Featured Dr. Prius Packs Less Than A Year Away?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by PriusCamper, Oct 28, 2020.
  1. Frijjj
    Frijjj Member
    70
    38
    Runcorn, UK
    Added my name for the mailing list, not in the market yet for a lithium pack but as soon as the current one fails I will be!
    jacktheripper likes this.
  2. ChapmanF
    19,052
    H᠎i, it's good to see this is finally on the market!
    I'm not in the market at the moment, but I hope you won't mind if I mention a few things I noticed at the web site that would raise questions for me if I were in the market. They might raise questions for others too, and maybe you can find ways to revisit them in ways that would raise fewer questions.
    1. In the FAQ, "What is the technical specification of the battery?"
      • storage temperature (1 month): -20C ~ +45C
      • storage temperature (3 month): -10C ~ +45C
      Where I live, -10C to -20C can be real-life temperatures, not just for "storage", but for normal hopping into the car and going somewhere. What are the operating temperature limits for the battery, and what happens if they are exceeded?
    2. From the home page:
      • Nexcell lithium pack delivers 260Amp peak power compared to 100Amp peak power from stock NiMH battery
      Can you clarify any immediate or long-term effects this might have on the 125 amp fuse Toyota uses to protect the battery circuit?
    3. Also from the home page:
      • Nexcell lithium pack maintain an optimal voltage to trick the computer in favor of electric power. Resulting in better fuel economy
      Here on PriusChat we spend a certain amount of repetitive effort explaining to newbies the reason why tricking the car into more electric driving generally isn't a win for fuel economy, because of the double tax of conversion losses into and out of the battery.
      Perhaps what you are trying to say here is something more specific, and you have a reason why it makes more physical sense in your specific case. It might be helpful to give a little more detail then, so readers can tell what sets it apart from a classic newbie mistake.
    4. Seeming dissonance:
      • From the FAQ: ... testing all around the world in extreme conditions and weather/temperature variances. Some testers race their Prius, some power their home with their Prius. For more detailed information, please visit PriusChat.com [italics mine]
      • From the warranty: Powering high voltage inverter straight from battery pack will void warranty, NO EXCEPTIONS.
      It doesn't seem quite cricket in one breath to tout a certain configuration being tested, and in the next breath exclude it unconditionally from the warranty, especially a configuration that doesn't seem abusive on its face. It would be better to mention up front that these testers are doing something excluded in the warranty; it would be better still to explain in the warranty exactly why you consider the configuration abusive, and even better still if you could establish specific guidelines for "plug-out"-type configurations that you would not exclude from warranty.
    I hope you find some of these comments useful!
  3. jacktheripper
    jacktheripper Senior Member
    284
    561
    Great questions, let me try my best to answer
    1. If someone is driving outside of the temperature range, the battery ECU will reduce or even cutoff the power from and to the battery, that's why many prototypes were sent to testers in Sweden, Russia, middle east and northern state, the test all passed with flying color. The LiFePO4 cell we co-developed actually have better temperature tolerance than the Toyota NiMH cell, on top of that the entire Lithium cell is seal, no vent hole, no connectors joints that can leak out or leak in moisture due to temperature difference.
    2. Actually our lithium cell can produce peak 400Amp max, 260Amp is a conservative number. It's mostly to show how good the cells are and 125 Amp is basically walking in the park. I know a lot of customers already plan on using these lithium cell on go-kart and EV boat project, can't wait to see what people can do with all these power.
    3. I have explain this topic in multiple threads so hear me out again, the lithium has better round trip efficiency at 95~97% compare to NiMH at probabaly around 75%, it means that instead of wasting charging power in heat, lithium actually absorb most of the energy and deliver it back with higher voltage potential. On top of that lithium has 80% usable capacity (compare to NiMH at 40%) means your Gen2 will be much harder to run out of juice again in that long stretch hill. All these contribute to a better fuel economic and match what we see if real world. So far we have only two users saying they are not seeing MPG gain, it turns out these 2 users are basically driving on highway speed 90% of the time and electric motor isn't really helping much in that situation.
    4. Very good point and thanks for the great feedback, we should be more specific on how we test and what warranty covered.
    Best,
    Jack
  4. ChapmanF
    19,052
    Are you saying that those numbers are capabilities of the pack when used in other projects, but just won't ever be seen when installed in a Prius because the ECUs will keep the current draw within the original limits? Or are you saying that currents of 260 A might sometimes be seen in a Prius using this battery, but you are not concerned what effect that may have on the 125 amp fuse?
  5. Rmay635703
    Rmay635703 Senior Member
    2,705
    1,730
    Somewhere in Wisconsin
    2013 Chevy Volt
    How many of these retail packs are fielded?
  6. PriusCamper
    PriusCamper Senior Member
    13,472
    5,440
    Pacific Northwest, USA
    Even a NIMH pack will go up over 150amps briefly... The fuse blows on sustained amp loads during short circuiting or similar events not on brief high amp loads.
  7. ChapmanF
    19,052
    Sure, and Pacific Engineering even publishes data on the time-to-blow versus percent overcurrent. I guess I am still wondering whether the number, duration, or amplitude of overcurrent events will be higher with this battery than with the original, and if so, what has been thought about the effect on the fuse of repeated overcurrent events short of blowing on the spot?
