Drain valve...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ScottY, Mar 6, 2006.
  1. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    Thanks for the opinions. I think I will just deal with a plain old drain plug and have the peace of mind that my oil isn't going to be draining down the freeway. It's really not that big of a deal for me to spend an extra $0.50 for a drain plug gasket and get down there with a ratchet that I'll be using with the oil filter wrench anyway.
  2. wrennick
    wrennick Junior Member
    I've been using a Fumoto valve in my subaru for about 100K. It really makes oil changes quicker and less messy. No leaks from my valve. I'll probably put one on my new 2006 Prius when I get to the first oil change.
    I asked one shop that I had one of the major service done at and they were a little hesitant about my drain plug, but still did the service.
    Like the fumoto site says, they have sold over 2 million plugs and haven't had any problems, but I still understand the worry.
  3. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    It looks like this subject has been beat up pretty good, so I’ll just say that I don't want something that I need to keep track of extra parts to make it work. Because I will lose them and then need to buy another. :eek: I vote for the one piece construction of the Fumoto valve. :)
    rayluo likes this.
  4. richard schumacher
    7,682
    1,064
    United States
    <div class='quotetop'>QUOTE(darelldd @ Mar 6 2006, 07:23 PM) [snapback]221378[/snapback]</div>
    Which cordless mower do you recommend? How much runtime do you get?
  5. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(richard schumacher @ Jul 12 2006, 09:04 AM) [snapback]284990[/snapback]</div>
    CMM1000 by Black and Decker. I have 1/4 acre (with a house, of course, so about half that is lawn) and I can mow it several times per charge if I wanted to. But of course I never need to.
    Trust me when I say I won't go back to gas! I tried a nice push reel mower, but it would not cut the grass long (tall) enough, so I had to settle for this.
  6. richard schumacher
    7,682
    1,064
    United States
    <div class='quotetop'>QUOTE(darelldd @ Jul 12 2006, 11:12 AM) [snapback]284997[/snapback]</div>
    Thanks. Uhh, that link takes me to an image of one pixel.
  7. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(richard schumacher @ Jul 12 2006, 09:30 AM) [snapback]285017[/snapback]</div>
    It is a REALLY small mower.
    Sorry... looks like this:
  8. onerpm
    onerpm New Member
    477
    MN
    My .02: I've had the suredrain on two ford explorers for years, and now my two prii for last couple of years. no problem. no leaks, no annealing (or whatever the hell it is) of any gaskets, just install it. no leaks. got them at walmart for $10 but they don't carry them anymore; glad to see the OP with link because I'll be buying another when my 2006 comes in in August. I originally picked it over the Fumoto because it was cheaper, and available at walmart.
    You don't need to use the little hose for the suredrain, on the prius. It's easier to screw the release valve on without it anyway. it does drain a little slowly, so it's Miller Time for that. I bought it because when removing the regular drain plug, the oil comes in a gush and I ended up wearing rubber gloves. half the time, I dropped the oil plug into the drain pan. problem solved.
    it's so easy with the suredrain that I change my own oil in the winter, even though I live in MN. However, on a couple of occasions with the Explorers, I'd take it in somewhere for an oil change and just hand them the release valve thing.
    rpm
  9. n2y2
    n2y2 New Member
    23
    I can pull my drian plug and only get a drop or two on my fingertips, and none any where else.
    The real trouble is when you pull the old filter. That gets oil all over me.
    So as long as you still change the filter (like you should every oil change) I don't see the point of the product.
    <div class='quotetop'>QUOTE(darelldd @ Mar 6 2006, 09:58 AM) [snapback]221076[/snapback]</div>
  10. onerpm
    onerpm New Member
    477
    MN
    <div class='quotetop'>QUOTE(n2y2 @ Jul 12 2006, 01:54 PM) [snapback]285104[/snapback]</div>
    you're a better man than I am!
    on the filter, cut off the bottom couple inches of a 1L pop bottle and use that to remove filter when it is loose and about to come off.
    rpm
    rayluo likes this.
  11. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    <div class='quotetop'>QUOTE(darelldd @ Jul 12 2006, 01:35 PM) [snapback]285057[/snapback]</div>
    Teacher! Teacher! Darell is high jacking posts. Darell is high jacking posts. :lol: :lol: :p
  12. TheForce
    3,461
    537
    Wheelersburg, Ohio
    <div class='quotetop'>QUOTE(grasshopper @ Jul 12 2006, 05:36 PM) [snapback]285209[/snapback]</div>
    HAY! leave him alone! With an average of 11 posts per day he is just trying to reach his 2000 post mark! :p
    and i'm posting here because i'm trying to reach my 500 post mark! :p
    and to keep my post on topic i'm going with the Fumoto on my next oil change. :D
  13. Cheap!
    Cheap! New Member
    1,157
    <div class='quotetop'>QUOTE(onerpm @ Jul 12 2006, 02:58 PM) [snapback]285144[/snapback]</div>
    1 liter bottle trick! :eek:
    Too Cool. B)
    I'm getting a drain now! :)
    And never pouring oil over myself again! :lol:
    Engine Oil that is. :rolleyes:
    <div class='quotetop'>QUOTE(darelldd @ Jul 12 2006, 12:35 PM) [snapback]285057[/snapback]</div>
    I've been looking for that mower for two years and gave up last year. I thought they stopped making them. I've been tripping over my mowers leash all this time.
  14. Alnilam
    Alnilam The One in the Middle
    760
    Carlsbad, CA
    <div class='quotetop'>QUOTE(ScottY @ Mar 6 2006, 03:25 PM) [snapback]221297[/snapback]</div>
    What does this do for you? Can you hook up a tube to it and direct the oil flow to a bottle or something? Which model is best for the Prius, with or without nipple?
  15. TheForce
    3,461
    537
    Wheelersburg, Ohio
    <div class='quotetop'>QUOTE(Alnilam @ Jul 14 2006, 04:40 PM) [snapback]286383[/snapback]</div>
    Thats a good question. I would like to know also. I would like to add nipples and a skirt along with my cars see through bra. ;)
    Seriously I would really like to know if the nipple would be worth getting.
  16. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    <div class='quotetop'>QUOTE(theforce @ Jul 14 2006, 05:33 PM) [snapback]286417[/snapback]</div>
    I have a nipple! :wub:
  17. woodprius
    woodprius New Member
    <div class='quotetop'>QUOTE(grasshopper @ Jul 14 2006, 12:16 PM) [snapback]286432[/snapback]</div>
    The Fumoto valve comes with a blue washer. Is both drain plug gasket and blue washer used when installing the Fumoto valve?
  18. phumpher
    phumpher um...oh...uh...wa...er
    44
    where gold was discovered
  19. ServoScanMan
    ServoScanMan Member
    262
    Lorena, TX
    We just sold our diesel pusher motorhome. When I bought it I installed a Futomo drain valve on it. When it was time for an oil change I would place a 5 gallon gas jug under valve and drain the oil. Made it really simple and I never had a problem with the valve.
    I installed the F-103N on my Prius because I like the nipple. I also installed a Futomo drain valve with nipple on my wife's Dodge Caravan. I leave the drain tube on it and when I'm done draining the oil I just ty-wrap it back above the front cross member.
    rayluo likes this.
  20. Cheap!
    Cheap! New Member
    1,157
    <div class='quotetop'>QUOTE(theforce @ Jul 14 2006, 04:33 PM) [snapback]286417[/snapback]</div>
    I don't have one on my Prius yet, but I hear such good things about them, right behind the clear bra, I may put two. :eek:
