DRAFT Transaxle Oil Testing Results
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bwilson4web, Oct 13, 2007.
  1. tochatihu
    tochatihu Senior Member
    9,998
    3,863
    Kunming Yunnan China
    2001 Prius
    etp, this may highlight the difference between Prius transaxle and conventional auto. trans. In the latter the fluid 'does work" while in the Prius it is only lube and heat transfer.
    It is certainly possible that a Prius fluid change could mobilize varnish as passage-plugging goo, but it seems much more likely in the other systems.
    Meg&Bear, dave77 and ETP like this.
  2. bwilson4web
    16,552
    Not enough samples of transaxle failures. We've seen less than a dozen transaxle failures. But we were able to document an increasing load of contaminates in the oil and loss of viscosity.
    As Doug pointed out, our transaxle are significantly different as there are no hydraulic operations in the Prius transaxles ... none. So when we change the transaxle oil, we restore the original viscosity and remove wear material.
  3. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
  4. bwilson4web
    16,552
    They still do. Give them a call but I haven't checked the prices recently.
    My recommendation is:
    • basic oil analysis - $17
    • add oil index (same as 40C and 100C viscosity test) - total $20
    The two temperature, viscosity test lets us know how well the oil has aged.
    Meg&Bear, dave77 and 2009Prius like this.
  5. ETP
    ETP 2026/2021 Prime/24 Venza Limit/B52-D,G,F,H
    2,806
    1,170
    Auburdale FL
    Makes you wonder if another type fluid would be better than tranny fluid. But I suppose 0W20 may be a problem for some of the parts/maybe. CVT fluid should work.
  6. 2009Prius
    2,705
    512
    63
    Monitor transaxle temperature?
    How do you monitor the transaxle temperature? Can ScanGauge do it?
    Meg&Bear likes this.
  7. satwood
    satwood Member
    107
    16
    Webster, MA, New England, USA
    2014 Prius v wagon
    Latest data with RedLine D6 ATF
    Good Morning Everyone,
    As I reported earlier, I'm one of the owners testing the Redline D6 transaxle fluid instead of the factory WS. I made the change last year at 35K miles and had the factory oil tested as a baseline. Since then I have put 23K miles on the Redline oil and changed it for the first test sample. Total mileage at change was 57691. I had hoped to put more miles on but I've been out of town a lot. The car is used primarily for long highway trips, daily and weekly. The normal average mileage would be about 35K per year.
    It looks like everything is in line or better than the first factory change except copper, phosphorus and Boron. The copper number went up to 19 but that looks similar to other people's data. The Boron value went way up to 268 - I don't know what that implies:eek:. Viscocity stayed up. I don't think I needed to change the oil again this early but I wanted the data. Anyone know what the Boron value would indicate? What does Phosphorus indicate?
    My weekly mileage is right around 50MPG so the car is operating great and it drives excellent. I'll go for 35K miles on the next cycle and report again in a year or so.
    Here is the quick data. Attached is a copy of the report with both sets of data.
    Al 14
    Cr 1
    Fe 39
    Cu 19
    Pb 1
    Sn 1
    Mo 0
    Ni 1
    Mn 1
    Ag 0
    Ti 0
    K 1
    B 268
    Si 42
    Na 7
    Ca 25
    Mg 2
    P 660
    Zn 7
    Ba 3
    SUS Viscosity @ 210 F = 44.4
    cSt Viscosity @ 100 C = 5.54
    Flashpoint 425 deg F.
    Water 0.0%
    insolubles 0.0%
    Meg&Bear, Dino33ca and dave77 like this.
  8. 2009Prius
    2,705
    512
    63
    Thank you for the data!
    I wonder what the error bars are on those numbers. Has anyone asked for them from the oil analysis companies?
    Meg&Bear and dave77 like this.
