Featured Dr. Prius Packs Less Than A Year Away?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by PriusCamper, Oct 28, 2020.
  1. PriusCamper
    PriusCamper Senior Member
    13,475
    5,441
    Pacific Northwest, USA
    Well... Do you have a nexcell pack yet? We could use your help...
    As previously discussed there's an RV product that's basically a 12v powered electric blanket bag you can put your Lithium battery in and we could design something similar for Prius packs, perhaps a range of designs based on easy to hard to install... I'm leaning toward some kind of inexpensive 12v heating pad that installs underneath the hybrid pack.
    We also need to decide if we want something that heats with lots of power so it warms up fast, or something that is low power and is left on all night.
    Then next step is adding some temperature sensors in the pack. Research question being: what's the easiest/most efficient way ensure the pack is no longer too cold to take a charge when you're down below sub-zero.
    Let us know how you can help?
  2. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    Keep in mind that the low temp ratings are typically relevant to new cells, and decreases along the same lines as cycle life.
    An example is my NiMH smart charger for honda and toyota NiMH packs. Has an option for low temp charging at temps below 40 F. Not recommended to use that option in the chargers manual iirc, but I wouldn't use it after seeing the graphics of how the older weaker cycled packs perform both on the bench and in the car.
  3. PriusV17
    PriusV17 Active Member
    440
    207
    CA
    2017 Prius v wagon
    Impressive study. Done in space and at -20C. No sign of degradation.
    "The results showed that the battery can still operate properly at temperatures as low as -20°C. However a reduction of the capacity at low temperatures was observed: The battery's capacity at -20°C was 62% lower than the one at 20°C. The battery fully recovered its capacity after returning back to the nominal working range (20°C), and its performance barely changed thorough the whole range of temperatures studied."
    "We can also see, that the performance of the battery (charge/discharge capacity) barely changes and it almost remains constant thorough the whole range of temperatures studied. The changes are also only temporary and the battery is fully recovered after it is put back to the nominal temperature range."
    https://upcommons.upc.edu/bitstream/handle/2099.1/26410/David_Balaguer.pdf?sequence=1&isAllowed=y
    Battery was charged at -20C and had no negative affects.
    #143 PriusV17, Dec 19, 2022
  4. Trollbait
    12,832
    "For further analysis of the LiFePo4 battery we should also measure capacity and performance but considering the variable number of cycles. With this we could be able to see how affected is the battery when performing hundreds of cycles and in what way do the charge and
    discharge cycles change. This analysis however would be destructive, it would require several batteries and it would take much more time."
    They only had a single battery. Thus were unable to do the extended life cycle study. The possible damage from charging at below zero could be slight enough to not show up in the tests they did.
    Coots likes this.
  5. vvillovv
    4,337
    1,519
    NY
    6. References​
    [1] http://www.trisat.um.si/
    [2] Maini, Varsha agrawal (2011). Satellite Technology: Principles and Applications
    [3] http://earthobservatory.nasa.gov/
    [4] MIT Electric Vehicle Team (2008). A Guide to Understanding Battery Specifications.
    [5] http://www.batteryuniversity.com/
    [6] Kamal K. Kar, Jitendra K. Pandey, Sravendra K. Rana (2014). Handbook of Polymer Nanocomposites. Processing, Performance and Application: Volume B: Carbon Nanotube Based Polymer Composites
    [7] Masaki Yoshio,Ralph J. Brodd,Akiya Kozawa (2009). Lithium-Ion Batteries: Science and Technologies.
    [8] NI-DAQ™mx C Reference Help (February 2014)
    gives an idea about how quickly battery technology is advancing to date
    Battery University Homepage
  6. PriusV17
    440
    207
    CA
    2017 Prius v wagon
    So far this is the best -20C research I have seen on LiFePO4 battery. That means that not enough if any research is done on these battery chemistries at below freezing to conclude anything. Other than "so far so good". Only long term time will tell esp for Nexcell packs. The fact that we have users getting good results below freezing is a good sign. It might take many (many) years before we can make any conclusion.
  7. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    Want a test let me have one I'll put 1000+ miles on it a week. And I'll do logs.
  8. PriusCamper
    13,475
    5,441
    UPDATE: Still have this pack in my Gen2 Prius and is still running flawlessy with no issues after more than 5 years!
    bwilson4web, hill and Isaac Zachary like this.
  9. Isaac Zachary
    Isaac Zachary Senior Member
    2,787
    1,506
    Thanks for the feedback? Do you mind if I ask how many miles that equates to?
  10. PriusCamper
    13,475
    5,441
    I'm not sure of the exact number... I'm at 304K miles right now and I think 5 years ago I was probably in the 230K mile range.
    #150 PriusCamper, Dec 29, 2025
  11. Isaac Zachary
    2,787
    1,506
    So about average for a US car owner. That's very good to hear.
  12. PriusCamper
    13,475
    5,441
    Prior to the Pandemic it was more than double that annual mileage, but everything changed so much after that happened. My life has been more boring ever since.
