DRCC "braking" lights
Discussion in 'Gen 3 Prius Main Forum' started by RaZa, May 17, 2012.
  1. RaZa
    RaZa Member
    480
    93
    So when the prius "brakes" when the drcc is engaged (sorry tech packages only) do the brake lights come on? It can pretty aggressively hit the brakes and am just curious at what point (if any) the brake lights actually come on.
  2. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Yes they come on. During DRCC braking the car will decelerate (brake) all the way down to 23 MPH and then it will beep at you and disengage the DRCC if the conditions permit this to happen then you need to apply the brakes yourself.
    Posted from my iPhone via the Tapatalk app.
  3. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Yes, this is logical. Otherwise, those behind you will crash into you.
  4. Tideland Prius
    16,629
    Yes. It operates just as it would if you were controlling the pedals. If DRCC coasts, lights won't come on. If it brakes, lights will come on.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    And if it asks you to stop and let it out, you should take a close look at your driving.
    Tom
  6. RaZa
    RaZa Member
    480
    93
    Logical and obvious. I realize that if the drcc is actually using the brakes then yes I would expect the lights to come on, however to anyone that has experienced drcc it's hard to tell when it's "braking" and when it just slowing down. So what I'm really wondering is when is the slowing down actually "braking" and when is it coasting? I realize now there's really no good answer to this question unless I can actually see the brake lights.
  7. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    When you simply lift your foot off the gas and it slows down, you don't expect the brake light to come on, right? Likewise, if DRCC is slowing down in this manner and not actively applying the brake, the light won't come on.
  8. RaZa
    RaZa Member
    480
    93
    what i'm wondering is when is it "in this manner" just saying it's hard if not impossible to tell when it is. even with our own driving there are times you may have your foot on the brake and slowly applying it. lights would be on, but any passengers you have would probably not be able to tell you that you are braking...
  9. qbee42
    18,058
    3,081
    Northern Michigan
    You can't tell, since the only difference is the amount of applied braking.
    The Prius lacks the engine and transmission drag found in ordinary cars, so it simulates it by applying a small amount of regenerative braking when the driver lifts his foot from the accelerator pedal. This is technically considered coasting, so no brake light is shown, but with the Prius it is actually light braking.
    Any braking harder than that is considered braking and the brake lights are illuminated.
    Because of this, the difference between coasting and braking is just an arbitrary threshold. Without instrumentation there is no way for the driver to tell when the threshold is crossed.
    Tom
  10. RaZa
    RaZa Member
    480
    93
    Already understood
