Dr Prius results
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bdc101, Nov 26, 2023.
  1. bdc101
    bdc101 Member
    250
    usa
    Can anyone help me interpret these results? Should I pay for the full battery test? My car is a 2010 with 262k miles. But was used as a highway commuter for most of its life. Any advice is appreciated, or if you can send me to some resources for better understanding these batteries! (I am a lifelong gearhead and mechanical engineer who has just bought his first hybrid! I would love to learn more about it.)
  2. Kiwi7910
    Kiwi7910 Junior Member
    50
    New Zealand
    It's pretty hard to tall anything about the state of the battery unless it under load. The internal resistances look like default values, so I assume that the 12V auxiliary battery has been recently disconnected. Check if it is more than 5 years old. If it is, then it probably needs replacing.
    bdc101 likes this.
  3. bdc101
    bdc101 Member
    250
    usa
    I just replaced the 12v battery. It lasted 13 years and 262k miles!!! Pretty crazy. Anyways, would I need to purchase the full diagnostic test in order to test it under load?
  4. PriusCamper
    PriusCamper Senior Member
    13,344
    5,395
    Pacific Northwest, USA
    Just keep an eye on the "Voltage Diff" number... The high that number goes under high amp loads the sooner you'll have battery problems.
  5. Kiwi7910
    50
    New Zealand
    If you're handy, it's pretty straight forward to refurbish the HV battery with a DIY grid charger. See my signature for guidance.
  6. bdc101
    bdc101 Member
    250
    usa
    Thanks! I will see if I can log the data with the free version so I can keep my eyes on the road. I'll pay for it if I need to thought.
    I was just looking at the circuit diagram I found on a different post and thinking how easy it would be to build. I worked as a systems integrator/PLC programmer/panel designer for many years, and built panels a few times too. Trying to wrap my head around the how and the why but I'm learning a lot about NiMH batteries and how to properly charge, discharge, and recondition them! I'm absorbing everything I can find. I read through your entire post and most of the links in it as well. I think I could build the DIY reconditioner with the constant-current LED driver as a power supply in a few hours, if I buy the parts. Just want to make sure I understand why I'm doing it that particular way.
  7. Kiwi7910
    50
    New Zealand
    If you have questions, just let me know.
  8. PriusCamper
    13,344
    5,395
  9. bdc101
    bdc101 Member
    250
    usa
    That first link I have been through in detail. Already thinking of laying it out on a board with some DIN rail and terminal blocks. I have to say though, the Mean Well brand is synonymous with crap in the industrial controls industry -- but to be fair, I've never specified out an LED driver or a constant-current power supply. I suppose their commercial products could certainly be better than their industrial ones. Anyways, I'll read through the other two links in detail, thanks for posting! Just gotta get my car's engine all ironed out before I can start on reconditioning the battery.
  10. PriusCamper
    13,344
    5,395
    Every once in a while I run across a fluorescent light ballast and look at the specs and wonder if there's a particular light fixture out there that are widely available for cheap or free that would work for this. If you can figure that out, that'd help lots of people!
  11. bdc101
    bdc101 Member
    250
    usa
    Unfortunately that kind of stuff isn't really my forte - I have a mechanical engineering background and mostly work with process equipment (pumps and valves) and don't get to dink around with electrical gear very much. But I'll definitely spend some time on it before I buy any of the Mean Well units. (I always thought that was a weird name -- like they "mean well" with their products even though they end up making crap?)
  12. PriusCamper
    13,344
    5,395
    It's especially troubling that they have a reputation like that because the people on here and other socials that have compared Mean Well to Hybrid Automotive's Prolong trickle chargers have concluded that Hybrid Auto uses significantly lower quality / inferior components compared to Mean Well.
  13. bdc101
    bdc101 Member
    250
    usa
    I'm searching and finding a few other brands. Philips makes a similar one for about 4x the price. Not finding a lot that can go so high in output voltage. That first one is over $250 and does up to 530 mA. The second one is only $100 but may not give high enough voltage. Unfortunately this isn't really my area of expertise.
    https://www.northcoast.com/product/detail/1039947/advance-transformer-ledinta0530c280dom
    https://www.platt.com/p/1181201/philips-advance/outdoor-led-driver-/781087142455/advxi180c125v200bs
  14. PriusCamper
    13,344
    5,395
    Suspect these links are for buyers limited to exact match replacements that are way overpriced due to a captured buyer... Wasn't talking about new stuff like that. Talking about finding someone who has a huge inventory of old ballasts that is running out of room for them and wants to get rid of them as quickly and cheaply as possible.
  15. bdc101
    bdc101 Member
    250
    usa
    The thing is, I don't think many led lights are so high of voltage. I could certainly be wrong, I don't spec out LED lights. Fluorescent ballasts don't seem to be the same sort of constant-current power supply, at least as far as I am learning so far.
    I don't know where you would look to sell such a ballast secondhand. Often times surplus like that gets left around to rot because it's too much work to find buyers. Few buyers or builders will put stuff like that in used. Working in industrial plants, you virtually always see industrial electric equipment left in storerooms as spares "just in case we need it" rather than parted out or sold as surplus. Often for decades.
    Here is the only one I found on eBay with a brief search. But I don't know if I'm using all the right search terms. Still learning about this sector! https://www.ebay.com/itm/304925450762
    Can you tell me, what's the voltage range of the traction battery? i.e. the very highest it can be at full charge and the very lowest it can be?
  16. PriusCamper
    13,344
    5,395
    yeah... I bet all the newest ones aren't high enough voltage. But I bet some of the old ones built like tanks that run without issue for 4 decades or longer are.
    bdc101 likes this.
  17. bdc101
    bdc101 Member
    250
    usa
  18. bdc101
    bdc101 Member
    250
    usa
    I purchased the DR Prius paid version and looked at some more data. I ran a life expectancy test and it said 59% remaining. It also took almost 15 minutes to drain the HV battery while running the AC full blast and with all the lights and stereo on.
    I will try to run the battery health test later. But it said the battery wasn't warm enough after a 15-minute drive.
  19. bdc101
    bdc101 Member
    250
    usa
    This second one was just after starting, the cumulative delta voltages are much higher.
  20. bdc101
    bdc101 Member
    250
    usa
    Also, I ordered a Meanwell LED driver to start building a battery reconditioner.
    PriusCamper likes this.
