DRCC auto switch off
Discussion in 'Gen 4 Prius Technical Discussion' started by raspy, Apr 20, 2017.
  1. raspy
    raspy Senior Member
    438
    699
    London, UK
    I didn't realise DRCC would automatically switch off after a set period of time where the car had come to a stop. I was on the motorway when a big traffic jam occurred and after several minutes of not moving and the car 'waiting' with the DRCC, I got this message on the display. Never seen that before, and just thought I would share.
  2. Prodigyplace
    12,715
    11,848
    Central Virginia
    The message indicates the car also switched from Drive to Park. I have not heard of that before.
    RCO and raspy like this.
  3. Mendel Leisk
    42,352
    I guess they figure if too much time elapses without motion or interaction with the controls, it becomes more and more likely you're not fully in control of the vehicle, for one reason or another, so they play it safe.
  4. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    @raspy ,. I've had the same thing happen on mine, but typically for me I reacted by stirring the selector, pushing pedals and buttons. By the time I'd realised what had happened, the message was gone before I could read it all.
    raspy likes this.
  5. Prodigyplace
    12,715
    11,848
    Central Virginia
    No wonder you are confused :LOL: :D
    RCO likes this.
  6. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I try to be consistent. Maybe it's the only thing I'm inadvertently successful at..... :ROFLMAO:
    Prodigyplace likes this.
  7. Mendel Leisk
    42,352
    Even broken clocks are right, twice daily. :)
    RCO likes this.
  8. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    This is described on page 309 of the manual:
    Automatic cancelation of vehicle-to-vehicle distance control mode Vehicle-to-vehicle distance control mode is automatically canceled in the following situations.
    The following are detected when the vehicle has been stopped by system control:
    • The driver is not wearing a seat belt.
    • The driver’s door is opened.
    • The vehicle has been stopped for about 3 minutes.
    It has to switch to Park - if the car reverted to Drive it would then release the brakes and creep forward into the car in front!
    kevin
    raspy, RCO and Mendel Leisk like this.
  9. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    Good that it switched to park. Imagine if it just turned off and the car began moving forward. Actually you do have to monitor the DRCC all the time. Not often, but occasionally it will disconnect itself. I think it has an issue with following. There is a few beeps and a message.
  10. kevinwhite
    333
    200
    Los Gatos Ca
    One significant scenario where the DRCC will disconnect is if you are below 25mph and it loses sight of the vehicle it is following.
    You cannot re-engage until you get up to about 30mph
    Page 309 in the manual.
    kevin
    RCO likes this.
  11. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Thanks. Yes, I've had that happen and didn't understand what was wrong. (y)
  12. kevinwhite
    333
    200
    Los Gatos Ca
    I find this a bit annoying but I suspect it was implemented that way to avoid the car accelerating to a high speed when you have been following slowly just because the car in front turns out of the line of traffic
    One particular scenario that isn't handled very well is when you are following at a speed above 30mph, if the lead car turns into a left exit lane and the lane in front of you has stationery cars - quite often it will fail to see the stationery cars and accelerate towards them.
    Usually I chicken out and apply the brakes, one time I left it until the AEB activated. I have seen this behavior in other vehicles with DRCC. I think the reason is that the radar system requires the target cars to be moving at least 1-2mph or it sees them as ground, and so not something to stop for.
    The radars that are used for cars currently only have a single beam, they cannot distinguish up or down to tell if stationery object is a car, ground or maybe an overhead signal or sign except by its velocity.
    The camera based systems (BMW i3 for example) have better imaging but they cannot get velocity from the doppler shift and they still suffered with the same problem (at least they did about 2 years ago).
    kevin
    #12 kevinwhite, May 1, 2017
    RCO likes this.
  13. Tideland Prius
    16,681
    Probably, because that's the way it works in the Gen 3 so you really have to be cautious. There's a sharp curve on a 50 mph highway that I sometimes traverse. Occasionally, it can lose radar lock on the car in front because of the angle of the curve so the car ends up pulsing around the curve as it accelerates when it loses sight, then slows down when it locks on again and repeat until the curve straightens out.
    RCO likes this.
  14. Gen 2 Tom
    333
    286
    Lincoln Park NJ
    I didn't look that up,but you maybe correct. I will test it at that 28MPG setting. That's all a bit strange, 28 because it will go to 0 and any speed in between.
    RCO likes this.
