Dr. Prius readings
Discussion in 'Gen 2 Prius Main Forum' started by Strlinmoss, Sep 16, 2019.
  1. Strlinmoss
    Strlinmoss Junior Member
    Los Angeles
    Guys can you give me some input in this reading. The numbers on number 9 are not low, but is it charging? The resistence goes over 40....and I get a p3000 code that clears. Screenshot_20190915-182329_Dr Prius.jpg
  2. Mendel Leisk
    42,325
    @jacktheripper ?
    No clue, but:
    Delta SOC looks ominous, and that's a big variation on #9.
    Do the (2) tests?
    Can you do another screen grab without the menus across the bottom? That said, think it's very uniform, just discernible.
  3. Strlinmoss
    Los Angeles
  4. Strlinmoss
    Los Angeles
    I'll post another shot later. I plan on hooking up my prolong this weekend to see what happens before I tear into to battery box...I have some cells to test first. Thanks for now.
  5. jacktheripper
    jacktheripper Senior Member
    284
    558
    @Strlinmoss, are you Per from Swedan?
    per our email, #9 is where the orange service plug at for Gen2, make sure you have "click/lock" the plug.
    also, since you didn't balance all 28 blades, it is highly possible to have a blade/block with different voltage, drive it for couple of days and see if the situation improve.
    another possible reason (pure guessing) is that your service plug is leaking current causing #9 to drain overnight, just a thought for now.
  6. PriusCamper
    PriusCamper Senior Member
    13,450
    5,430
    Pacific Northwest, USA
    I've been dealing with a prius with P3000 that clears and associated codes of late... Compared to a normal pack, voltage difference stat is too high and in that regard, you've same problem as I'm dealing with... In this pic block #9 shows up as the concern, but in my experience and it seems in your opinion as well, is that indication can change quickly and is easy to discount and not the problem... Perhaps load testing is needed to determine which module is really bad? Also charging up all the modules and letting pack sit for a day or two may point out a module that self-discharges faster than the others.
    #6 PriusCamper, Sep 17, 2019
    jacktheripper likes this.
  7. Strlinmoss
    Los Angeles
    Thanks, I have the car hooked up to my Prolong charger, let's see if the pack will balance out. Interesting clue for me. The safety plug being near #9. Well a couple of months ago I changed#4 and did a discharge and charge but, the safety plug was not fully engaged during this procedure. So, I'm thinking this may be related.....I will let you know after the charge.
  8. Strlinmoss
    Los Angeles
    I'm Ron from Los Angeles.....Sweden doesn't sound bad right now tho...lol
  9. jacktheripper
    284
    558
    I'm in Los Angeles too, Sweden does sounds good right now!!!
  10. Strlinmoss
    Los Angeles
    Well....I pulled the pack and changed out #9 with a couple of cells that I hand charged and loaded over the last week. 5 hours charged on the Prolong charger I unhook it at 238volts and the screen looks like this....weird #9 going to let it sit overnight....could I have a bad safety plug? Screenshot_20191002-190947_Dr Prius.jpg
  11. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    5 hours on the Prolong Charger isn’t enough to balance everything out;).
    Let it top end balance more and then begin the discharge process:).
    Good luck and keep us posted (y).
    SFO likes this.
  12. jacktheripper
    284
    558
    I actually received my Prolong charger this Monday and hook it up to a beaten up battery pack from a 210K miles Prius.
    The Prolong charger charge up the battery in about 24 hours, my #8 was the lowest block and then becoming the highest block after charging, this means #8 is the weakest block.
    Prolong charger did increase the overall capacity by 10% (measure with life expectancy test), but I notice the #8 block is getting even weaker now, IR increase and voltage fluctuation a lot, time to swap it out !
    Let me see if I can post the video here.
    #12 jacktheripper, Oct 4, 2019
  13. jacktheripper
    284
    558
    2010 Prius with 210K+ miles, original battery, back from the dead :eek:
    Before:
    After: LifeTest_before_2019-09-24.jpg
  14. Qamar Fahim Khan
    Qamar Fahim Khan New Member
    25
    Lahore, Pakistan
    I own a Toyota Prius Gen 4 2016 model, today i connected Dr. Prius app to my car via OBD2 bluetooth device, its showing 9 battery blocks instead of 14 and voltage difference is also 8.6 volts, my HV battery is working perfectly ok but why dr. Prius is showing this, see screenshot and help
