Drag HP vs mph
Discussion in 'Prime Main Forum (2017-2022)' started by bwilson4web, Mar 18, 2017.
  1. Gen 3 for me
    Gen 3 for me Member
    198
    81
    Illinois
    Although I would never expect that anyone would do this, (just thinking aerodynamics here), there is a way to make a Prime have lower drag then a Prius ECO. Replace the Primes: hood, front fascia and fenders with those from a 4th generation Prius (non-Prime).
    From what I think I read the shape of the double bubble glass and perhaps the greater length in back of the Prime is to make up for the weaker aerodynamic Prime front end. I suppose the Prime got the more agressive styled front end for marketing reasons, and perhaps because Primes were expected to on average be driven at lower speeds, shorter distances, than the non-Prime Prius because the Prime really shines while driven in EV mode.
  2. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    This EPA data most interests me in finding out whether my guess that an EV can be simplified down to mass, tyre rolling resistance, frontal area and Cd is reasonable.
  3. EV-ish
    602
    278
    SW US
    Here is the CSV data without quotation marks. It should import cleanly into Google Docs
  4. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    That's how I simulate them.
    EV-ish likes this.
  5. EV-ish
    602
    278
    SW US
    Did you compare to the roll-down data ?
  6. Lee Jay
    5,850
    4,036
    I compared using the roll-down data (which includes an odd, linear term) to zeroing the linear term and fitting the same curve using only the constant and quadratic terms. Virtually the same.
    EV-ish likes this.
  7. EV-ish
    602
    278
    SW US
    I'd like to compare the roll-down data to the simple drag equation of tyres and air mentioned above.
  8. Lee Jay
    5,850
    4,036
    Tires is the constant term, air is the quadratic term. In other words, remove the linear term.
    The resulting terms matched the roll-down data well, but they don't match what I'd expect for rolling friction or CdA.
  9. EV-ish
    602
    278
    SW US
    I may not be following, but I'm asking if
    Coef B = tyre RR * mass
    Coef C = Cd*frontal area
    The Coef A term strikes me as a fudge factor to make the algebra work but I don't know that with any confidence
  10. bwilson4web
    16,533
    I would suggest not trying to overthink the problem. In differential equations I learned there are families of equations that within the range limits are perfectly accurate. In the case of roll down coefficients and the quadratic equation, it avoids having to add a lubricant stirring drag coefficient for the differential and transmission.
  11. EV-ish
    602
    278
    SW US
    I can assure you, I am not capable of over thinking ;-)
    Under thinking is no problem
    So,
    is the drag equation
    RR*mass + v*v*Cd*frontal_area
    a good substitute instead of using the roll-down data for EVs ?
    #31 EV-ish, Mar 19, 2017
  12. Lee Jay
    5,850
    4,036
    drag force = RR_coef*mass + 1/2*air_density*v^2*Cd*frontal_area
    EV-ish likes this.
  13. EV-ish
    602
    278
    SW US
    Thanks for the correction
  14. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    I thought the coefficients are submitted to EPA by the manufacturers, If this is the case, why ignoring part of them?
  15. bwilson4web
    16,533
    The coefficients and roll-down tests are required by the EPA and sometimes are brought by manufacturers and other times by the EPA spot checking. The earlier Hyundai fines came from owner complaints and the EPA running their own tests. This revealed Hyundai had 'misinterpreted' the regs like VW's interpretation of diesel emissions testing . . . Pass the test and otherwise turn off emissions hardware and control laws.
    #35 bwilson4web, Mar 19, 2017
  16. Lee Jay
    5,850
    4,036
    If I can find a physical reason for the linear term, I'll include it. But it doesn't seem to be necessary since I can form basically the same curve without it.
  17. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Which indicates that the linear coef. contribution is very low - may be transmission load in EV drive?
  18. Prime8
    Prime8 Member
    Oregon
    2020 Prius Prime
    I successfully reduced the drag on my Prime by setting the following distance on the dynamic cruise to 1 bar, and the speed to 80mph while following 2 megabus's doing 77mph. 85 miles later, at an average cruise speed of 77mph, I had 59mpg in hybrid mode. I was getting about 57mpg on my own at 67mph prior to their arrival. So the simple solution is to buy a megabus and hire a driver to drive it ahead of your Prime.
    bwilson4web likes this.
  19. Tideland2005
    Tideland2005 Member
    72
    34
    SoCal
    My less "thinky" method :
    use 60-30 coast down to consider the squared variable (aero drag)
    30-0 coast down to consider the linear variable (rolling friction)
    hardly precise, but gives some rough idea
    Cheers, Folks
  20. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    Wow I love the tech math talk even though I seriously don't understand it!
    Lowering the intellectual kennel somewhat, I have ordered the "Protection Pack" which includes what we call "mud flaps". Does that translate into U.S.? If so, will these be likely to affect the aerodynamics much?
    It is v muddy round here with our weather and farmers tractors on the road so I reckon the mud flaps are worth having to keep the Car looking cleaner. The (black) Gen2 after I wash it only has to look at a road to be dirty again behind the front wheels and along the sills (fenders?) below the front doors.
    Felt likes this.
