Drain valve...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ScottY, Mar 6, 2006.
  1. darelldd
    6,059
    389
    Northern CA
    I can help you with this one! Get an electric mower and stop changing oil and storing gasoline. You'll love it, and your neighbors will love you.
  2. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    I did this a couple years back and will never go back to gas. Dealing with the cord is nothing compared to the starting/storage/maintenance of the old Briggs and Stratten.
  3. dreichla
    dreichla New Member
    2,230
    Connecticut
    That's a great idea - except mowing 4 hilly acres by hand gets really old fast!
    I'm thinking sheep might be the answer! Automated mowing with a fertilizer byproduct! Sorry for digressing.
  4. darelldd
    6,059
    389
    Northern CA
    Cord?! Yikes. I have a battery electric. NO CORD! You have one more step to go to achieve mowing nirvana. ;)
  5. darelldd
    6,059
    389
    Northern CA
    Hey... the response was specifically aimed at the "push mower" mentioned!
    What was this thread about, again?
  6. mssmith95
    mssmith95 Michael
    535
    Valencia, CA
    I just can't figure out how to get my gas mower into Stealth mode!
    Maybe the Prius can be retrofitted with a mower blade...ever watch "Monster Garage?"
    Maybe we can get the drain plugs added to the Store?
  7. Frank Hudon
    Frank Hudon Senior Member
    4,147
    I use the Fram drian valve and when I went to install it I found that the supplied copper washer was not soft. So I annealed it and it was dead soft when I put it on and has never leaked a drop. I'm sure with the standard washer at the proper torque that it's still not going to conform to the undulations on the oil pan where the drain plug goes in. Next time you have the drain plug out have a look and see, what I found was it was quite rough and uneaven.
    Anneal copper is really easy, take the washer and hold it with needle nose plier and heat it with a propane torch till you see a colour change and then drop it into cold water. Dead soft.
  8. Catskillguy
    Catskillguy New Member
    536
    Mid Hudson Valley NY
    the extractor sounds pretty neat (double meaning intended). The least expensive one I found was about $75.00. Does that sound right?
  9. Begreen
    Begreen Member
    670
    Western WA state
    Yeah. I haven't found an extension cord long enough for field mowing. I tried hand mowing for 2 years, it was a marathon. No exageration, in spring, by the time I finished, it was time to do it all over again.
    However, that doesn't mean I don't dream of an EV lawn tractor. Considering converting the Craftsman to propane at least.
  10. Begreen
    Begreen Member
    670
    Western WA state
    But don't you still have to drag out the oil pan to deal with the oil filter? At that point, pulling the plug seems just a part of the process. I ended up buying the NAPA version of this drain pan:
    http://www.partsamerica.com/ProductDetail....artnumber=11837
  11. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    Same thoughts. You'll have to get under the car and use the oil pan anyways.
    Another question. When you guys go to a dealer for oil change and services (I'm talking about the major maintenance services that you have to do at the dealer), did they say anything? For people using Fram, do you just hand them the hose?
  12. darelldd
    6,059
    389
    Northern CA
    In my case... if I go through the trouble of using a drain valve, it is for MY own convenience. No reason to install the drain if you're paying somebody else to perform the service. I'm the only one who changes the oil on my cars (I mean on the one that actually NEED oil changes!). The lowest-common denomintor employee is the one who usually does oil changes, regardless of the vehicle. Not for me, thanks!
    rayluo likes this.
  13. dreichla
    dreichla New Member
    2,230
    Connecticut
    That sounds close. This is the one I purchased.
    The-Fluid-Evacuator-Plus,-8.8-Liter
  14. dreichla
    dreichla New Member
    2,230
    Connecticut
    I just knew someone would call me on that point.
    Yes - I have a pan, but so far, very little oil has spilled out when I removed the filter. I think if I had more working room under the car (a lift or a pit), I'd probably opt for the traditional method of oil changing.
    But since I can use the pump with all my small engines, it makes sense for me.
  15. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    I m not talking about the 5k mile oil changes. I am doing those myself, that's why I am looking into drain valve in the first place. I m talking about bringing the car in for major services, let say 60k or 100k. Then I'll just have the dealer change my oil + the major service while the car is there. My question is, anybody have experience with that. Does the tech from the dealer know what to do with the drain valve?
  16. darelldd
    6,059
    389
    Northern CA
    Ah.... I still don't let them change the oil... so I'm no help with this answer. :)
  17. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    <div class='quotetop'>QUOTE(ScottY @ Mar 6 2006, 10:38 AM) [snapback]221059[/snapback]</div> I'm trying to decide between the Fumoto and the Fram. My local O'Reilly auto parts store only has a drain valve called "EZ Drain" where you push an outer ring and twist to lock and it starts draining from a hole in the center. The only thing holding me back from a Fumoto was the safety, but now I know about the hose clip ring that can keep the lever in the locked position. I like how the Fram drain is more secure where you can only drain it with the proper fitting. The biggest thing that leans me toward the Fram is that it has the drain tube, which would be nice to have without adding any additional length to the drain valve on the oil pan as opposed to the Fumoto with the nipple. Since I cannot find the Fram locally I will have to order anyway, since I don't have actual experience with a drain valve... which one should I order? Oh yeah, I also do not like that the Fram has the copper washer that needed to be annealed...? I do not have a blow torch... Would I be better off going with the Fumoto assuming it is a higher quality product? Or should I just forget about the whole thing and get the gaskets with the oil filters and just use the drain plug?
    Thanks!
  18. Frank Hudon
    4,147
    I've got the Fram and to be perfectly honest I wish I'd just left the origional drain plug in it. As far as anneling the copper washer you could do in on you kitchen stove all you need is a pair of pliers to pick it up and drop it into the cold water. For that matter just use a new origional gasket and skip the copper. Also it hangs down a bit low with the protective cap on it as well. Honestly, save your money.
  19. K5VMI
    K5VMI New Member
    Baton Rouge, LA
    Fumoto works great. I also tie wrap a piece of electrical tape over the outlet of the valve to keep it clean for catching oil for analysis.
  20. jmccord
    jmccord New Member
    199
    San Diego, CA, Earth
    I installed the Fumoto valve (#F-103) on my 2006 Prius. It comes with a washer which I also installed. Installation was a breeze, and so far completely bubble tight. I did not order the nipple as I wanted to minimize undercarriage projection.
    The Fumoto drain valve does not appear to reduce ground clearance, as it seems to project no farther than other undercarriage components.
    The lever w/detent seems secure enough, so I haven't added the locking clamp.
    Eventually, I'll be taking my car to discount oil change outlets, and I'm hopeful that an added drain valve, will only make it easier for the teenage lube jockeys to change the oil without cross-threading the oil pan.
    Oh, did I say I love this car? :D