  8. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Doesn't the hybrid controller use a current sensing resistor? The current draw is probably limited by the ECU.
    moto g power ?
  9. ChapmanF
    19,052
    There's a Hall effect current sensor donut. We can speculate about how the consumption is modulated, but I'm hoping jacktheripper has something less speculative.
    mjoo likes this.
  10. PriusCamper
    13,472
    5,440
    Yes, exactly and the packet size and lithium chemistry type of each cell is specifically designed to match the power curve that the ECU requires. So when you floor it from 0-60 the power doesn't feel any different than a brand new NiMH pack at first. But what does feel different is a slight lack of decline in the power curve because the Lithium pack can sustain full power for longer periods of time.
    What's more the lithium pack recharges way faster because NiMH only charges in 70% efficiency range with rest of the energy lost as heat and the Lithium pack is only loses charge efficiency at ~2%.
    The real magic using these packs happen when the car's charge drops down to 3 bars when climbing mountains, or in EV mode in traffic or during a heat wave when your air-conditioner can't keep up. In my experience when the pack drops to 3 bars in these situations I feel like I'm driving a different car because there's still plenty of power left and not even a brand new NiMH pack can do that.
  11. ChapmanF
    19,052
    So which is it? Is the "260Amp" touted on the web site a figure that won't really be seen in a Prius because the actual behavior will match the output curve of the NiMH (and, therefore, no new concerns for the fuse, but also nothing really to ooh and aah about)?
    Or is it something actually noticeable in a Prius, and therefore possibly worth evaluating for long-term effects on the 125 amp fuse?
  12. jacktheripper
    284
    561
    yes sir, Prius battery ECU won't let the battery drain more than 125 Amp. 115 Amp is the highest I've seen using Dr. Prius App + lithium, again, this is just to show how good the battery cell is.
  13. ChapmanF
    19,052
    Is it also the case that "Even a NIMH pack will go up over 150amps briefly" (upthread in #66)?
    Those statements seem at first incompatible, but is it because of something a difference in timescale, or has there been a mistake?
  14. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    This is false.
  15. PriusCamper
    13,472
    5,440
    Saying something is false with no reference and no details is not helpful to all of us learning... Are you suggesting that the numbers are off? Or are you suggesting that the amount of electricity going into a 1980's battery chemistry is absorbed just as efficiently as electricity going into a 2010's battery chemistry?
    From my personal experience comparing a project lithium pack with a NiMH pack is that the lithium pack charges up to the same capacity as NiMH much more rapidly and produces less heat in the process. The rest of the information I presented was direct from @jacktheripper
    If you have firsthand experience, as well as specific references to help us all learn more about what is "false" please provide them.
  16. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    The numbers are way off. On both sides. I am an EE and have worked with both chemistries a long time. I've already given lots of data before, mostly ignored in this thread. But those values are just way off.
    Just think about it for a second. Let's say even 10KW of regen into the pack. You're saying 30% is heat? That's 3000W of heat generation. Prius can do almost 40KW of regen.
    NiMH can be charged almost as efficiently as lithium chemistries in many SoC ranges. The bulk of the inefficiencies come from the bidirectional converter which hasn't changed.
    Like I said before, I've been here and done this. Both professionally and as a hobby.
    donbright likes this.
  17. tre4xw30
    tre4xw30 Junior Member
    37
    US
    Wish he would go ahead and implement LiFePO4 tech.
    SM-N986U1 ?
    PriusCamper likes this.
  18. bisco
    52,889
    is that coming next?
  19. PriusCamper
    13,472
    5,440
    Wouldn't it be pretty easy to go back and quickly grab a link to those numbers? Telling me I can't see "lots" of data because it was "mostly ignored in this thread" makes no sense because in reviewing this thread I don't see data that relates to your claim?
    And referencing 10kw examples for a 1.3kwh pack is confusing... Clearly if you send a few hundred watts of charge into a battery pack, the amount of energy loss in the process is measurable, right?
    And clearly if you use a more modern, more advanced chemistry their will be less of an energy loss than NiMH right? This is interesting information and I validated it with my own direct experience. What about you?
    We're interested in learning more but doesn't seem you want to share you knowledge, or maybe you don't have knowledge to share are are just bitter that Jack's pack is better than the ones you sell? I'm not interested in taking sides. I recommend your battery packs often. I'm simply trying to learn more.
  20. ChapmanF
    19,052
    We can take that as a working number ... 40 kW would be around 150 amps assuming the charge voltage during regen has risen to 270 volts. This could be around the outside extreme regen possible for a short period.
    The battery ECU keeps track of the blocks' effective internal resistances as well as their voltages. Values around 19 to 21 milliohms seem to be in the ballpark for good packs. Let's say 20 mΩ.
    There are 14 of those blocks (assuming the iconic Gen 2, or the Gen 3 liftback) ✕ 20 mΩ = 0.28 Ω for the pack.
    (150 A)² ✕ 0.28 Ω = 6.3 kW of heat generation in a 40 kW regen event. (At a mere 10 kW of regen, because of the quadratic, the heating is only around a sixteenth as much, around 400 W.)
    What are the typical effective internal resistances for the lithium packs?
    mjoo likes this.
