Drag HP vs mph
Discussion in 'Prime Main Forum (2017-2022)' started by bwilson4web, Mar 18, 2017.
  1. bwilson4web
    16,512
    Much to my surprise, the EPA test car data was updated in March: Data on Cars used for Testing Fuel Economy | Compliance and Fuel Economy Data for Vehicles and Engines | US EPA
    The March data includes some interesting car so I graphed their drag HP vs speed:
    • PRIUS Eco excellent, low drag - put the Prime one-way clutch in; replace the lead-acid battery with something lighter, and; add 2 kW for a deeper LiON battery capacity and it would put the Prime to shame.
    • IONIQ - excellent drag profile
    • Prius, Volt, Prime, and Camry Hybrid - all show good drag curves in effect lying on top of each other.
    Felt, giora and Gen 3 for me like this.
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Note that for all those cars, 80 MPH (130 kph) needs twice the HP as 60 MPH (100 kph)
    As driver, it may seem just a little bit faster, to your car, it is twice as much work.
    jerrymildred and bwilson4web like this.
  3. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    Please remind me -- are these data with the ICE off, so they are measuring the combination of air, tyre, and transmission losses ?
    If so, I'm surprised that the Volt keeps up since it has a relatively high Cd and I didn't remember it as having a much lower frontal area. I'm also then not sure why the range/kWh of the Volt is so much worse than the Prime.
    #3 EV-ish, Mar 18, 2017
  4. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Rolling drag power goes up linearly with speed.
    Air drag power goes up with speed cubed.
  5. Tideland2005
    Tideland2005 Member
    72
    34
    SoCal
    The math and the physics jibe very well in this chart.
    But, how could a Prius 2 Eco be so much better than
    a regular Prius 2 ? A rear window wiper about the only
    thing different (?).
  6. bwilson4web
    16,512
    Perhaps the tires? Also slightly less weight.
  7. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    As humans, we fixate on making the front of the vehicle aerodynamic, but very often the real gains are at the back.
    Often the front of airplanes is quite bizarre, but the back is the same as always, to get good aerodynamics.
    here is air flow adding a tail to Semis
    Do not discount the gains at the back.
    giora, bwilson4web and EV-ish like this.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    That's a telling statistic right there!
  9. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    I assume the Ioniq is the hybrid version? Blue?
  10. jerrymildred
    11,517
    14,164
    Tampa, FL
    Thanks Bob. This is really enlightening. Do you know if there's one for Gen 3? I did click the ink, but just got raw data. I'll have to try to explore more tomorrow afternoon.
  11. bwilson4web
    16,512
    I am not sure so I included the test car identifier in the name.
    What I did was pass through the data file and order them by make, model, and decreasing MPG keeping one set of coefficients. A quick hack, I then kept the models specific to PriusChat and the non-Prius trolls.
  12. EV-ish
    602
    278
    SW US
    I put the CSV file into a spreadsheet ... and then stared into the abyss. I have no idea how Bob turned the data into a graph although I have a vague recollection of reading that the the coefficients model constant, linear and quadratic forces proportional to speed. I could play if the numbers were not imperial units.
    #12 EV-ish, Mar 18, 2017
  13. bwilson4web
    16,512
    More technical details here: Drag HP vs mph | PriusChat
    jerrymildred likes this.
  14. jerrymildred
    11,517
    14,164
    Tampa, FL
    I hope to have time to mess with that this afternoon. I wanted to yesterday, but was spending some time at the hospital with my son who's facing some really serious stuff. So our lives are going to be very busy for a while. And I'll be driving the best car I ever had a lot more as I make extra trips to their house (1 hour away) or the hospital (1 hour in a different direction). But have less time for light stuff like this. ;)
    Raytheeagle and Prodigyplace like this.
  15. Prodigyplace
    12,710
    11,848
    Central Virginia
    They have the same tires. Toyota recommends higher pressures though. There is a tire tracking thread that proves a various tires across Trim lines.
  16. Prodigyplace
    12,710
    11,848
    Central Virginia
    Take care of your higher priorities.
    You are in our thoughts and prayers.
    scona, Mendel Leisk, GT4Prius and 3 others like this.
  17. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    On second look the Ioniq may be the All Electric version.
    First two digits on the cars' identifiers could be the model year, but for the Ioniq there is AE instead.
  18. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Take time for family, being a car geek can wait.
    I wish your son well!
    scona, Mendel Leisk, GT4Prius and 4 others like this.
  19. Gen 3 for me
    Gen 3 for me Member
    198
    81
    Illinois
    This is from another thread on this forum by Jan Treur of Dec 3, 2016. It reinforces the point Bob is making from the calculations of the low drag of the Ioniq: 4.08 vs 3.99 mi/kWh for Ioniq vs Prime
    1. Hyundai Ioniq Electric----------------136 MPGe---58 KMPLe----6.53 km/kWh---4.08 mi/kWh---24.5 kWh/100mi
    2. Toyota Prius PHV 2017---------------133 MPGe---57 KMPLe----6.39 km/kWh---3.99 mi/kWh---25.0 kWh/100mi
    3. BMW i3-------------------------------------124 MPGe---53 KMPLe----5.95 km/kWh---3.72 mi/kWh---26.9 kWh/100mi
    Chevrolet Bolt/Opel Ampera-e-------119 MPGe---51 KMPLe----5.71 km/kWh---3.57 mi/kWh---28.0 kWh/100mi
    Nissan Leaf----------------------------------112 MPGe---48 KMPLe----5.38 km/kWh---3.36 mi/kWh---29.7 kWh/100mi
    Tesla Model S with 85 kWh battery--89 MPGe----38 KMPLe----4.27 km/kWh---2.67 mi/kWh---37.5 kWh/100mi
  20. EV-ish
    602
    278
    SW US
    Thanks
    I have trouble with imperial units, but this looks like
    power = force * velocity
    So just taking the quadratic force of
    • Target Coef C (lbf/mph**2)
    • v - mph
    • Drag_HP = (v*(Coef_A+(v*Coef_B)+(v*v*Coef_C)))/375
    Would the Drag_HP then simplify to v*v*v*Coef_C / 375 ?
    Where does the 375 come from ? I presume it is the unit compression between force and velocity in imperial units, but the number is escaping me. Imperial units are the devil.
    A post on Quora says
    4.45 N to a Lbf for about 99.95% accuracy. Sound right ?
    I went back to look at the CSV and the Coef columns are either empty or have text in them. I'll have to poke around a bit more. Which columns are the data in ?
    Lastly, a question about roll-down tests: Am I correct in thinking that the test occurs in neutral ? In a regular ICE car that would capture rotation of the drivetrain and engine, but how does the model account for Toyota hybrids where the ICE does not rotate during a coast ?
    #20 EV-ish, Mar 19, 2017
