius.jpg Screenshot_20241206_141513_Dr Prius.jpg Screenshot_20241206_141443_Dr Prius.jpg Screenshot_20241206_141437_Dr Prius.jpg Screenshot_20241206_141430_Dr Prius.jpg Screenshot_20241206_141301_Dr Prius.jpg Screenshot_20241206_141249_Dr Prius.jpg Screenshot_20241206_141246_Dr Prius.jpg Screenshot_20241206_141130_Dr Prius.jpg Screenshot_20241206_141104_Dr Prius.jpg Screenshot_20241206_143103_Anyscan.jpg Screenshot_20241206_142709_Anyscan.jpg Screenshot_20241206_142420_Anyscan.jpg Screenshot_20241206_142119_Dr Prius.jpg Screenshot_20241206_141814_Dr Prius.jpg Screenshot_20241206_141616_Dr Prius.jpg Screenshot_20241206_141548_Dr Prius.jpg Screenshot_20241206_141544_Dr Prius.jpg Screenshot_20241206_141528_Dr Prius.jpg Screenshot_20241206_141513_Dr Prius.jpg Screenshot_20241206_141443_Dr Prius.jpg Screenshot_20241206_141437_Dr Prius.jpg Screenshot_20241206_141430_Dr Prius.jpg Screenshot_20241206_141301_Dr Prius.jpg Screenshot_20241206_141249_Dr Prius.jpg Screenshot_20241206_141246_Dr Prius.jpg Screenshot_20241206_141130_Dr Prius.jpg Screenshot_20241206_141104_Dr Prius.jpg
    then after a stop at the store used the x tool dongle and app
    i also while parked at the store switched between the two
    there appears to be many things going on at once and or one cascading into another . there are discrepancies , sometimes quite large 50 % or more in state of charge between what is graphically represented on the prius dash display of battery charge ( 8 horizontal bars i think ) and what the prius computer reports as state of charge ,granted there is a rounding up issue with only 8 bars to represent 0 to 100 , and of course the prius app i cant remember if it asked me if i was using the lithium replacement cells or not , i think it did , may be taking into account the lithium's chemistry and performance and different cells capacity etc and be reporting it's refigured estimation of pack, actual state of charge . and the prius computer i believe graphically is only displaying the range of the packs capacity it will allow to be used so as to never fully charge or discharge the pack , which would damage it i do not know if the reported obd2 % is raw capacity or this restricted down capacity . also it appears the prius in the morning when it is freezing out reduces allowable charge and discharge power but runs more or less normal with less performance then some time after i start driving home it decides that there is a problem with the pack then starts doing the charge and discharge cycles and it seems the pack cant hold a charge or the capacity is restricted to a quarter or less of the normal pack capacity , and then it just keeps trying to charge the pack all the time even when almost flooring it going up a steep hill . then the prius computer reporting of state of charge and the dash bars graphically representing it , jumps around , out of sink with each other (the graphical may just be lagging several seconds ) state of charge say change from 50% to 90% or 100% to 40%. , or be at 100% and continue to charge quite a bit . it seems like it may be part of some sort of test to figure out what the actual available capacity of the pack is , but it is getting conflicting data it cannot reconcile, and usually around this time i clear the trouble codes and history but unless i use my professional obd2 tool i cannot get the subcodes or more specific trouble codes and wipe all its history data it seems because some times it will not return to normal operation until i stop and turn the car off . then on the rest of the trip home it runs fine , just seems to allow itself to charge the pack a little higher than normal .
    i need to research all i can on the battey management specifics of the prius computer and performance profile of the oem hydrides , to maybe figure out what is setting off the computer. it's going to turn into a lot of work to figure this out probably.
  18. mikweb73
    35
    oregon
    in response to black_jmyntrn post about making an all wheel drive prius , sounds cool . i once entertained the idea of getting 2 prius with rear end damage or complementary damage so they would be really cheap and take the front drive train out of one and put it in the back end of the better one so you could also steer the rear wheels as well as having double the power and and independent drive system providing redundancy , and you could crab walk it ! i figured out how to solve a lot of the control problems , but some things would require quite a few trade offs such as a lot of extra weight killing fuel economy and decreasing range , greatly reducing cargo room and having to create a firewall and extra reinforcing and fitting all the extra control stuff around the driver not in the way but fairly accessible . and not to mention would take a massive amount of time to accomplish , just to make a cool toy . your mod is probably far more practical .
    black_jmyntrn likes this.
  19. Hayslayer
    Hayslayer Active Member
    534
    325
    Wait a minute. Jimmy Neutron had to take his car to a dealership and another place, because his car was running poorly from bad gas? That's not the Jimmy I remember. He'd of sorted that out in his secret lab while Goddard was turning into a multi-tool or just installed a rocket engine.
    The car is 7 years old, now.
    Was it years newer when this event happened, maybe car was 4 years old?
    How did you end up with gas old enough to 'crystalize'?
    Did it have a 15 year old container of gas put in?
    Any additives that may have worked out of solution or something?
    If the gas was crystalized, were the fuel lines, pump, filter, injectors, etc all clogged?
    Well, probably not, because you say it was running. Maybe just 'oxidized' enough to pop codes?
    Weird.
  20. highmilesgarage
    highmilesgarage Active Member
    494
    185
    Kansas City
