Dr. Prius showing 9 blocks instead of 14 for my Prius 2016
Discussion in 'Gen 4 Prius Technical Discussion' started by Qamar Fahim Khan, Apr 8, 2023.
  1. Qamar Fahim Khan
    Qamar Fahim Khan New Member
    25
    Lahore, Pakistan
    I own a Toyota Prius Gen 4 2016 model, today i connected Dr. Prius app to my car via OBD2 bluetooth device, its showing 9 battery blocks instead of 14 and voltage difference is also 8.6 volts, my HV battery is working perfectly ok but why dr. Prius is showing this, see screenshot and help
  2. a2058
    a2058 Junior Member
    36
    Westchester, NY
    2019 Prius
    XLE AWD-e
    My 2019 shows the same, I read somewhere that in gen4, they do not monitor individual banks anymore to save cost. I think it’s two banks per measurement. Apparently DrPrius accounts for that and reports the values correctly. But, mine also shows the voltage difference in the order of 8-9volts, so not sure how that part works.
  3. Qamar Fahim Khan
    25
    Lahore, Pakistan
    But 3 months ago when i purchased this car, i checked that day voltage difference was 0.05 but now its showing around 8.65v, the only thing i have done during this period is replaced 12v battery, can it be the issue?
  4. Qamar Fahim Khan
    25
    Lahore, Pakistan
    Can you please share pictures of Dr. Prius for your car for my reference please
  5. a2058
    a2058 Junior Member
    36
    Westchester, NY
    2019 Prius
    XLE AWD-e
    I wrote to their support email, they responded and told me they will look into it… we will see what they say about this…
  6. Qamar Fahim Khan
    25
    Lahore, Pakistan
    You wrote to toyota?
    Please also share their email Id so i can also write the same to them.
    And also share their response when received, thank you dear
  7. a2058
    a2058 Junior Member
    36
    Westchester, NY
    2019 Prius
    XLE AWD-e
    Looks like they fixed it, they said they update the app and it seems to work now showing more realistic delta voltage values 2587E3DA-AECD-43BC-98B1-0D3158398959.png
  8. Qamar Fahim Khan
    25
    Lahore, Pakistan
    Yes you are right, but number of blocks are still 9 instead of 14, voltage difference is fixed but why 9 blocks only?
  9. a2058
    a2058 Junior Member
    36
    Westchester, NY
    2019 Prius
    XLE AWD-e
    #9 a2058, Apr 23, 2023
  10. Qamar Fahim Khan
    25
    Lahore, Pakistan
    Ya that makes sense but in that case voltage of block 3 to 7 should be double around 30v, but dr prius is showing same volt for all blocks
  11. a2058
    a2058 Junior Member
    36
    Westchester, NY
    2019 Prius
    XLE AWD-e
    As stated before, it seems to account for that I think, and report the appropriate values..
  12. Qamar Fahim Khan
    25
    Lahore, Pakistan
    Can you please refer me any software other than dr prius, which shows battery voltages to confirm the same,
  13. a2058
    a2058 Junior Member
    36
    Westchester, NY
    2019 Prius
    XLE AWD-e
    I believe Torque Pro is another app that can be used, but I have no experience with that one…