  9. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Re: Latest data with RedLine D6 ATF
    Both are anti-wear additives. For engine oils, phosphorus is usually part of zinc dialkyldithiophosphate. ZDDP is commonly used to prevent cam lobe wear in flat tappet engine designs, which are not found in modern motors
    Boron is usually boron amide and is usually used as an inhibitor to control acid buildup. It can also show up as a borax, which would imply a coolant leak
    Since boron is multi-source, the testing of other additives and compounds will determine if the source is an additive, or a problem
  10. jayman
    13,439
    641
    Winnipeg Manitoba
    Some are expected ranges, eg a xW-30 should test out at around 9.3-12.5 cSt @ 100 C. Others are "universal" averages, which are expected ranges
    Most oil analysis will provide an expected range
  11. 2009Prius
    2,705
    512
    63
    Thanks! What I meant was not the expected range but the uncertainty (error bar) of each measured value. For example if the amount of Al comes back at 14 as in the data shared by satwood, is it 14 +/- 1, or 14 +/- 10 ?
  12. jayman
    13,439
    641
    Winnipeg Manitoba
    The testing lab I use, it's +/- 5%
  13. snijd
    snijd DIY or die
    243
    52
    PNW
    This is an encouraging result. I replaced my Gen II's WS with D6 in July, but haven't done a UOA yet--and haven't driven too many miles yet. I'd hope for even lower Si levels, given that this is the second fluid change. I'm now considering replacing the WS in my Gen III with D6, which is beginning to look like a low-risk venture.
  14. dcoyne78
    dcoyne78 New Member
    135
    Over 23k thats a lot of shear the D6 starts at 6.4 at 100 C so thats about a 13.4 % loss in viscosity, was there any increase in fuel consumption due to the heavier fluid?
  15. udor
    udor New Member
    Melbourne
    2003 Prius
    I just changed my transaxle fluid at 56k miles (2004 prius). Still looked pretty good with a red tinge to it still. Probably didnt need to be done, but its done now! No point getting it tested really as it looked good.
    dave77 likes this.
  16. jayman
    13,439
    641
    Winnipeg Manitoba
    Huh, my '04 fluid was almost black at 12,000 km. Maybe our -40 winters don't help much
    Meg&Bear, Justabrake and dave77 like this.
  17. torrens89
    torrens89 New Member
    Boston, MA
    This is Rich from Hopkinton, MA. I have a white 06 with pkg 7. Almost 60K miles. I've been using Mobil 1, 5W-30 and Fram filters, changing at about 5K.
    Re maintenance. The spark plugs were never mentioned. As they are Iridium tipped, is
    the 100K recommendation of the owner's maintenance manual a good number?
    Separately, what is the consensus on Engine Coolant and Inverter Coolant, mileage-wise?
  18. Patrick Wong
    18,214
    6,531
    Actually the maintenance schedule shows 120K mile replacement intervals for the iridium spark plugs. I changed the plugs on my 2004 at ~99K miles, the engine seems to run a bit better and mpg improved somewhat.
    I would say that you should observe the maintenance schedule regarding the coolant: 100K miles to replace the factory fill; then 50K miles between subsequent changes.
  19. bisco
    52,904
    i have an 04 with 70,000 miles. when i take it to the dealer for transaxle fluid change, what will they use, what does the owners manual say? thanks in advance!
  20. jayman
    13,439
    641
    Winnipeg Manitoba
    Toyota dealerships have the WS fluid, which is called for in all Toyota automatic transmissions, eg the 5 speed auto in my FJ Cruiser
    Others have used different fluid. IMHO probably doesn't make any difference, the cvt in the Prius has gears, a planetary gear, and a transfer chain. No torque converter or clutches like a conventional auto
    Good luck getting an American Toyota dealership to even change the fluid. They usually claim it's "lifetime" or they will try to upsell you on a "flush" procedure, which is clearly impossible for the +04 Prius anyway
    With my '04, my dealership wanted $65 to drain and refill the cvt. That was reasonable
    Let us know how it turns out
